EAGLE User Chat (English) cap round flat is not selectable in line properties
  • Views 837 views
I am following the manual tutorial to create components and I see lines with square endings (not round). I also noticed there is a property Cap round/ flat for lines but it is not selectable (greyed out and forced to "round"). Also there is a Cap round/flat under the wrench change tool which IS selectable but has no effect, my line is still rounded ends no matter what. I hope somebody figure that out.
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    Wow you're right, thanks for that, but it does not make sense why the option is blocked with wires and available with arcs. Actually I do need it for arcs foremost (custom RF board)  so that's great it's there at least. There seems there is an untold story here, it should  be available for wires too ( some RF routes must end flat). But i can do as long as it's available with arcs image.
    0 autodeskguest over 12 years ago
    round/ flat for lines but it is not selectable (greyed out). Also there
    Hi Jarvis,
    I hope you're doing well. The ROUND and FLAT cap options only apply to
    ARCs. WIRES and ARCS are fundamentally the same thing in EAGLE hence why
    the options show up in both dialogs.
    hth,
    Jorge Garcia
