EAGLE User Support (English) Finding Components on a Schematic Design
  • Replies 9 replies
  • Subscribers 187 subscribers
  • Views 5792 views
Is there a way to find a specific component by typing a reference
designator that will have the schematic editor zoom in on that component
regardless of whether the component is on the current page or on a
different page on of the schematic.  I know that SHOW will highlight the
component, but if it's not on the current page or you've got a dense
schematic it is often difficult to see the highlight.  What I am looking
for is the ability to enter a ref des and have it automatically zoom to
that component no matter which page it is on.
-Michael
    Thanks Warren.
    -Michael
  • Richard_H
    Richard_H over 15 years ago
    Am 23.09.2010 17:47, schrieb Michael Sansom:
    -Michael
    Do you know about the @ option of the SHOW command? SHOW @ IC3
    highlights IC3 and draws a pointer and a rectangle around it.
    In case the component is not on the current sheet a menu appears
    that shows you where you can find it.
    Available since EAGLE 5.5.0
    Richard Hammerl
    "Michael Sansom wrote
    BTW, is it possible to create your own button on the Eagle toolbar?
    I've assigned the find.ulp to be <CTRL> F, which works nicely, but a
    toolbar button is a nice reminder for functions that are less frequently
    used.
    You can customise the Command Text Menu which displays on the right of the
    editor window.
    If it is not displayed you can turn it on with Options/User Interface.
    Essentially, anything you can do from the command bar you can build a button
    to do and cascade other buttons from that button.
    By default Eagle comes with it pretty much duplicating the icons of the
    command button toolbar
    Read up on the Menu command and the section of the manual that illustrates
    the structure of the cascaded menu.
    Many strongly customise these text menus to perform many functions. Most
    often you modify your eagle.scr so that the appropriate customisation occurs
    in the Brd, Sch and Lib editors
    Attached is a script (crafted by the late Syd Levine). Run it and your
    Command Text menu will change and thus you'll see some of the possibilities.
    Clicking "Refresh Eagle.scr" within the menus will run your Eagle.scr and
    get you back to the way you were before running this script.
    Enjoy
    Warren
    begin 666 Analog3.scr
    M365N=2!!9&0@0V]P>2!$96QE=&4@1W)O=7 @+2!,87EE<B!-;W9E(%)E8W0@
    M4F]U=&4@4VEG;F%L(%-P;&ET(%1E>'0@5FEA(%=I<F4@)RTM+2<@)SLG("<M
    M2TG(%P-"D=R:60@7 T)T=R:60@061J=7-T('L@7 TC$P,"!'<FED("T@
    MC Q,"!!;'0@*"XQ,# @5FES:6)L92DZ($=R:60@C$P(#$[($=R:60@06QT
    M("XP,3L@?"!<#0HN,#4P($=R:60@2 N,#$P($%L=" HC$P,"!6:7-I8FQE
    M*3H@1W)I9" N,#4@,CL@1W)I9"!!;'0@+C Q.R!\(%P-"BXP,C4@1W)I9" M
    M("XP,3(U($%L=" H+C$P,"!6:7-I8FQE*3H@1W)I9" N,#(U(#0[($=R:60@
    M06QT("XP,3(U.R!\(%P-"BXP,C @1W)I9" M("XP,3 @06QT("@N,3 P(%9I
    M<VEB;&4I.B!'<FED("XP,B U.R!'<FED($%L=" N,#$[('P@7 T*06QT(%-E
    M='1I;F=S('L@7 T06QT("XQ,# Z($=R:60@06QT("XQ,# [('P@7 T06QT
    M("XP,3 Z($=R:60@06QT("XP,3 [('P@7 T*06QT("XP,#4Z($=R:60@06QT
    M("XP,#4[('P@7 T06QT("XP,C4Z($=R:60@06QT("XP,C4[('P@7 T06QT
    M("XP,3(U.B!'<FED($%L=" N,#$R-3L@?"!<#0I!;'0@+C P,3H@1W)I9"!!
    M;'0@+C P,3L@?"!<#0I!;'0@1FEN97-T.B!'<FED($%L="!&:6YE<W0[("!<
    M#0I]('P@7 T5FES:6)L92!'<FED('L@7 T3VXM3V9F(%1O9V=L93H@1W)I
    M9#L[('P@7 T3&EN97,Z($=R:60@3&EN97,@3VX[('P@7 T1&]T7,@,C8@,C@[('Q<#0IT1&]C=2!4;W @1&]C=2!4;V=G;&4@-3$Z(%)U;B!T
    M;V=L87ES(#4Q.R!\7 T*8D1O8W4@0F]T=&]M($1O8W4@5&]G9VQE(#4R.B!2
    M=6X@=&]G;&%Y<R U,CL@7 T*?2!\(%P-"E)E9G)E<V@@16%G;&4N<V-R.B!3
    I8W)I<'0@96%G;&4[7 T?2<@7 T)RTM+2<@7 T5W)I=&4@7 T.R `
    end
    I've assigned the find.ulp to be  F, which works nicely, but a
    used.
    -Michael
    On 9/23/2010 3:09 PM, Ing. J.M. Rafetseder wrote:
    Attached
    r
    Danke
    -Micahel
    Attached
    r
    >> Thanks
    >> -Michael
    run find
    You know, I thought there was a ULP to do that but it doesn't appear to
    be in the folder that holds the ULPs.  Maybe it got deleted by mistake
    somehow.
    Thanks for the info guys.
    -Scott
    -Michael
    run find
    Did you try "find.ulp"? AFAIK it comes with eagle
    r
