EAGLE User Support (English) Problem on 0402 package
  • Replies 15 replies
  • Subscribers 180 subscribers
  • Views 2050 views
Former Member over 15 years ago
the company which mounts my boards complains about EAGLE 0402 package.
They say "the pads are too much large" and a lot of components are lost
during the soldering (reflow) due to the "tombstoning" effect.
I'm wondering if anyone ran through this problem, because I'm sure the
EAGLE library is ok.
Anyway, I don't know what tell them. In fact, they ask me a charge for
new components and manual soldering (it means it's my mistake).
Marco
  • icefield
    icefield over 11 years ago in reply to Former Member +1
    The IPC standard for 0402 has been revised because the pads were too large. See for example http://edit.news.cmg.net/pnneditorial/imagepath/101/0000101666_70_79681.pdf (top of page 4). If Eagle used the…
  • Richard_H
    Richard_H over 15 years ago
    Am 02.08.2010 10:53, schrieb Marco Trapanese:
    Marco
    these packages are part of our libraries since several years. We didn't
    have complaints
    concerning the sizes of them. The packages follow the IPC standards, and
    so I think they can't be too wrong.
    just my 2cents
    Richard Hammerl
    Former Member over 15 years ago in reply to Richard_H
    Il 02/08/2010 14.33, Richard Hammerl ha scritto:
    have complaints
    I will bet on this. It's just to talk about, because I think my supplier
    did something wrong and now it complains for everything...
    Marco
    Can it be compared to Cream area, like Cream "hole" not same as pad size.
    In DRC | Masks | Cream, my Cream settings are 0mil, ie not extra area for
    cream
    Maybe could be check with gerber viewer or reading gerber files.
    Also 0402 can come from different libraries, like rcl, and other libraries.
    Is the problem on all 0402 or only some kind of them (resitors only)
    If problem is too less solderpaste on board, maybe the boardhouse has
    ordered too thin a pastemask for production.
    Just my thoughts...
    Christen
    Former Member over 15 years ago in reply to Former Member
    cream
    The same applies here.
    For all components (resistors and capacitors).
    If I'm not wrong they told me there was too much solderpaste so the
    components moved from their position.
    Marco
    What can too much paste do?
    1) Spread to other pads?
    2) ??
    The solder should hold the components in place, if they get into contact
    with each others. The surface tension will pull components into center
    I have had same problem (tombstone) in my home office (50$ oven in the
    garden), as some resistors only soldered on one end, leaving the other end
    up in the air.
    Here my solder paste might have dried out a bit before mounting components,
    so they did not get into contact, or I simply did not press them firmly
    enough onto the board (into the solderpaste).
    PS: I have not worked with 0402, smallest are 0805, as I do my own
    prototypes, and I am getting older...
    I would check my pad size, and ask what size the company request. Too-much
    is not that precise specification image
    I just recall the 0402 pads were too large for the comoactness U
    required, so I did my own. Could it be that they are meant for wave
    soldering? Google for tombstoning and you will find out why this happens
    on very light components. Pad size and position IS critical.
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:1232800121302465937.313441mleikvol-yahoo.nospam@news.cadsoft.de...
    Sorry for typo. Sloppy Iphone typing... First line should be:
    "I just recall the 0402 pads were too large for the compactness I"
    Marco Trapanese: worte
    Marco
    "Richard Hammerl"  replied
    have complaints
    so I think they can't be too wrong.............
    The libraries only control the pad dimensions.
    I suspect DRC settings could cause one-off problems with the standard
    footprints.
    Verify with a gerber viewer what the Board house and assembler see.
    SolderStop that is to distant from the pad does not prevent solder from
    running away from the pad along the attaching trace, enabling the leverage
    for tombstoning.
    A Cream setting that covers the entire pad may be to much for the standard
    libraries 0402s.
    Perhaps the PCB has  a mix of massive componants and 0402s, the Cream
    stencil thickness may have been choosen to satisfy massive parts and so
    excessive cream is being applied.
    Perhaps the positioning file has an offset error that is manifesting itself
    when the tiny 0402 are placed (offset so one end of the chip wins the
    surface tension tug of war.)
    A quick Google found
    http://www.xs4all.nl/~tersted/PDF_files/Plexus/tombstoning.pdf
    Most of the findings are assembler issues.
    Another 2 cents worth
    Warren
    Yes. And I remember that in a german mailing list the IPC pad size
    suggestions have been discussed contrarily - obviously they tend to be
    too large in many cases for whatever reason, even when specified for
    reflow soldering.
    The probability of tombstoning rises significantly if the pads extent
    too much beyond the part - the melting paste pulls the part up. The pads
    should be more "under" the part's contact than "besides" it.
    Tilmann
  • Richard_H
    Richard_H over 15 years ago in reply to Former Member
    Am 03.08.2010 08:24, schrieb Tilmann Reh:
    reflow soldering.
    As far as I remember there was a change for the 0805 package in the
    past. The
    reason was that the original pad sizes did not allow to lay, I believe,
    a 0.3mm track
    between the two SMDs.
    Richard Hammerl
