EAGLE User Chat (English) Eagle v8 licensing...
  • Replies 415 replies
  • Subscribers 218 subscribers
  • Views 29957 views
  • eagle
  • license
  • freeware
  • 8.0
technolomaniac
technolomaniac over 8 years ago
Hi All --
Moving this to a separate thread so it doesn't get lost in the ether.  Here's my two cents on licensing and I'd love your feedback:
Firstly, the Autodesk licensing model is subscription and the EAGLE paid license will require that you install the SW and then generate an account to retrieve your license entitlement.  Once you have this, you are good to go and the SW will run as expected.  If you lose your network connection, the SW has a 14-day heartbeat that will enable you to work offline for 14 days.  I know that some folks would prefer to never have to connect, but this is required to support a monthly subscription model that can be selectively enabled and disabled when you use the SW (so you only pay when you use it).  The total cost of ownership for those folks using it less than a few weeks a year will thus be substantially lower and still enables you to access the full software for less money.  <Insert revolt here>  image
WRT to "what happens if autodesk decides to one day just shut off the license server?" ...ok, sure, that's possible, but so is a reality TV star becoming President of the..cough...nevermind, bad example.
Point is, that's a pretty remote possibility (think: time travel and alien invasions) and it wouldn't benefit us *at all* to upset the users we just spent real money hoping to bring into autodesk and earn their business.  As the guy with both development and P&L for the product, I can tell you that it's counterintuitive and wouldn't benefit us at all.  We know this.  We make SW used by governments, movie studios, game developers, MEs, Civil Engineers, machinists, etc. and you can bet that shutting down a license server is not to our benefit in any of these categories.  To demonstrate this behavior in one category, without a path for user SW and data, calls into question ALL of our tools' viability under this model.  Not helpful.
Now...a question was raised about "but what if I drop my subscription and I want my data".  Awesome, the data is yours and lives on your machine.  And for SW that stores data in the cloud (we have some of these) we always provide a path to your data.  If this again fails with one product, it puts all of the others up for discussion.  Again, not helpful.  (Read:  strategy = doomed).
"So what about needing an entitlement for the freeware to open the data I created in another version (a *paid* version) and reading it?  What if I want access and I dont want the 14-day time out?"
So here's the deal...We can do better here.  So we will.  Here's my commitment to the group here for freeware that ensures you always have a license that you can fall back on without need of internet connection *except when you first install it* (which after all, you would have had to get it in the first place):  in version 8.1 or 8.0.1 or whathaveyou (let's call it 'a future release'), if you install the SW and authenticate once, we'll remove the timer req.  So what I'm saying another way is, the freeware will require you to login the first time to get your license, but if you log out beyond that, you're good.  You got your entitlement and you can use it freely without connection.
Caveat:  to install an update, you will need to login.  The update server (which issues the new version...e.g. 8.1 or 8.2. or 8.0.1, etc.) requires that you login and get the update, but beyond that, logout.  Thus if you want to go off-grid in a mountain cabin somewhere, get your license at Starbucks (blagh! I understand they have 'free' wifi, but no frappucinos!  ...that stuff is bad for you) then get your license and go on your merry way up to the snow drenched peaks.  When you hear from the other mountaineers or your local yodeler that a new version of EAGLE is available...download, login, get your license, get your 'decaf double-pump vanilla non-fat latte macchiato' and head back up the slopes.
Point being, we can do the freeware better.  So we will.
Hope this is clear.  Let us know if you have questions!
Best regards,
Matt Berggren
Director - Autodesk
@technolomaniac
hackaday.io/matt
  • COMPACT
    COMPACT over 8 years ago in reply to autodeskguest +4
    Not to worry, it's back to the Drawing board for me.
    shabaz over 8 years ago +3
    Hi Matt, When will the EAGLE Maker version (or another solution for hobbiests) be v8-ready? I see the subscription for 'EAGLE Standard' and 'EAGLE Premium' are now available on the website, but not EAGLE…
  • albertovignati
    albertovignati over 8 years ago in reply to techsupport +3
    Il 21/02/2017 22:54, Ed Robledo ha scritto: The customers are the sole driving force to the improvements to EAGLE. Some of these 'wants' take time to be done right, that's the reason they were not done…
  • rbtx99
    rbtx99 over 8 years ago in reply to technolomaniac
    Matt Berggren wrote:
    @David Kirkby: Are you advocating breaking the license & stealing the software? Just curious.
    Best regards,
    Matt - Autodesk.
    Actually I am hopping that someone will manage to break the license. Not because I want to use the unlicensed copy, but because only when I can install it and run without online activation I will have confidence to use EAGLE for my work. It would be my fallback plan if you like for when you lose interest and abandon us unable to access our work.
  • levafreidin
    levafreidin over 8 years ago in reply to technolomaniac
            Next phrase does not belong to me:
    " Actually I am hoping that someone will do it. Not because I want to use the unlicensed copy, but because only when I can install it and run without online activation I will have confidence to use EAGLE for my work. It would be my fall-back plan if you like for when you lose interest and abandon us unable to access out work."
            Again, I did not say it (sentence above). Why you sent the e-mail to me?
    But I have another solution of the problem:
                  I  already bought AuloTRAX" (it imports "EAGLE" library and projects) ($49);
                  I installed "KiCAD" (free);
                  I installed "PCB Artist" (free);
                  I install demo version of "DipTrace" (full cost $1200 about).
    Next step is to check and select more suitable for me software.
    I think "KiCAD" would be most stable and growing, but I have to try.
                  Best regards,
                         Lev Freidin, Electronics Engineer.
  • geralds
    geralds over 8 years ago in reply to technolomaniac
    Hi Matt,
    have you ever read my posts here?
    1) Autodesk sells something Eagle does not yet have, but Autodesk is pushing us to pay a year before it will be developed later in the year.
    2) Autodesk pushes us to buy a toy software, because at the end of the license the Eagle falls back to a a toy version called "free version".
    3) Some employees (previously also of Cadsoft) of Autodesk seem to be a liar because they have said something last year,
    but now have a complete 180 ° rotated statement, appeased to urge them what Autodesk prescribes.
    Matt, did you read my suggestions, the 4 points I posted here in this thread?
    I have to take Eagle at the time because a change is much more expensive.
    But the software of the competition has already advanced over 15 - 20 years advanced software, which Autodesk wants to catch up in the 21st century.
    All extra tools that Eagle provides, such as 3D view, component database, router quality, must be paid in advance at Autodesk, which are already installed as standard in the software.
    But.... Eagle has nice functions, but......
    I appeal to think seriously about customer-friendliness.
    It's YOUR - Autodesk risk if you can't write a well software.
    If i like to buy a software, not just Eagle, i look for functions that it have right now, not sometime in the future!!!! "hopefully" !!!??!!
    We can also reckon, also understand business mathematics.
    I look forward to Eagle V9, V10, V???..... can it be happen?
    Best Regards,
    Gerald
    autodeskguest over 8 years ago in reply to technolomaniac
    Matt Berggren wrote on Fri, 24 February 2017 15:05
    Best regards,
    Matt - Autodesk.
    Nice of you to pop back in Matt.  Are you going to answer my questions
    about your claim that Autodesk operates all of these servers?
    http://www.eaglecentral.ca/index.php/mv/msg/53384/169470/b5a59619d668d7d428929436c36e1c27/#msg_169470
    https://forums.autodesk.com/t5/eagle-forum/matt-please-substantiate-your-claim/td-p/6888773
    We've had a reply from Element 14 already...
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • drkirkby
    drkirkby over 8 years ago in reply to technolomaniac
    Best regards,
    Matt - Autodesk.
    Matt,
    Given the VERY real risks with the licensing scheme, I would not wish to put any effort into using a product I know could stop working at any minute. I would want a "plan B", if Autodesk folded (less likely), or dropped support for the product (much more likely), I'd want a way out. For what it is worth, there's a huge list of obsoleted Autodesk products at
    https://en.wikipedia.org/wiki/Autodesk#Discontinued_products
    So why should I have confidence Eagle would not go the same way?
    rbtx99 sums it up with
    "Actually I am hopping that someone will manage to break the license. Not because I want to use the unlicensed copy, but because only when I can install it and run without online activation I will have confidence to use EAGLE for my work. It would be my fallback plan if you like for when you lose interest and abandon us unable to access our work."
    I would feel exactly the same myself.
    Luckily I don't have time invested in Eagle, so unlike some I am less bothered about this license. It just strikes me as a crazy one, and I feel very sorry for the people caught up in it all.
    For me, KiCad is much more attractive. No vendor lock-in.
    Quite honestly Matt, I'm fairly certain IF I wanted to, (which I do not), I could get a free trial of Eagle and use the program indefinitely without paying a penny. But the truth is even if Autodesk offered me 50 years of support on the product, without paying another penny, I would not invest any time in it. It is simply too risky.
    If you want to offer me £10.000 if I can prove it could be hacked, then I'd take up the challenge, but otherwise I am not interested. Even if I hacked it, collected the £10,000, I would still not use it.
    Dave
  • drkirkby
    drkirkby over 8 years ago in reply to Jan Cumps
    Jan Cumps wrote:
    Are you going to work with unlicensed software as a professional designer? You make your own customers liable in that case.
    No I am not going to work with unlicensed software. KiCad is much more attractive to me.
    But if I did use software that could stop working, I'd want a backup, in just the same way as I have a backup in case my hard disk fails.
    The expression "Don't put all ones eggs in one basket" comes tom mind.
    Dave
  • clem57
    clem57 over 8 years ago
    The storm I said was coming has turned into a full fledged hurricane.image
  • drkirkby
    drkirkby over 8 years ago in reply to geralds
    Best Regards,
    Gerald
    It is unreasonable to say someone is a liar over this. They probably said it with the best intentions in the world, believing it to be true, but later someone else made a decision different to what they expected.
    Dave
  • macegr
    macegr over 8 years ago in reply to clem57
    I wonder how long it will take them to realize the truth:
    • Yes, the people who actively post on forums about Eagle, and care about licensing, are greatly in the minority.
    • Yes, there are many people who will just not care, and buy the subscription.
    • However, those people WERE TOLD ABOUT EAGLE by us, the vocal minority. We have a disproportionate impact on the market.
    Eagle, and Autodesk, do not have the momentum necessary to succeed without the support of the users, like myself, who recommended Eagle to their colleagues and invested valuable time helping those people learn to use Eagle.
  • KE5FX
    KE5FX over 8 years ago in reply to autodeskguest
    On 2/23/2017 9:29 AM, Jorge Garcia wrote:
    I hope you're having a good day. Autodesk is not giving up on EAGLE at
    all, that's why so much work . However Autodesk has almost 3 million
    subscribers of their software, so they have demonstrated that the model
    works and that there are a lot of customers who like the model.
    Question for you (or anyone else who knows) -- how many other Autodesk
    products, besides EAGLE, use a product-specific file format (whether
    documented or not) that no other industry-standard tools are compatible
    with?
    In other words, how many of those 3 million customers are being held
    hostage by Autodesk the way EAGLE users are now, with no alternative but
    to continue their subscriptions if they want to keep doing business...
    and with no assurance that they'll be able to install and use the
    software over the next several years at any price?
    -- john
