EAGLE User Support (English) Printed Text on Circuit Board
  • Subscribers 178 subscribers
  • Views 4337 views
Former Member over 15 years ago
I am new to this software. What layer do I use to insert text that will
be printed on the top side of a manufactured circuit board. I am
guessing that it is the dimension layer 20 but am not sure. I can't find
the necessary information in the manual.
Ken
    Ken
    You don't say if you want the text to appear in etch (metal) or
    silkscreen.    For etch you can put text directly into the top (or
    bottom) layers of the board....of course you have to be careful that the
    etched letters don't short important stuff!
    For silkscreen on the top of the board common layers to use are tPlace,
    Document, or tDocu.   Whatever layer you pick,  you also have to make
    sure that the CAM job setup includes that layer in the output gerber for
    the silkscreen layer.
    Jim
    kend wrote on Sat, 12 June 2010 10:46
    What layer do I use to insert text that will be printed on the top side
    tPlace
