EAGLE User Support (English) I want help with a custom library!
  • Subscribers 187 subscribers
  • Views 885 views
  • custom lbr
  • .lbr
scuplex
scuplex over 6 years ago
Hello dear community,
  I came across a problem creating on library for a terminal block! i've spend the past 2 hours trying to make one with no success
i want one like this!  But i cant make one!
I've taken the exact measurements that i need and it doesnt line up correctly! Trying all over again with different MM mil and stuff but no success!
Any help would be appreciated! image
    dougw over 6 years ago in reply to scuplex
    You can type in coordinates of anything you are trying to place or just set the grid pitch to match you positioning requirements before creating and dropping the part.
    One thing to note is: you can snap the part you want to drag to your cursor with the CTRL key so that you can place it precisely on the grid.
  • scuplex
    scuplex over 6 years ago in reply to dougw
    Im trying that too but i come into some problems too! Maybe i dont know how to use eagle custom library (i've made some libraries my self too and they work ! but this one is a difficult one!)
    Thanks a lot for the quick reply too!!! what a great community!! image
  • scuplex
    scuplex over 6 years ago in reply to shabaz
    thanks a lot for the quick reply! i will read it for sure!
    Are you just trying to get the labels to line up?
    The labels can be placed anywhere with any accuracy - you may need to set a smaller grid pitch when adjusting position because they snap to the grid when dragging.
    shabaz over 6 years ago
    Hi George,
    See here for a multi-part guide:
    EAGLE Tutorial: Library Part Creation Part 1 - Creating Packages
