EAGLE User Support (English) Expose open project path in ULP
  • Replies 15 replies
  • Subscribers 180 subscribers
  • Views 1187 views
Former Member over 15 years ago
It would be useful if the path of the Open Project folder could be
determined from within a ULP.
Such a command should reveal the path of the Open project. If none is open
then it should indicate this by returning a null.
This would enable ULP code efficiencies when determining the folders used by
Eagle when a Project is open /or not..
Eagle already knows the path so I imagine that  it should not be a large
task to expose it via the User Language.
Thanks in anticipation
Warren
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:i54d39$6g6$1@cheetah.cadsoft.de...
    by
    You CAN investigate name memer of the board and schematic. "The name member
    returns the full file name, including the directory.".
    I dont know if that reflects the output folder, but it might.
    Former Member over 15 years ago in reply to Former Member
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:i5598g$h4v$1@cheetah.cadsoft.de...
    open
    used
    by
    member
    Its not the name of the open board or schematic that I'm after. You can get
    that easily and the full path is provided.
    Its the path to the Open Project I need, which is not necessarily the same
    as the open board as you can open any board. You are not limited to the open
    Project folder.
    I also need to know when there is no project open.
  • kcadsoft
    kcadsoft over 15 years ago
    You can do this with
      cfgget("EAGLE:Project.Dir")
    The cfgget() function was introduced in version 5.9.2.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    Former Member over 15 years ago in reply to kcadsoft
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:i55eqf$b8f$1@cheetah.cadsoft.de...
    Nice one, I've never looked for it, and I must have missed it in the release
    text.
    Can you read DRC parameters with it?
  • kcadsoft
    kcadsoft over 15 years ago in reply to Former Member
    No, but this is something that might go into the next version
    (not making any promises, though).
    Klaus Schmidinger
    open
    used by
    "Klaus Schmidinger"  replied
    Thank you, cfgget and cfgset are great additions.
    I suspect, for the reasons below , this does provide the correct path in all
    situations.
    Right now I cannot test this but have read the v5.10 help for the commands.
    Please tell me where my logic fails.
    (a) cfgget queries the user's eaglerc file.
    (b) eaglerc is updated when the user performs a File/Save All or when Eagle
    is closed
    (c) user's eaglerc file is not updated when a project is closed and another
    opened, within a session
    In the following scenario the previous project.dir will be returned.
    (1) Eagle is closed with an unclosed project ("Project1")
    (2) Eagle is opened and "Project1" is also open. The user's eaglerc file
    Project.dir points to "Project1"
    (3) Close "Project" and open "Project2"
    (4) Query the eaglerc file Project.dir with cfgget and it returns "Project1"
    (which is the previously open project) and not "Project2" (the currently
    open project).
    My argument pivots on point(c) above. The user's eaglerc file is not being
    updated when a project is closed and another opened, within a session. If it
    is then there is no problem and my apologies for wasting your time.
    Warren
  • kcadsoft
    cfgget() always returns the actual value currently used in the program.
    Klaus Schmidinger
    being
    Klaus Schmidinger
    That's great
    Many Thanks
    Warren
    Am 27.08.2010 10:13, schrieb Klaus Schmidinger:
    Note that this is NOT always the case with all possible parameters:
    Apparently, 'cfgget()' always returns the latest setting defined with
    'cfgset()', which might NOT be the value currently used by the program,
    because for some parameters, an EAGLE restart is necessary for
    re-reading them.
    Example:
      1. In the print dialog, set the left border to 5mm.
      2. Run the following ULP:
           dlgMessageBox(cfgget("EAGLE:Printer.Border.Left"));
           cfgset("EAGLE:Printer.Border.Left","80000");
      3. This first shows a border of '500000' (=5mm) and then
         '80000' (=8mm), which SEEMS to be conclusive.
      4. Unfortunately, now 'cfgget()' does NOT return the value
         currently used in the program any more, because EAGLE still
         uses the old value of 5mm, as can be seen by opening the
         print dialog again.
      5. When running the above ULP, exiting EAGLE without
         displaying the print dialog, and starting EAGLE anew,
         the changed left border of 8mm is used.
    Therefore, 'cfgget()' only works properly if the values were not
    previously modified by 'cfgset()'. This is a bit frustrating, because
    this makes 'cfgset()' practically useless for changing EAGLE settings...
    Andreas Weidner
    "Andreas Weidner" wrote..
    re-reading them.
    Example: ......................
    Nice example
    The Help for cfgget() and cfgset() confirms:
    "Some EAGLE parameters may require a restart of EAGLE for changes to take
    effect".
    Something you may like to try out is whether your parameters of interest can
    be put into effect with a "File Save All" thus saving a restart.
    A recent version update changed  "File Save All" to include an update of
    eaglerc.usr so there is possibly a win here.
    This all depends on Eagle re evaluating the eaglerc after a File Save all
    and re-setting the program accordingly. With the presence of cfgget() and
    cfgset() now, I feel this should happen.
    This does not help from within the ULP though.
    Warren
