EAGLE User Chat (English) Eagle v8 licensing...
  • Replies 415 replies
  • Subscribers 218 subscribers
  • Views 30036 views
  • eagle
  • license
  • freeware
  • 8.0
technolomaniac
technolomaniac over 8 years ago
Hi All --
Moving this to a separate thread so it doesn't get lost in the ether.  Here's my two cents on licensing and I'd love your feedback:
Firstly, the Autodesk licensing model is subscription and the EAGLE paid license will require that you install the SW and then generate an account to retrieve your license entitlement.  Once you have this, you are good to go and the SW will run as expected.  If you lose your network connection, the SW has a 14-day heartbeat that will enable you to work offline for 14 days.  I know that some folks would prefer to never have to connect, but this is required to support a monthly subscription model that can be selectively enabled and disabled when you use the SW (so you only pay when you use it).  The total cost of ownership for those folks using it less than a few weeks a year will thus be substantially lower and still enables you to access the full software for less money.  <Insert revolt here>  image
WRT to "what happens if autodesk decides to one day just shut off the license server?" ...ok, sure, that's possible, but so is a reality TV star becoming President of the..cough...nevermind, bad example.
Point is, that's a pretty remote possibility (think: time travel and alien invasions) and it wouldn't benefit us *at all* to upset the users we just spent real money hoping to bring into autodesk and earn their business.  As the guy with both development and P&L for the product, I can tell you that it's counterintuitive and wouldn't benefit us at all.  We know this.  We make SW used by governments, movie studios, game developers, MEs, Civil Engineers, machinists, etc. and you can bet that shutting down a license server is not to our benefit in any of these categories.  To demonstrate this behavior in one category, without a path for user SW and data, calls into question ALL of our tools' viability under this model.  Not helpful.
Now...a question was raised about "but what if I drop my subscription and I want my data".  Awesome, the data is yours and lives on your machine.  And for SW that stores data in the cloud (we have some of these) we always provide a path to your data.  If this again fails with one product, it puts all of the others up for discussion.  Again, not helpful.  (Read:  strategy = doomed).
"So what about needing an entitlement for the freeware to open the data I created in another version (a *paid* version) and reading it?  What if I want access and I dont want the 14-day time out?"
So here's the deal...We can do better here.  So we will.  Here's my commitment to the group here for freeware that ensures you always have a license that you can fall back on without need of internet connection *except when you first install it* (which after all, you would have had to get it in the first place):  in version 8.1 or 8.0.1 or whathaveyou (let's call it 'a future release'), if you install the SW and authenticate once, we'll remove the timer req.  So what I'm saying another way is, the freeware will require you to login the first time to get your license, but if you log out beyond that, you're good.  You got your entitlement and you can use it freely without connection.
Caveat:  to install an update, you will need to login.  The update server (which issues the new version...e.g. 8.1 or 8.2. or 8.0.1, etc.) requires that you login and get the update, but beyond that, logout.  Thus if you want to go off-grid in a mountain cabin somewhere, get your license at Starbucks (blagh! I understand they have 'free' wifi, but no frappucinos!  ...that stuff is bad for you) then get your license and go on your merry way up to the snow drenched peaks.  When you hear from the other mountaineers or your local yodeler that a new version of EAGLE is available...download, login, get your license, get your 'decaf double-pump vanilla non-fat latte macchiato' and head back up the slopes.
Point being, we can do the freeware better.  So we will.
Hope this is clear.  Let us know if you have questions!
Best regards,
Matt Berggren
Director - Autodesk
@technolomaniac
hackaday.io/matt
  • COMPACT
    COMPACT over 8 years ago in reply to autodeskguest +4
    Not to worry, it's back to the Drawing board for me.
    shabaz over 8 years ago +3
    Hi Matt, When will the EAGLE Maker version (or another solution for hobbiests) be v8-ready? I see the subscription for 'EAGLE Standard' and 'EAGLE Premium' are now available on the website, but not EAGLE…
  • albertovignati
    albertovignati over 8 years ago in reply to techsupport +3
    Il 21/02/2017 22:54, Ed Robledo ha scritto: The customers are the sole driving force to the improvements to EAGLE. Some of these 'wants' take time to be done right, that's the reason they were not done…
  • techsupport
    techsupport over 8 years ago in reply to COMPACT
    COMPACT wrote:
    I just wish that EAGLE had a cheap licence for a maximum limit of 6" x 11" for two sided PCBs such as vintage S-100 boards.
    The low density of old SSI (Small Scale Integration) ICs doesn't allow these designs on very small boards.
    Maybe a few months of the EAGLE Premium version is all you need to get this project done.
    Ed Robledo
    Global Support Specialist
    Autodesk, Inc.
  • rbtx99
    rbtx99 over 8 years ago in reply to techsupport
    That reply shows how disconnected Autodesk is with how engineers work. Just today I opened an EAGLE board I designed last September to modify a component value. With your licensing model I need a month subscription just to update such minor things. It may be a resistor value, or it may be one track that we moved to another MCU pin, or moving a screw hole which I did on the same board in December. If I don't update the board immediately then the information get scattered around and can be lost/missed. Really, EVERYTHING about the subscription license is detrimental to my work and workflow.
  • COMPACT
    COMPACT over 8 years ago in reply to rbtx99
    Likewise for me and a lot of other parties.
    Also the machine being used is deliberately isolated and not network connected.
    autodeskguest over 8 years ago in reply to rbtx99
    Full acknowledge to this statement from me!
    Andreas
  • COMPACT
  • andycrofts
    andycrofts over 8 years ago
    OK, don't like subscription model, but I can certainly live with it IF:
    I found a lovely chip from TI. 3-channel high-side voltage/current measuring thingy with I2C interface. INA3221. Perfect for (e.g.) solar panel/MPPT design.
    BUT, it's only surface mount. Take me about an hour to put it onto a breadboard PCB, so "Arduino-compatible".
    I'll give the design away under the GPL , but there are folks out there who can't do their own PCB.
    It'd be double-sided.
    Does this new subscription model mean I can make a free prototype, test, then if it's OK, take a months €15 subscription to satisfy the legal bit, make a thousand PCB's (from Seeedstudio, for example that month), sell them and let my subscription lapse?
    Seems cheap to me!
    Or am I missing something?
  • macegr
    macegr over 8 years ago in reply to andycrofts
    The pricing is not the issue (though it's more expensive for someone who makes a PCB every month). The part you're missing is that some of us prefer not to have our tools stop working on the day Autodesk decides Eagle isn't worth it anymore.
  • KE5FX
    KE5FX over 8 years ago in reply to andycrofts
    I found a lovely chip from TI. 3-channel high-side voltage/current measuring thingy with I2C interface. Perfect for (e.g.) solar panel/MPPT design.
    Seems cheap to me!
    Maybe, maybe not.  Come back and try to access your design in a few
    years, and see how lucky you are.
    -- john
  • KE5FX
    Seems cheap to me!
    -- john
  • geralds
    geralds over 8 years ago in reply to andycrofts
    Are you sure, that you are sure?
    Then press ENTER!
    After expiring the license period Eagle falls down to the toy mode. -> free mode.
    Gerald
