EAGLE User Support (English) File Locking Fix on Mac Eagle 7.5.0
  • Replies 10 replies
  • Subscribers 189 subscribers
  • Views 1541 views
lisamaxima
lisamaxima over 10 years ago
Hi Jorge,
I think I fixed the file locking problem on my Mac running Yosemite OS X and Eagle 7.5.0.
I posted about it online earlier.
I'm wondering if the fix could be as simple as requiring the user to open his schematics and
boards through the Eagle console while in an an open project, and defeating the user's ability
to open the schematic or board directly by clicking on it in the OS X Finder and thereby
bypassing opening the project.
Perhaps the schematic and board's System Open File With... Attribute could be set to an
auxiliary program that instead of opening it , tells the user to open it using Eagle in an open
project to not disturb the lock mechanism.
Could you check my post and see if there's a simpler solution in there?
Lisa
  • lisamaxima
    lisamaxima over 10 years ago in reply to autodeskguest
    On the Mac, you change file association as follows:
    1. a. click on file, invoke File -> Get Info or b. right-click on file, ->
    Get Info
    2. the current (attempted) file association is shown in the Get Info dialog
    3. unlock the lock at the bottom of the Get Info dialog (requires admin or
    owner password)
    4. change the file association in the Get Info dialog
    5. if it won't change it:
    a. Check that the new association application is an allowed source in
    Applications -> System Preferences -> Security and Privacy
    b. If not, Allow from Anywhere
    c. change the file association in the Get Info dialog
    6. Lock the lock at the bottom of the Get Info dialog
    7. Go back to Applications -> System Preferences -> Security and Privacy
    and allow sources from identified developers only
    autodeskguest over 10 years ago in reply to lisamaxima
    On 12/28/2015 8:00 PM, lisa fredrickson wrote:
    If I save a file with Eagle 7.5.0, and quit Eagle, and later click on
    the file to open it,
    I expect Eagle 7.5.0 to open it, not an earlier version of Eagle.
    Hi Lisa,
    Thank you for the clarification, ignore my earlier reply. I know how to
    do this in Windows but Im not quite sure how to do it on the Mac.
    Hopefully someone can chime in.
    In Windows there's a setting in the Control Panel which controls which
    programs are assigned to which file extension. If eagle is associated
    with .sch Windows will call the executable that was installed at the
    time of setting up the association. It's not aware of any newer versions
    of the program.
    I think something similar is going on under the Mac OS.
    Best Regards,
    Jorge Garcia
  • lisamaxima
    If I save a file with Eagle 7.5.0, and quit Eagle, and later click on the file to open it,
    On 12/28/2015 1:57 PM, lisa fredrickson wrote:
    I noticed another bug leftover from installation.  I had Eagle 6.4
    installed on
    my machine then installed 7.5.0.  I would create a new project in Eagle
    7.5.0.
    However, if I later started Eagle by clicking on the eagle.epf in the
    project folder,
    it started the earlier version of Eagle instead of the current version,
    and
    I could
    even end up with two versions running at the same time.  When you quit
    from
    the wrong
    version, it gives an error message about over-writnig the eagle.epf from
    another version
    of Eagle.
    Hello Lisa,
    This is probably not a bug but actually the intended behaviour. The .epf
    file stores all of the info about the last time the designed was opened,
    version of EAGLE, window positions, libraries in use, etc. If the last
    time that design was opened it was opened with 6.4 then the eagle.epf
    file would likely call for 6.4 to open it.
    Personally, I usually just open EAGLE and then from there open whatever
    I want to work on. When you have multiple versions of EAGLE installed
    this is usually easier than relying on the OS to figure out which
    version of EAGLE to call.
    hth,
    Jorge Garcia
    On 12/28/2015 1:51 PM, lisa fredrickson wrote:
    Where should I download it from?
    www.cadsoftusa.com > Downloads > Betatest
  • lisamaxima
    installed on
    7.5.0.
    project folder,
    it started the earlier version of Eagle instead of the current version, and
    I could
    even end up with two versions running at the same time.  When you quit from
    the wrong
    another version
    of Eagle.
    On Mon, Dec 28, 2015 at 10:51 AM, lisa fredrickson <
  • lisamaxima
    Where should I download it from?  I noticed that Newark is now offering
    it as a limited trial download on their website, but I am using the
    freeware
    version from the Cadsoft website.
    On 12/24/2015 7:14 PM, lisa fredrickson wrote:
    Hi Jorge,
    and Eagle 7.5.0.
    Finder and thereby
    could be set to an
    Lisa
    http://www.element14.com/community/message/170103
    Hi Lisa,
    There were a number of file-locking issues reported for the Mac
    platform. These have been addressed in our latest beta 7.5.1, if you
    could try it out and let me know if everything working that would be
    very helpful.
    Any feedback on the file-locking or any other feature of EAGLE is always
    welcome.
    Best Regards,
    Jorge Garcia
  • lisamaxima
    lisamaxima over 10 years ago in reply to rachaelp
    I have been working with Eagle 7.5.0 a lot recently, and have found a
    number of bugs and
    work arounds.
    Unfortunately, Eagle starts up differently and invokes different options
    depending
    on whether you start the Eagle application (1) from its installation
    directory, (2) from the <project.epf>
    "EPF" file or (3) from the schematic or board file.  I have found that I
    can keep the "delete lock" demon
    away by religiously starting Eagle from the Applications folder, then
    opening the project, then opening
    the schematic or board, and backing out in the same way.  If I go off and
    do something else, like
    start Eagle, edit a CAM file, and quit Eagle. the locking demon for my
    project sometimes returns.
    I can get rid of it again  by religiously starting Eagle from the
    Applications folder, then opening the
    project, then opening the schematic or board, deleting the lock, checking
    that ERC reports the schematic and
    board are still consistent, and backing out, saving in the same way. Once
    the demon is gone,
    if I stick to my religious opening, it doesn't come back.
    In my opinion, Eagle violates standard Mac protocol by failing to ask if
    you want to overwrite existing
    files.  For example, with the CAM processor, if you tell it to process the
    job and there are existing
    CAM files already there, it silently overwrites them without asking if you
    want to replace them.
    In the same manner, Eagle is silently overwriting a number of preference
    files, including the
    project EPF file and other global preference files, without letting you
    know what is changing and
    if you really want to replace your existing preferences.  When you open
    your schematic or board
    directly, it is unclear how many of the preference settings are being
    updated.
    In addition, the Auto-Router window is especially buggy.
    1. If you turn off Auto-grid and set the grid number too low (e.g. 0.01 mm)
    the router starts but
    starts spitting up error messages and may crash.
    2. If you partially auto-route your board, and then make some change on the
    board and go back
    to auto-route, BEWARE of allowing the job to go with its default setting
    of  "continue".  Eagle starts
    spitting up error messages and crashes if you don't quit right away. You
    have to manually turn off the
    continue option.
    3. If you start an auto-route job, there is a delay for the window to
    update.  If you accidentally double-click
    when starting the job, or click again during the delay, the auto-router
    window may disappear and Eagle
    goes Zombie, continuing to route but without a controlling router window.
    If you try to use the standard
    Eagle menus, they are all greyed out  and nothing responds.  Apple's
    Force-Quit doesn't even work!
    The work-around is to start Apple's Activity Monitor, find Eagle in the
    list of running applications, click on
    Eagle and click on Quit (as opposed to Force-Quit).   Suddenly, Eagle comes
    back to life with an Error Message
    concerning Not being able to issue commands from the missing window, but
    then you say OK and Eagle
    is responding normally again.
    Hope this helps.
    Lisa
  • rachaelp
    rachaelp over 10 years ago
    Hi Lisa,
    Good job finding a work around to this issue. I didn't have the patience to
    keep digging to work this out, I just turned off the feature and ignored
    any remaining spurious whinges from Eagle!
    lisa fredrickson wrote on Fri, 25 December 2015 00:14
    open his schematics and boards through the Eagle console while in an an
    open project, and defeating the user's ability to open the schematic or
    board directly by clicking on it in the OS X Finder and thereby bypassing
    Personally I really wouldn't want this to be the fix as this just forces
    people to use Eagle in a particular way. I rarely use projects, they don't
    add anything of benefit to me and I would find being forced to use them
    quite annoying. Enforced use of projects is at best a work around in my
    opinion.
    could be set to an auxiliary program that instead of opening it , tells
    the user to open it using Eagle in an open project to not disturb the
    lock mechanism.
    The correct way to fix this is to fix the bugs in the implementation so
    that it works as expected. I think they should possibly ask a varied group
    of users how they would like such a feature to work though first as it
    seems to me that somebody in CADSoft dreamed up this feature without fully
    considering its impacts on end users....
    Rachael
