EAGLE User Chat (English) Good practice on 4layer pcb for noise immunity
  • Subscribers 189 subscribers
  • Views 408 views
pedromiguel
pedromiguel over 12 years ago
I want to design a 4layer board and not know what is the best practice to make best immunity to noise
I plan to put the components on the top layer and layer2 all as GND, the layer15 as VCC an the bottom layer for the rest of route. The top and bottom layer i want design a poligon that connects to GND
Anyone have experience with this and can give a ideas if what i want do it's correct or not?
Thanks in advance
Best regards
Pedro
    0 michaelkellett over 12 years ago
    Ground filling the top and bottom layers may or may not improve matters - the problem is that you may end up with a large number of small islands of copper connected to ground by thin tracks. If this does happen you need to stitch these islands to the ground plane with a large number of small vias.
    However it may not be worth while -  for sensitive analogue circuits putting ground plane under some parts may actually make things worse.
    If you have a relatively small number of connections to VCC it may be better to make these by track and use the "VCC" layer as a second ground plane.
    If I were you I would get out of the habit of calling any power net VCC, call it V5 or V33 or some name that tells you what it actually does - I've seen some horrible disasters when chips with VDD and VSS ( and other oddly named power pins) pins get mis-connected to  VCC  and GND.
    If you want to post  a .pdf (not Eagle format - I can't read it) of your top layer I might be able to offer some more ideas.
  • dukepro
    0 dukepro over 12 years ago
    Pedro,
    It's very convenient to have a ground and power plane, but in many cases
    one should consider using a star power and star ground architecture.
    This minimizes noise from one IC from interfering with the operation of
    another.  Ideally each component would have a ground line from its
    ground pin directly to the power supply ground.  Same goes for power.
    This can't always be done, but emphasis should be to keep all analog
    devices on their own analog ground, and digital devices on their own
    digital ground.  Both grounds can be tied together with a SHORT device
    in close proximity to the power supply ground.  The power planes do
    provide some capacitance, but it's such a small value that a .1 or .01
    uF bypass cap will swamp this out.
    Another suggestion is to keep the traces on one layer orthogonal to
    adjacent layers.  This minimizes the capacitive coupling from one trace
    to another.  So one layer should be designated for traces that run
    horizontal and diagonal from top left to bottom right, and the adjacent
    later should be designated for traces that run vertical and diagonal
    from bottom left to top right.  The idea is to minimize the stray
    capacitance between signals.
    Of course, for every rule there are exceptions, and it's up to the
    designer to identify which rules to follow and when to make exceptions.
    HTH,
        - Chuck
    On 08/12/2014 02:07 PM, Pedro Pinto wrote:
    Thanks in advance
    Best regards
    Pedro
    http://www.element14.com/community/message/123592
    1777.att1.html.zip
