EAGLE User Support (English) PCB mounted Heat Sink
  • Subscribers 177 subscribers
  • Views 1499 views
I am working on a board that uses a vertical heat sink (Aavid 531102B0)
that has pins to mount it to the board. I can make a PCB footprint
(package) for it, but I'm not sure how to add it to the board, since it
won't have a schematic equivalent. How do I do this?
-Dave Pollum
    You could always give it a schematic symbol. The symbol doesn't need any
    pins (unless you want to be able to connect the heatsink to ground). I'd
    suggest placing it on the schematic somewhere near the component that's
    mounted on the heatsink, perhaps with a bit of text saying "TR3 mounted
    on heatsink".
    Am 12.12.2015 um 23:34 schrieb David Pollum:
    -Dave Pollum
    You could use symbols from the heatsink-lbr image
    Joern Paschedag
    Joern Paschedag wrote on Sun, 13 December 2015 03:33
    Joern Paschedag
    I haven't used a PCB mounted heat-sink before, so I didn't know about
    "heatsink.lbr". Even though I've used EAGLE for many years, I am still
    learning new things about EAGLE. Thanks, Joern!
