EAGLE User Chat (English) How to retrieve deleted files/ file recovery? Dimension error at card edge.
  • Views 572 views
liu
liu over 11 years ago
Hi, I've lost my own library, I couldnt find it at the recycle bin and its missing.
I am facing problem with layout DIMENSION ERROR with the PCI express card edge. May I know how to solve these issues?
  • liu
    0 liu over 11 years ago in reply to autodeskguest
    Thank You for you help. I have solved this issue (:
    0 autodeskguest over 11 years ago in reply to liu
    On 17/11/2014 8:15 p.m., Liu Claudia wrote:
    There's the thing at the side and its the one causing the dimension
    problem, but i cant delete them. What should i do???
    The red thing at the side is not causing the dimension problem, it is
    indicating a dimension problem. It is one of the errors detected when
    you ran the DRC. You can clear it by selecting  tools > errors > clear
    all or type into the command line ERRORS CLEAR.
    The dimension problem likely stems from the distance of the left most
    smd pad and the edge of the board. You can approve it in the DRC results
    or change the DRC setting DRC>Distance to the clearance required. Read
    the help to understand the implications of doing this. It will affect
    the distance copper pours keep away from holes and the edges of the board.
    HTH
    Warren
  • liu
    There's the thing at the side and its the one causing the dimension problem, but i cant delete them. What should i do???
