EAGLE User Chat (English) Copy board layout and have schematic synced
  • Subscribers 187 subscribers
  • Views 1813 views
  • board
  • copy
  • eagle
  • eaglecad
  • layout
  • pcb
  • schematic
  • 6.6.0
I have a board that has 20 copies of the same charging circuit and I need to copy the physical layout 20 times (in .brd) while showing up in the schematic correct.  I know how to copy the schematic and I know how to copy the board layout (without keeping .brd and .sch in sync)
I will appreciate any help!
Using EagleCAD 6.6.0 PRO
    Great advice!  I was unable to do it the same way you said but almost. Here is the revised instructions.
    Given a board layout and schematic that you would like to copy.
    1. Open your *.brd and *.sch files.
    2. Switch to your *.brd file.
    3. Go to File>Import and select the same *.brd file.
    4. Place all components. (this will add a identical sheet to your *.sch file)
    5. For components that are unwanted switch to your *.sch file and delete them from your new sheet.
    I appreciate the help Osi Van Dessel!
    The best way to copy a single design multiple designs is to use the import tool in eagle.
    Create a new blank board.
    Go to file and select import.
    Navigate to the file you would like to import
    The schematic should be automatically updated as a new sheet. You will need to adjust what the net names and eagle will try to connect the nets it deems appropriate.
