EAGLE User Support (English) *** Top Layer Jumpers to be Isolated ***
  • Subscribers 179 subscribers
  • Views 396 views
autodeskguest over 15 years ago
    Former Member over 16 years ago
    Thanks, I appreciate the guidance image
    I believe the right approach would be to extend bottom side traces in the
    affected area and add a pad.  Then go to the top side, ripup the
    appropriate connection and re-route to the new bottom side pad...
    If this is incorrect in theory, let me know, otherwise I will try this
    approach, thanks.
    Gordon
    Former Member over 16 years ago in reply to autodeskguest
    Tilmann,
    Thanks - I will practice my manual adjustments image
    I have plenty of SS boards to do so learning this sounds like the best
    thing.
    Gordon
    On Fri, 27 Nov 2009, Gordon Hope wrote to us saying :
    That sounds like the wrong order to me. Starting from a trace with a via
    in the middle of the top-side section, I would proceed as follows:
      - Identify which direction from the via has more bottom side space
      - rip-up the top side trace in that direction
      - manually route from the other end of that airwire, on top side
      - drop an intermediate point just short of the shared via
      - swap to bottom side
      - finish routing to the via
    That last step will automatically create a new via to act as your second
    pad. It's better than adding a pad manually because Eagle knows from the
    get-go that it's part of the signal you're modifying.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    Former Member over 15 years ago in reply to autodeskguest
    On 2009-11-27 08:47:01 +0100, Tilmann Reh <usenet2007nospam@autometer.de> said:
    Paul Romanyszyn schrieb:
    >> I don't think any setting will fix the autorouter results. Just clean up
    >> the autorouter results manually. After a few minutes of manual
    >> adjustments you should see that a few traces and jumpers may be able to
    >> be eliminated.
    I don't think that the autorouter will generate a useful result at all.
    Learn manual routing - especially for single sided boards.
    Tilmann
    Tillmann is right. Real Men Route by Hand. Real Women do it too, google
    for "ladyada routing Eagle" and you will find a great video where you
    can learn a lot, just by watching.
    Eur van Andel  eur@fiwihex.nl
    Former Member over 15 years ago in reply to Former Member
    Eur van Andel wrote on Mon, 12 July 2010 10:15
    That's silly, of course.  Do you refine your own silicon too?  Do you write
    all your PC programs by hand in machine language?
    The autorouter is tool, which has its advantages and disadvantages like any
    other.  If you spend a little time with it to learn what it can and can't
    do, and how to control it properly, you'll find it a useful tool that can
    save hours of pointless manual work.
    In this case as I understand it, the OP wants to create a single sided
    board with wire jumpers as needed.  Yes, this can be done with the auto
    router.  Set it up for a two layer board and make the bottom layer cost
    really high.  Set up the via parameters so that they become nice pads for
    the wire jumpers.  This will cause the autorouter to try to minimize the
    number of jumpers and their length.
    However keep in mind that the autorouter is just a tool.  It won't solve
    all the problems for you, but if used properly can do a lot of the rote
    work for you.  You will likely want to route some important traces manually
    before auto routing, then do some cleanup afterwards.  The combination can
    still take considerably less time than doing it all by hand.
