EAGLE User Chat (English) Eagle v8 licensing...
  • Replies 415 replies
  • Subscribers 218 subscribers
  • Views 29997 views
  • eagle
  • license
  • freeware
  • 8.0
technolomaniac
technolomaniac over 8 years ago
Hi All --
Moving this to a separate thread so it doesn't get lost in the ether.  Here's my two cents on licensing and I'd love your feedback:
Firstly, the Autodesk licensing model is subscription and the EAGLE paid license will require that you install the SW and then generate an account to retrieve your license entitlement.  Once you have this, you are good to go and the SW will run as expected.  If you lose your network connection, the SW has a 14-day heartbeat that will enable you to work offline for 14 days.  I know that some folks would prefer to never have to connect, but this is required to support a monthly subscription model that can be selectively enabled and disabled when you use the SW (so you only pay when you use it).  The total cost of ownership for those folks using it less than a few weeks a year will thus be substantially lower and still enables you to access the full software for less money.  <Insert revolt here>  image
WRT to "what happens if autodesk decides to one day just shut off the license server?" ...ok, sure, that's possible, but so is a reality TV star becoming President of the..cough...nevermind, bad example.
Point is, that's a pretty remote possibility (think: time travel and alien invasions) and it wouldn't benefit us *at all* to upset the users we just spent real money hoping to bring into autodesk and earn their business.  As the guy with both development and P&L for the product, I can tell you that it's counterintuitive and wouldn't benefit us at all.  We know this.  We make SW used by governments, movie studios, game developers, MEs, Civil Engineers, machinists, etc. and you can bet that shutting down a license server is not to our benefit in any of these categories.  To demonstrate this behavior in one category, without a path for user SW and data, calls into question ALL of our tools' viability under this model.  Not helpful.
Now...a question was raised about "but what if I drop my subscription and I want my data".  Awesome, the data is yours and lives on your machine.  And for SW that stores data in the cloud (we have some of these) we always provide a path to your data.  If this again fails with one product, it puts all of the others up for discussion.  Again, not helpful.  (Read:  strategy = doomed).
"So what about needing an entitlement for the freeware to open the data I created in another version (a *paid* version) and reading it?  What if I want access and I dont want the 14-day time out?"
So here's the deal...We can do better here.  So we will.  Here's my commitment to the group here for freeware that ensures you always have a license that you can fall back on without need of internet connection *except when you first install it* (which after all, you would have had to get it in the first place):  in version 8.1 or 8.0.1 or whathaveyou (let's call it 'a future release'), if you install the SW and authenticate once, we'll remove the timer req.  So what I'm saying another way is, the freeware will require you to login the first time to get your license, but if you log out beyond that, you're good.  You got your entitlement and you can use it freely without connection.
Caveat:  to install an update, you will need to login.  The update server (which issues the new version...e.g. 8.1 or 8.2. or 8.0.1, etc.) requires that you login and get the update, but beyond that, logout.  Thus if you want to go off-grid in a mountain cabin somewhere, get your license at Starbucks (blagh! I understand they have 'free' wifi, but no frappucinos!  ...that stuff is bad for you) then get your license and go on your merry way up to the snow drenched peaks.  When you hear from the other mountaineers or your local yodeler that a new version of EAGLE is available...download, login, get your license, get your 'decaf double-pump vanilla non-fat latte macchiato' and head back up the slopes.
Point being, we can do the freeware better.  So we will.
Hope this is clear.  Let us know if you have questions!
Best regards,
Matt Berggren
Director - Autodesk
@technolomaniac
hackaday.io/matt
  • COMPACT
    COMPACT over 8 years ago in reply to autodeskguest +4
    Not to worry, it's back to the Drawing board for me.
    shabaz over 8 years ago +3
    Hi Matt, When will the EAGLE Maker version (or another solution for hobbiests) be v8-ready? I see the subscription for 'EAGLE Standard' and 'EAGLE Premium' are now available on the website, but not EAGLE…
  • albertovignati
    albertovignati over 8 years ago in reply to techsupport +3
    Il 21/02/2017 22:54, Ed Robledo ha scritto: The customers are the sole driving force to the improvements to EAGLE. Some of these 'wants' take time to be done right, that's the reason they were not done…
  • macegr
    macegr over 8 years ago in reply to autodeskguest
    It's going to work, too. The only reason you don't often see competitors in the same business doing this sort of adversarial marketing: usually companies don't aim a crew-served .50 at their own feet and hold down the trigger.
  • sauerwald
    sauerwald over 8 years ago in reply to autodeskguest
    Altium is not a cure-all.
    I use both Eagle and Altium.   When using Altium my employer has a license server where I have to grab a license to use the program.  If I am away from an internet connection and don't have an active license, I am S.O.L,  Sometimes I will be working with a schematic only license, and then need to use the layout tool - and that can also be a PITA.
    Altium is a fine environment, and does some things far better than Eagle.  Eagle has it's advantages too, and there are times when it is the best tool for the job, but neither one ticks all the boxes.
    I do lament the change in licensing structure, and I hope that it will change.  For the forseeable future, I'll continue working in Eagle (7.5) as well as Altium.
  • drkirkby
    drkirkby over 8 years ago in reply to autodeskguest
    CadSoft Guest wrote:
    Just got a contact from Altium, starting with, "You are in a rush to modify
    your PCB. So, you start EAGLE and then this happens..." and then a
    picture of the "Oops, an error occurred" Autodesk dialog.
    Then, the interesting part, "Move to Altium Designer and we will give you
    back what you paid for your EAGLE license!"
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    Competition in a marketplace is usually a good thing, and it seems the Autodesk has created a bit more competition.
    I don't suppose Altium made a serious attempt to attract Eagle customers before, as they knew there was a significant price difference. But Autodesk have introduced a "feature" which Altrium see as something they can exploit.
    It is interesting to see the number of people joining the KiCad forum very recently. This post by hippo
         Import project from Eagle
    Projects
    about converting Eagle files to KiCad was made by someone who joined only one day ago. Although it appears he is already running 8.0.
    https://forum.kicad.info/t/import-project-from-eagle/5517
    I don't think that is a coincidence.
    Dave
    autodeskguest over 8 years ago in reply to sauerwald
    Mark Sauerwald wrote on Wed, 01 March 2017 15:54
    Eagle.
    Yes, there is a reason they use Altium at my day job and would never
    consider EAGLE.
    Agreed.  I tried to do a tiny board in Altium Designer, and just kept
    thinking I was using a bazooka to hit a tsetse fly...
    change.
    I'm a skeptic; I too prefer the old license, but doubt it will change.  In
    a bittersweet decision, our diy music devices group decided to remove all
    eagle files from their web sites.  I'm now converting my designs to KiCad
    (and Circuit Studio)...
  • macegr
    macegr over 8 years ago in reply to sauerwald
    We're used to hardship. I don't think there's ever been a CAD package used by professionals made someone say "You know, this program is an absolute joy to use" (barring some heavy-duty sarcasm).
    These software packages are hard to use, and not necessarily by bad developer decisions, but due to the nature of the work that has to be done. It takes significant time to be functional in them, let alone start feeling like an expert. The program gets in the way of your work for a long time as you start to learn it.
    An earlier poster said they wouldn't use a cloud or internet-tethered program for serious work even if it was free...or even if the software company PAID them to use it. The reason for this is above. Our time is valuable, and it's a waste of precious weeks and months to learn how to use a program that could be taken away at any moment.
    It would be like designing a new product that depended on a part that was already in last-time-buy status. You just made sure that at some point in the near future you're going to have to redesign that product. A cloud-based or internet-tethered CAD package takes away the chance you'll have to spend months becoming skilled in a different CAD package someday, and turns it into a certainty.
    autodeskguest over 8 years ago in reply to autodeskguest
    Yep, so true. And freezing for 5 hours because the nest thermostat also
    didn't control the heater anymore....
    Interesting times nowadays...
    Markus
    Markus Rudolf wrote on Thu, 02 March 2017 01:33
    I'm starting to wonder if I'm part Luddite.  I have a swamp cooler on my
    house, I drive a 1988 Toyota 4x4 with a manual transmission, and I've taken
    my best photographs with a completely manual Nikkormat.
    On the other hand, I'm having solar panels installed, I've got a Raspberry
    Pi controlling the watering system and I love my Lumia 550XL...  LOL!
  • rbtx99
    rbtx99 over 8 years ago in reply to Joop14
    Probably the outage was related to this...
    Amazon typo knocked websites offline - http://www.bbc.co.uk/news/technology-39151932
    autodeskguest over 8 years ago in reply to rbtx99
    Amazon typo knocked websites offline - http://www.bbc.co.uk/news/technology-39151932 (https://www.element14.com/community/external-link.jspa?url=http%3A%2F%2Fwww.bbc.co.uk%2Fnews%2Ftechnology-39151932)
    Of course with THEM this is never going to happen.... Also EAGLE
    never is going to be subscription...
    Markus
  • techsupport
    techsupport over 8 years ago in reply to autodeskguest
    Just as reminder, EAGLE can work offline for up to 14 days.
    Ed
