EAGLE User Support (English) Selecting inches/mm with the RS_274x CAM processor
  • Replies 9 replies
  • Subscribers 189 subscribers
  • Views 2653 views
Is there any way to output Gerbers files with the RS_274X CAM processor
in anything other than inches?  I'm capturing in mm, so I would think
that the Gerber files would be output in mm, but looking at the files I
can see that I am getting inches instead.  I don't see any place in the
CAM processor dialog to select unit systems.
Truly, what I'd really like is a Gerber output in microns (um), but I'll
take mm.  Inches are a problem.
Michael
    autodeskguest over 10 years ago in reply to bbartley
    Is there some reason this isn't in the normal EAGLE distribution? While
    inches seems to be the most common, I've dealt with a couple of shops
    that prefer mm.
    Hi Brad,
    This is part of the normal EAGLE distribution, at least now anyway ;).
    You'll find the drivers listed for EXCELLON_33MM and GERBER_RS274X_33MM.
    This was added recently with the release of 7.3 if memory serves.
    Best Regards,
    Jorge Garcia
  • bbartley
    bbartley over 10 years ago in reply to Richard_H
    This worked just fine for me. (More specifically, this version: http://www.eaglecentral.ca/forums/index.php/mv/msg/34173/117557/ did.)
    Is there some reason this isn't in the normal EAGLE distribution? While inches seems to be the most common, I've dealt with a couple of shops that prefer mm.
    Thanks!
    Brad
    http://www.webspace.ne.jp/rental/icon_tree_bbs/bbs.php?pid=5574&mode=pr&parent_id=326
    Sample for mm 3.4-digit format.
    Where should I paste it? Do I need a header or something for the first part, or should it replace something existing?:
    Type = PhotoPlotter
    Long = "Gerber photoplotter"
    Init = "G01\nX000000Y000000D02\n"
    Reset = "X000000Y000000D02\nM02\n"
    ResX = 25400
    ResY = 25400
    ;Wheel = ""
    Move = "X%0.6dY%0.6dD02*\n" ; (x, y)
    Draw = "X%0.6dY%0.6dD01*\n" ; (x, y)
    Flash = "X%0.6dY%0.6dD03*\n" ; (x, y)
    Aperture = "%s*\n" ; (Aperture code)
    Units = mm
    Decimals = 4
    Info = "Plotfile Info:\n"\
    "\n"\
    " Coordinate Format : 3.3\n"\
    " Coordinate Units : mm\n"\
    " Data Mode : Absolute\n"\
    " Zero Suppression : None\n"\
    " End Of Block : *\n"\
    "\n"
    I just copied pasted it into the existing Eagle def file...I received the
    same error - it was easy to fix, one of the lines has simply wrapped round
    onto a new line (it tells you which line is giving the error) ...therefore
    there was no " at the end of the line - I just brought the line that
    followed back up to join it where it should have been
    e14 Contributor over 14 years ago in reply to Richard_H
    I'd really like millimetre output to, so I copied/pasted your code above
    into teh eagle.defs file, but weird results when I open up the gerber file
    (no such problems with the original inch versions)....
    http://imageshack.us/photo/my-images/24/30216098.jpg/
    It appears just to be the centre line of every track?
    Here's the original board layout...
    http://imageshack.us/photo/my-images/835/70166729.jpg/
    Any ideas?
    Do I just add the text above in the .def file? Or should I replace anything? I have tried editing the def file by adding but get error messages: Unknown paramter or invalid value
    Mags
    e14 Contributor over 16 years ago in reply to Richard_H
    >> Thanks,
    >> Michael
    Michael,
    the default output of Gerber data is in inches. If you prefer to have
    "mm" you could change the Gerber device in the eagle.def file or even
    better define a new device. That's the place we define the output
    devices. It's located in the eagle/bin folder.
    Examples for Gerber output in mm 3.3 format:
    snip ....
    > snip ....
    HTH
    That worked well.  I reworked it to output in microns (just changed the
    scale from what you had by another factor of 1000).  I am bringing
    gerber files which are antennas into an RF simulation program that
    really wants microns.
    Thanks again,
    Michael
  • Richard_H
    Richard_H over 16 years ago
    Michael
    Michael,
    Type     = PhotoPlotter
    ResX     = 25400
    ResY     = 25400
    ;Wheel    = ""
    Units    = mm
    Decimals = 4
               "\n"\
               "\n"
    @GERBER_MM_33
    Long          = "Gerber photoplotter with automatic aperture wheel
    generation"
    Wheel         = "" ; avoids message!
    AutoAperture  = "D%d" ; (Aperture number)
    FirstAperture = 10
    Decimals      = 4
    Units         = mm
    @GERBERAUTO_MM_33
    Long          = "Gerber photoplotter with RS-274-X aperture generation"
    Units         = mm
    Init          = "G75*\n"           \ allow positive and negative coordinates
                    "G71*\n"           \ units are mm
                    "%%OFA0B0*%%\n"    \ horizonal and vertical OFfset is 0
                    "%%FSLAX33Y33*%%\n"\ Format Statement is Absolute (I for
    incremental) 3.3
                    "%%IPPOS*%%\n"     \ Image Polarity is POSitive (NEG for
    nagative)
                    "%%LPD*%%\n"       \ Layer Polarity Dark (C for clear on
    negative planes)
                    "%%AMOC8\n5,1,8,0,0,1.08239X$1,22.5\n"\ Octagons are
    emulated with a circle (using 8 vertices)
                    "%%\n"            ; and therefore the diameter must be
    enlarged with '1 / cos(pi / 8)'
    Reset         = "M02*\n"
    Circle        = "%%AD%sC,%6.3f*%%\n"        ; (code, diameter)
    Rectangle     = "%%AD%sR,%6.3fX%6.3f*%%\n"  ; (code, dx, dy)
    Oval          = "%%AD%sO,%6.3fX%6.3f*%%\n"  ; (code, dx, dy)
    ; According to the RS-274-X specs there is an aperture macro
    ; primitive that allows us to specify an octagon (i.e. a polygon with
    ; 8 vertices). As some Gerber viewers seem to have problems with that,
    ; we would have to use a round shape for that.
    ; If your Gerber processor cannot handle the polygon primitive you may
    ; uncomment the following line and comment out the line after it:
    ;Octagon       = "%%AD%sC,%6.3f*%%\n"   ; (code, diameter) (looks like
    there is no octagon, so we take a circle)
    Octagon       = "%%AD%sOC8,%6.3f*%%\n" ; (code, diameter)
    Annulus       = "%%AMAN%s\n1,1,%6.3f,0,0\n1,0,%6.3f,0,0*\n"\
                    "%%\n"\
                    "%%AD%sAN%s*%%\n" ; (code, diameter, inner diameter,
    code, code)
    Thermal       = "%%AMTH%sX\n1,1,%6.3f,0,0\n1,0,%6.3f,0,0*\n"\
                    "21,0,%6.3f,%6.3f,0,0,45\n21,0,%6.3f,%6.3f,0,0,135\n"\
                    "%%\n"\
                    "%%AD%sTH%sX*%%\n"; (code, diameter, inner diameter,
    diameter + 2mil, gap, diameter + 2mil, gap, code, code)
    HTH
    Richard Hammerl
