EAGLE User Chat (English) edit .sch; ... # ... truncated in front of the '#'
  • Subscribers 187 subscribers
  • Views 836 views
autodeskguest over 8 years ago
Hi all,
first things first: I'm using eagle 6.6.0
after hashing out why my recent ulp project work as expected, it boild
down to the following:
if you have something like "edit .sch;  some other commnd ... # ...",
the command line is truncated in front of the '#' character.
For example: "edit .brd; sh 5V# GND" will only highlight the 5V net.
This iis the same with .sch and .sX, from the schematic or board
editor and from an exit("...") command.
The later is the case I stumbled upon.
Can someone confirme the behaviour?
Or, even better, explain it?
Lorenz
    autodeskguest over 7 years ago in reply to autodeskguest
    Sent:  Wednesday, October 03, 2018 8:55AM
    To:
    Cc:
    Subject: Re: edit .sch; ... # ... truncated in front of the '#'
    On 3/10/2018 08:55, warrenbrayshaw wrote:
    On 3/10/2018 6:44 p.m., warrenbrayshaw wrote:
    On 3/10/2018 12:17 a.m., Lorenz wrote:
    Hi all,
      Hi
    Using v6.6.0 WIN7 I cannot get that to happen from the command line or
    a ULP.
    How about attaching a file that gives you the problem and we'll try it.
    I'm guessing at this point that everything after the # is being seen
    as a comment.
    Warren
    Ok, hold the presses.
    I have been able to make it happen and it also happens with V7.7
    There are two possible results for a '...SHOW 5V# GND'
    string cmd;
    sprintf(cmd,"write; show 5V# GND");
    exit(cmd);
    will only display 5V if it exists
    string cmd;
    sprintf(cmd,"show 5V# GND");
    exit(cmd);
    will display GND and tell you it cannot find 5V#
    So it appears that if the editor has just attained it's state from an
    edit .brd or a save (write) it reacts differently to when it has had the
    focus continuously.
    I cannot explain it.
    Warren
    Hi all,
    1. is escape character for comments in script files(// is escape
    character for ulp file) and in this snippet of code:
    > string cmd;
    > exit(cmd);
    as far as I know, the string in "cmd" is a script file that is executed
    at the end of the execution of the ulp file, so this is quite logic...
    Michel
    On 02.10.2018 13:17, Lorenz wrote:
    Hi all,
    Adding single quotes to all names is a good rule of thumb, and seems to
    resolve this issue too.
    This must be something with the handover; when first command of a string
    is executed in the schematic editor, while the next one is passed on to
    the board editor, weird stuff happens.
    autodeskguest over 8 years ago in reply to autodeskguest
    Hi all,
     Hi
    Using v6.6.0 WIN7 I cannot get that to happen from the command line or a
    ULP.
    I'm guessing at this point that everything after the # is being seen as
    a comment.
    Warren
    string cmd;
    exit(cmd);
    string cmd;
    exit(cmd);
    focus continuously.
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    Hi all,
      Hi
    ULP.
    a comment.
    Warren
    Thunderbird!
