EAGLE User Support (English) Does EagleCAD support more than two layers PCB design?
  • Replies 8 replies
  • Subscribers 184 subscribers
  • Views 2252 views
Former Member over 15 years ago
I have a design that needs to be compact, that is, small in size.  I am
not able to route the traces with just top and bottom layers.  I look to
do a 3-layer PCB.  Does EagleCAD support that?  Is there a tutorial or
example that I can learn from?
Thanks!
    On 7/27/2010 11:39 PM, AL wrote:
    Thanks!
    Just found the below from http://www.olimex.com/pcb/pcb-FAQ.html.  Still
    like to find out how to do it with EagleCAD.
    The Number of Layers - try to route your board with minimum number of
    layers. Some times is more cost effective to place some jumpers on the
    board and to make it single side. Roughly speaking the cost of double
    layer = 2 * cost single layer, cost of 4 layers = 2 * cost double
    layers. The number of layers always come in pairs i.e. 1-2-4-6-8-10-12,
    there are some odd layer stacks as 3 layer board but the price will be
    same as 4 layer board so what do you gain if you make your board with 3
    layers?
    Am 28.07.2010 08:39, schrieb AL:
    Thanks!
    eagle supports 16 layers. You must setup this in the DRC (Design Rule
    Check). Help Design Rules. In the "doc" subdirectory you'll find a
    manual and a tutorial.
    Gruß / regards
    Joern
    AL wrote on Wed, 28 July 2010 02:39
    I look to do a 3-layer PCB.  Does EagleCAD support that?
    Yes, since it can do up to 16 layers.  However, if you're going to use more
    than 2 layers you might as well go to 4.  There won't be any savings in
    specifying only 3.  For most board houses, that probably means etching away
    the fourth layer.
    Former Member over 15 years ago in reply to Former Member
    Does the free version support 16 layers or does one need to purchase the full version to unlock this?
  • Richard_H
    Richard_H over 15 years ago in reply to Former Member
    Freeware and Light Edition support 2 layers.
    Freemium 4 layers (limited to 60 days)
    Standard Edition and Non-profit allow 6 layers
    Professional Edition 16 layers.
    Richard Hammerl
    Former Member over 15 years ago in reply to Richard_H
    Thanks Richard - good to know.
    Thanks for the above info...Ok, I'll stick with two layers, since I love
    the FEE edition so much. image
    AL wrote on Fri, 30 July 2010 20:16
    I'll stick with two layers, since I love the FEE edition so much.
    Actually the fee edition can do 16 layers, it's the free edition that can
    only do 2.
