EAGLE User Support (English) In schematic, how to change the name of a net with a script
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 2004 views
For example: In schematic, I have one pattern group containing a led driver
and a bus named "MOTIF_1_[0..15]".
I have duplicated this bloc 60 times, but now, I have to rename each new bus
with a different name: "MOTIF_2 until MOTIF_60".
Now I do that manually net by net, but it take a long time.
How could I rename a net with a command script?
    e14 Contributor over 15 years ago in reply to kcadsoft
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> a écrit dans le message de news:
    i9had7$npl$1@cheetah.cadsoft.de...
    >> i9h5do$25k$1@cheetah.cadsoft.de...
    >>>> i9gv2c$2so$1@cheetah.cadsoft.de...
    >>>>> On 10/18/10 09:04, Morten Leikvoll wrote:
    >>>>>> "Christian Bohrer" <cbo@tele2.fr> wrote in message
    >>>>>> news:i9floc$go$1@cheetah.cadsoft.de...
    >>>>>>> driver and a bus named "MOTIF_1_[0..15]".
    >>>>>>> bus with a different name: "MOTIF_2 until MOTIF_60".
    >>>>>> You can, by using the NAME command. However, the name command has a lot of
    >>>>>> potential popup requesters coming up that can't be handled with scripts. If
    >>>>>> you try to rename a net to an existing net name, it will ask if you want to
    >>>>>> merge with existing or not. Also, if the net is present on several pages,
    >>>>>> you will get an option to rename 'current' net or all nets with the same
    >>>>>> name. So you may end up with a lot of requesters to answer. I have suggested
    >>>>>> optional command line keywords to get rid of those requesters and I'm exited
    >>>>>> to see what Eagle 6 will do.
    >>>>> Version 5.10.1 introduced
    >>>>>  - The new SET parameters Cmd.Name.RenameEntireNetByDefault and
    >>>>>    Cmd.Name.RenameEntireSignalByDefault can be used to control the default
    >>>>>    behavior of the NAME command.
    >>>>>  - The new SET variable CONFIRM can be used to automatically confirm message
    >>>>>    dialogs (see "Help/Editor Commands/SET/Automatic Confirmation").
    >>>> Version 5.10.2
    >>>> I've just tried the automatic confirmation SET CONFIRM
    >>>> and I don't see any difference between YES, NO or OFF
    >>>> When I type this string in the command line:
    >>>> name 'v39_0' (7200 9700);
    >>>> (coords of the label 'V21_0')
    >>>> the confirm dialog is always presented.
    >>> Did you read the section on "Automatic Confirmation" in the online help
    >>> of the SET command?
    >>> Especially the sentence
    >>>  "If automatic confirmation is not turned off explicitly, it will
    >>>   automatically fall back to OFF the next time the editor window
    >>>   accepts some interactive input from the user."
    >>> So if you interactively enter
    >>>  SET CONFIRM ...
    >>> it has no effect, since it immediately falls back to "OFF" when the
    >>> editor accepts the next comand from the command line.
    >>> This option is intended mostly for use with scripts.
    >> I have also tried the script below:
    >> SET CONFIRM YES;
    >> NAME 'v39_0' (7100 9700);
    >> SET CONFIRM OFF;
    >> SET CONFIRM YES;
    >> NAME 'v39_1' (7100 9600);
    >> SET CONFIRM OFF;
    >> SET CONFIRM YES;
    >> NAME 'v39_2' (7100 9500);
    >> SET CONFIRM OFF;
    >> But the dialog is still presented 3 time.
    >> What I'm doing wrong, how do I write my script?
    Looks like the handling of the SET CONFIRM variable was missing
    in the NAME dialog.
    Fixed for version 5.10.3.
    Klaus Schmidinger
    Christian Bohrer
  • kcadsoft
    kcadsoft over 15 years ago in reply to e14 Contributor
    >>> Version 5.10.2
    >> of the SET command?
    >>  SET CONFIRM ...
    SET CONFIRM YES;
    SET CONFIRM OFF;
    SET CONFIRM YES;
    SET CONFIRM OFF;
    SET CONFIRM YES;
    SET CONFIRM OFF;
    in the NAME dialog.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    >> Version 5.10.2
    of the SET command?
    SET CONFIRM ...
    SET CONFIRM YES;
    SET CONFIRM OFF;
    SET CONFIRM YES;
    SET CONFIRM OFF;
    SET CONFIRM YES;
    SET CONFIRM OFF;
  • kcadsoft
    Version 5.10.2
    of the SET command?
      SET CONFIRM ...
    Klaus Schmidinger
    Version 5.10.2
    (see the screen capture below)
    MB5!.1PT&@H````-24A$4@```A ```(+" (````V<S&```@`$E$051XG.V]
    M>[P>57WO_YV99^=$)%;)&$3) $L5Q6"0:,%15OE--N>E'H\QWU4(K6MMK+
    M&K476O1G:+ULY>CQ5[6E*-;N_JJ(J49/;86JH$'#Y42$H"3<0G8(4M@))'OO
    MYSK]\?L/4SFLIXU:V;6?-<\G_<KWCV/+/6LX\:[Z?:ZK(X0@````H!]N
    MW08```"P`P@&````)2 8````E(!@````4 *"`0``0 D(!@```"4@& ```)1H
    MU6T``* T)B<G@P_CX^,EI@V_"E',/YE0S[:R2C%CCX3 @+XEIMJ9),S'V'5!
    M, !H().3D[G\19:'DA^7%"%Q>8I.LUPXV*,H`YQ!DQ0`S:&XUXOFT-?!34Y.
    MIIZCXAE->D\.]JCGSUE7$&$``%*(N:V8%/5]8==(6!P5O31I3\%2U.4_E\P7
    M`1$&`(U"WJZ=BKSG8WQ\/'E<Q4-E)=2PL C14O0NI$0#; >"`0"(H^+CU'N5
    MF9#UPEY=[T56DYV]0# `:"S%V^ZUG:D\H>$>[UJ0-\WU3<7S%L4%8VQL3",7
    MYJF8FZ>7BKEY>JF8FZ>7RKQY>7W-Q,1$+-7X`E68%T5%THJ4I>A_@V\G)B8T
    M`H^YJ7>24NKGX/], !H'NHOJMJOMD)#92;*ZM:[(EFF/?FQ,[1F %3:8R"
    M45(`-!GYA R]%O:&M<M71$%_K3T#IE+0AP% `\GK4%3.GUR@2$%A5AJI0$A=
    M-Q 1!@"@/^J+501GYIUJ#DBAGSQZ0BUW&!$&`,VD[W2'4AJ[Y3/XDM\V;Z1I
    M%62-.)"/1# `(@P`0'\D;[NQ5]TPR(B=%LL-LI%$8]R!8?U A % \TE]TR^8
    MIV2.-"9A5$J--Q""`4!CT5A;J:S\^ZX+`FP$35(`@*J /#0,1!@`# 1]^Q5,
    MPGP!#) %! . YI!W8G#6MZE3+A0-8#4.2G%E7"8"QNWN)8%@`# HA#,D\B;1
    MQ941(WR!L$`H.%H+.NM/5%<Y8V+G_7=SY[1C>40#" 8`0$;6)JQ]G1J3
    M67OR9DVRO52-_;7HNU&"4%P "A[J^C<^MR[9FAF+ N[ZS7(B??+:K$:U&_
    M[;6 " . YB/?FE0]E>(Y?1,:5HNJYZ.4B\K=J\M:1!@`@$RR=F6@?GY->SN'
    MBM"D%K@=O>>01S.NG7K1'Z8IV)NGEXJYN;II6)NGEZJB@KZQS3..^\U..E
    M6\CJGJ=>INT7I9TJ=C?*+0@[[@'0' 9S47$FLRB84.G=0!\&````)2 8````
    ME$"G-P"@3HH,'HVUNK"=5%$UQ@;@(L(```"@! 0#``" $A@E!4!S&,Q14L 8
    M$ P```!H$D``" $A ,````2D P````* '!````H 0$`P``@!(0# ```$I
    M, ```"@!P0```* $! ,``( 2<<$8&QO3R(5YN;FZ:5B;IY>N;FZ:5B;IY>
    M*N;FZ:5B;IY>JG(+PM(@````E$"3% ```"4@& ```)2 8 ```% "@@$``$ )
    M" 8````E(!@```"4@& ```!0`H(!``! B5:YV4U.3@8?%'>B5SD_/"<D;^8:
    M:0$``,0H63#)=7CA\=S:8QZ6@```GP%0R)TX^>D'3]?1,&YT S0),8NW1S
    MW28`UFRY87WQ3)@1LSIQYQ[WP!"(R$`]@U`'T9NW1S<<W@WND]/CZ># 6B
    M1[(T("MA>!#B`9H!U (H4KRJ<!0,%5>>VJ $#0"#!M0"Y*)@A>$H&"':W0SR
    MA.B]````#3ANH#2^0%EE92611R0<;@6'@DRF8FZ>7BJ3YFW;NLE,*F,%F4S%
    MW#R]5'H%&=I J8IY&.H)U7/3+A<`5J!)"N2E2-<WTU%2$M!1`0``M6"-8)0X
    M;1N2`QK#EAO6(\@`QF#=Z1VBZ.(Q9!8,(*5,R ) !3L$(POY#+[DMZD'`; =
    M: 8P@QU-4IU/V*?(R/CT<E(:LA"[(!&@8T`P14VD1I:X0AF>R-21@``% %
    MM@H&25U_WW5!````Y,6.)BD]( \``% B%D<8VF#6'@``:%!GA"'?'XE*FOX-
    M``"@%$J.,/1F0F3Y=WDF&.D$```FJ;!)2MO=YXT/PO-5Y I1" ``Z%&^8*CL
    M;A0]G?<J3FHS_#K#T``"B7DE>K#3#0'B5)KKW_$@``V$[?B7M%YGA6TB2E
    MZ(IV]"J 4``&A02801I?@JL]HY)!-"*@``S:;2"(/$X:Q;MT[D
    MAWDJYN;II6)NGEXJYN;II6)NGEXJYN;II6)NGFJ=;_SC>B_XY>?'SM2I#*
    M(PP```#&L*\/`P``0/. 8 ```% "@@$``$ )" 8````E(!@```"4@& ```!0
    M`H(!``! "0@&````)2 8````E(!@````4 *"`0``0 D(!@```"4@& ```)1H
    ME9+UD<$H#I.6E]@?7\`@#)%!0-2`6HGK(10#@`J!4U2````E(@QMC8
    MF'KB\,UNPZ9-&F4;2\7</U4S,W32V72O%Q5O4@J8P693,7</U4S,W32[5M
    M:YE/1Z$=]] >!5B!)BD`L.,>``" ^BEGE%0(7O& ,1#@`F 81!@```"4@& `
    M``!0`H(!``! "0@&````)4KN] :@&4Q.3L:.C(^/EYX$`+N 8 !P&$F_'SV>
    MJ@$:20"P$31)`? ,6:Y?<H)&$@`L!1$&`.E$(P-%IZ^1! "+0(0!P#RABQ\?
    M'X^U(V4I@482`.P%@@& $AI=$>B]``T#35(`S -)`$ .(@P```!*0# ````H
    M`<$`0(EH_W9U20#@3$=]TPY9GY5,S-TTO%MOJ%KE]]O)-&DBB-_*68IV)N
    MGEXJUCON83\,8 QCU2_J\15C!8TD`)0"=MP#H#:@%@"$0# `R 1J`4 4" 8`
    MZ4 M`(B!B7L`I( Q40`D82$8J<-()$^=QDIP63D,R+-M_@X7MZ%&H!8`I%*S
    M8$@<4_&]!+ ;`?&XPY7:4#I0"P"RJ+,/0^4UMO@RGX.\4&CM=WAR<E+1!B8_
    M$]0"``DLFJ0H\;"5V.@4?,;#;/X.]]VR-'8"JY])?G]R[;LG20* 7=0684@V
    M$J R]A(9<OD!=8DK.YPE@VLWC&?1C >@4&&;[#:DMQ):S\$3<JO</J`TP'
    M7-<!L @N35*IP-U7C8$[K%+$/@X!ZG ?A@`R.$;891%$AS<$F-)'F'B]QJ
    M_$P`L4VP8AZ&?B(N!PA]5?P/&J#@!_ZFR2BC9$8$V%*L =!@"42"NY1K1)
    M4ANO,;"]1 ;J#M=;F5/9</_\;@2ER^OUQ(P(&Q;]:C\A'):[0SCS=)Z>U%
    M4V0'F_$%DB>DMJ5H;"$R,3&A;1[;5.I)HG<X=BL46ZOT+DKCMNO]4B8KK4:J
    M[=?LU"AHV\0VSJF8FZ>7BKEY>JFF-Y=9_9R'O_$-C>RR*&L'FY@7RYKPE7<-
    MT63W;,->L=6I] 3X2QYGS]JM@JXN*K>V)C?H?5
    M'.!FT,@[S'##QQN)G4F@V8Q=WV_'O4_:MN/>Y +RTQK@PNJ"R1W6V $;`,"6
    MYL_#0.M3U23O<)%;C9\)`;4!AXKZR:VN^PF15S`0`&J$<P%)</*G'E[4%[
    M;ZW]#JNO$(4)(@#8`HLFJ52'4M"/8 )YE%KN<$PS4J>#X#<"P")JF^D=FU"F
    MYSB;^K08#C<X5PV#.;/!(!%U!EA*YC6M"/#+(;XG"'S=@``#! S<N;QV8#
    M)+\JF#/@<(>KLP$`8!)'"&=.#EQC^',=!44/T`2#)V:;^)>S?8-G$/``"
    M=4 P````* '!````H 0$`P``@!(0# ```$I , ```"@1%PR]O=6*[+AG(!7S
    MO?/T4C$W3R\5JI\MJ9B;IY>*N7EZJ;9M+?/IP#P,8"NH?@`DP3P,````]0/!
    M````H(2)M:2\(\?>*KWM(&"0)/8.:_J=L$`,!A5"L8$U]^QS$C1S_O>2<M
    M&AX:7G3D\)!1$.M(X8\MS6RF(@6WH6$3E$1.1XF>&.Z/F5VJF.Q$C#L+TG
    MHN<(H<H_&\6,[/QUXB90P>)Z.#,TW.S3UWSU3;GIV&; # APH%8+[SCE
    MA)../NI9G6YG\? 0$;4[_O"0VD>$OYPN],>'AJ>[?7"\X7G!1<R$' G$ZW
    M'7P8:@V'?W86Q&S(<]N==O1\QVT)OQOV?4/[;=>48%S_RUYSYY\-B)+[\#
    MF@$`$ZH2C(DOOV/%TF6'GIX9'G:)Z#_W[Z?]^XEH:&C(<YU6JS72&IIMS[9:
    MPT34<MW9]NRBX45$%!P,CA#1HN%%P2MJS^?R0LV$GL]"5CW7Z_D]X?=:K>%N
    M]QGO+P3Y1$((WQ>0[[O.ZXK?)(7-<E(M_W17?^$GPBE\AI>7-S[2!:<3V/
    MB&8.S1Z]Z&AH!@!,J$HP%CE]C]Y\*AG'_'T@9G@R/"BENLZ1-0A&O%7+M#
    M1#U_CHCFB(CHX.S\F;WVW!Q1SQ>NZSR]<-#W]8?_@BKI!/]K=V?G/W1\(A)"
    MD.AVNT1$/O7$X7OZA=,C;[PDBZO5\(NI&?NA>MS<SUWGLT;E+P``H$@E
    M@O'Q:][M#G>'Z%G=[KR?:+7<]FQW>%%KWH4LT"%JM;SPSVXW_:V93W#A'VX_
    MH,-=?$ @#[[?2J!)%5OX=>?F>N$!V?FYI8>N0]5[[QTQ_^2KEF`P#R4HE@
    M/'Y@_])G']49$7/M[LAPGR*2(M'M=EW7]1?:H +/(OB(!H@0Q@JNZQVQ>'3=
    M19<?FO6/6%1H:,"W?WCM_0_MZ/;\3K<S,]-NSW3ZIP$`5(^Y+5J=EB/Y-H@\
    M`IWP?>'[S[R.LI(*GT?/`2TTYO#!]WOK+KI\YI$''OO6%WL'IGLS!T5[SN^T
    MB<CO=AS7I=Z\W_<7!C7XG86VIDZWUYGKMF=GCCCV[#_]SJK_Z2^\OG&]
    MUFSGT'1B/!4`P#Q5"88[W!4TDG2N"Y+@^[[?:K6((PDPJ@B15\W#1(XO>$
    MZSF!@/WJV_\P\IP3G>4G]PX=Z#Y]P&_/$1%U.\+W1:]1,W@]]5! >[;2+R
    MVVUO;L:=>?K0_OTW_N7;QK[X@Y;G=GM^JS4TUT8'!@!O[B(T:FGZSCJ@``"<PU28%!H#?S=.I`[0D&C/^G,SHM,F(M'I
    M)VVWT0D=/MJ)'1'ZG0T($$8;H=8. @SS7;7%Y.0``Q# G&'>]B]43GOA
    M]W06XP5,$)UV[] !W_5Z,P?%W.RJ/YX@HE]^Z HVPD$P_.B4Z'B$2O33W_
    MG,_]Q'][ ]?2;[PB5S7=;RA>B\!`)!%A8Q>&2(B-R6Z[0<K^41T97].FH_
    M[#B_\QM7?.W?/A(><P41W?_(G;??_>WD<2ZVG<-R0R?QC$^]*3];M=
    M?80>:[HM .U(*)?]#?WOLG;_2[<T0D.FW1ZQ"1Z':>__E_#TYXP1=N^ME;
    MR_F85$AD>&B*AS:(Z(%@U!0@!@`9>5D518<?Q9TT
    D?K5YS[ZUX:-`;DX
    MXZ/Q612A6@``*N+?K]H0_"LKPVIWW&NYCNLYT;?R#SM.\"_X7_BG2BG#PR.O
    MO?C=&N:!2O$\S_.\8 E)OS/G=]JBW1:=[LZKWAD][:R)KXE>SQ$^^;US/ON=
    MZ%<_>\M:T>LYP7HBB3!TMM-G'@9VW#.?BKEY>JF8FY<W5: 3W;<?++&@N&!L
    MV;)%(_<O77%%WB3B2B&N%303A5E^?5IRY_2=ZR@$G\]EQO;L[O=42O=]]?
    M7![]ZNRK;_#]WCE_\]WHP>V772"Z7?*[0O0<(5PG]P03C>I'NE5=(Y6Q@DRF
    M8FZ>7BKFYN5%485K<\M;$@TZ.D<LE#*N><>>'M]WSGZ&./3?UV_:O>/]0:
    M"3[/SAV<M4OPVZ/__::*P[-['_ZT)/'';/"<UN=[MR3_</?/DZ'-;='(
    MDI[?G3[PZ$T_^5(TM_//7K?\N%..6'Q4D-N!IW_U@]NP0(4,?VY&M.<<KT6"
    MA.3(W[YEV_YM?_GB$)L=CBKLLO<#T2HD<.!4L2$E:9!* 8L3:HW_SS+Y65
    M<X5]&.YPBXB"UJ:6.]_H%&N2"HXD;/):KM-RG:'$Y/#=N^^3-TS-SCTS)7C1
    MR))35IRW^HQUX9$C%A]U_'$K/;=%1$.MD>./6WG*BO,6C2PA(L]M'7?TB@O.
    MOC0\^3=?ONGK#@O4(L@M./6[GN(K2)Y>;>/W]3ZO&[?F]M5I)@A;&AQ2.$
    M3F\`\E"=6I"!3NL845!D]258OY?]*NAX2%O(4J(:<9E;SZWVU(&J;^]9;/
    M??ACKWOEQ4N^M7/!$>>M6CIXX_MBYYSTTU?"[\EHJ]]3/AGR<<?^HC#SU(
    M1"]P>\<?>0R(MJ][Y77KSDE1<OV;7KB(Z8O&SSSMM'8$,1<K.G.BVQ&]
    M+I$0OA"<(38\<'7Q\Z\VT7.JYPR'?(=QSAB"Z)GB-Z883A8$(&`#E9-K4L
    M^F>Y:D&5S_0>]NAPIZ_>).6V6GZO1T+$-&/W8W>O&CWWG#,OO/.7_R=ZW!MR
    MB>B\,WYKW<O_Z,H/'A4>7[;LI*F''UIVX@GAD4T?V? __N"MX9^?_]R?7O;N
    M=P6?AX='[KK]MI-/.V79<2N#(]=?_]FU_W6V:O/V_[0MTX]]?E$=,R4[_S
    M_8=7K%JI>"&#0*_C>ZY'1'ZGW>MV6JXG'-<5PG>)B(2@,S_VU5B2LS]_\SU_
    MN%;,3F?7]Z6?$&1[96&':%(\.$6$`T)JU8(J%8Q%(Y[G>H$?=[V4MT7Y
    MX"B'/-=[9J&ZD.WW?N?8(T
    ZLCGQ%J'7*)SS_BME:/G)K/ZT?=N/'_M81')
    M\<L.N[-''?6,P#SXR_M<HI'A^9ZB][[WT['<EBQY]LX=.R 848)?.8O3KTKO
    M^#GK"UOO_KWS4[]R7,?S1:_E4:>'U6H!Z(L!M2 #G=XND>ME;H1]I1#SO1Q"
    MT(*$# VY1,&>.UXR'G$\[_MW7ON97^\?-G)L>,G'U>\/FFF[ZVZ2,;;OJ/
    M@]%O8R>K_QFCW9[[^>UWO.JU.J/B&H_?;8OVG.]ZCN?YPA$D3O_(==$3[GW_
    M:\_XQ+?"/\_^]OO?T7.:X0ON\(03W?$3TB&AKV.CU!G9[C$B(,`.2840LR
    M-DIUAX=-%)%HXU@C4+A"JAX?E]/4."[M"IQW<\=_D+8L?#L&#31S:\Z9UO
    M3Z92_[/3G0M&6UU]]7N^]<UK8B:?<L;IK;I;V)FM;KY KR.Z;;_CN<X(D7/Z
    MIB]'O[SW3RXE(>Y][ZO/N/K?PH-G_=UM.][R?$$^]7K4[5*W2T3#(RV:ZQ+-
    MUAIDLG)R;[GC(^/&[ $`!6,J0551C>D.MZGK?@6Y-M4*FM4BW'Z0KA.(Y#
    M)(1PW,/BDV"QV[L?-]K.6QHX'O/%-'USWRO93*7YX&#XX[ZKE$
    MM&'#%9?\UTL?W'<[$:T]YPT__OD_R2_9&*;]J!INVWV^2VB-PS/_[_1;_Z
    MQ0=QUG0N9AFG/G%NYYX_.HUQ6]GECHPP@T8PZK`P.034PM]HWN&Z/-U157
    MH6 ,C0P14: 6KNN[-:K?_,E[U5)Z'D>A5T7CB,.?YD.1C^Y.Y_N/A%[VHM
    MK%77<IV#,T\N67P,$5U^5]&DUQUU=>>=G1FDG6GW?<_5??%;%R\Z\IAC
    MGG/,,2\_\Y27!U]=</KK[[SO:RI7`:+L^,#K8LV2OWCWRT__S ^RSA]JM7J]
    MWO!(BX@6QZNVKFL'KUZN##'7?<46+:\*LH>8L(,M$P3*.4&%476A=)M:BZ
    MQ"HCC)[O>O-;7SB.0T0W;9L?O3K<RFR5#G;%:+E>)]BLS2'G\)?IZ)_[_O/>
    M$X]_?GA\Z\^NN"L-S[[R*7M]MS.G=N)Z337C@\/$)$4P_OIA>G9YUYXV
    M__V8]8N>\XIQQSS'")JM^?V[7OX9]MOV35UUUDO/PUK!YXA!A""")R'"?X
    MX'?F_E9Q_.BS8@[WG\ID?!%EXBHUR/1(RR>_>^_8(S/O?3A7QZHMPN= +4)W%WP(@PC/=7N3PL#JX9<CXANON-OKGS?X,3
    M1H:>>=\_Y&;?WKG#?_[HQ\/CV_[ZL__OX/OONM:>?==;YWGQCV^GVV_]
    MR2_NN>>M[WY7!/YG\&'7SU]^QUWW_#>W;
    'LW$M'I9YUU^MEGG7SJ*5$;
    MZFNVZ[;!"(B9Z%1,?@@_)[HSO;:KB?$/>]Y+<T/:/ =$O,;(J.XP?+FW?(
    M[YXR_.)2'1F1<G;E?XO4!XO);7Z_9<Q_&Y**,=W''''05=<]2KJF2EHDSU
    MJD7TG,9H1BUJ029&22V$%P'!RWM,+2@A&T3D'3[C[\.?_$1J_DN?\YS85R]]
    MQ<M?HJ7AW>?O9969G(_PPXZ>233SKYY%?]ETM22Z^1D5;]HA42JE>GW18S
    M,QZY/5XG9;C.40D>CURR*$>$9'HNGZ7B$2O[?0ZHMLA(NIV_4ZWVUUNWZG
    M.Q^<!(V9?J_7Z6)8;0W$7'#,U4:_E3MB`VH10V)J,ZA+<C,\N9"B.["?VA
    M5HNR1_@$LN&Y-BVZ#FA!O0[-^K//7G;@Z4-/3A\X<.# ]/[]3SZY_\DG]T]/
    M']B__\#T]('IZ0/[IY\^\-2A`T\=.O#4S(&GYO8?;.\_V#YPJ//43/>I6?]
    M6[26K2#4@0*$[E+=4<I[/NZXXX[D\=A!C1:M$HF6DFJJ87LJI4:U( ,1AN_[
    MP1BD8)N=-I%#SE"K)1D5VL/R<[811!A''*?_Z&_N_%/]_;]0JT6.XR^$
    MCE[8<B5ZKN@1D2-\E\3\YDN[PJ_XPM:>N)_53_4:UF2(ZOM;UC0QW%SG-)
    M"U@MKCGVN(M=4RH5RW(S#R,=KO3:GGDN$34%<(C$B3"?N8@YB"B=EK0\OU
    MBCK<QE<V6-C"4/N>>A'9YWLO]QPS;M' [-D<L<N]YZ$<]W^]U>[W$//]
    MB?9XI\[&F)R<M$LSZNI@2#9G-<-?UTOM:D%)P1@;&]-8J'W#IDVI>Q+,')IU
    MB%S7:U-G:,@-IGSW6IX_OX(0N:X3ME"W6BV1<!!S?B]HP!(\9JHY:GL]&4 4
    M7BB+((A4CVB!Z=<O\C6UW7#6;;^;X01((HG'X1O7?==L<G<HE:PT-B(:SL
    M=0^K`)[G)=>&29)5_>1(JKID[IY&QZG>,U4D55X'O6O7KE-//35Z77VO4=&\
    M6#Z[=NU2MTJQKQ@)8JO">27]#\+Z5?J 6TV>/OK+1U,>M=BV==.:M:4]
    M'4X1O[-[<WR&R$GKUQ/1!SYUV?%EZQ<L6N8/N)Z8/#GN<L+ XR-+0P;FIA
    MZH/GN6[D<D!%Q?-BVZ7A6 X1$[\=.,:?<238LB\6LNZ$FT'O:(/*(>46O(
    M6[)D*'['[W[OH>OUB\LF55/VVB.I&,).3?<D-]0D:1J1M9R9/#6 N6DM>
    M@F=R(U=L,79IGXE[6V[0?TPJ;Y(:]CS?FP[_[&' "U @""M:0\M-%BJ7@6@[
    ME45M4Y4.8<I*;IU'Y@R'EJB0R@7C=;_QEJJ+`$WE@2>_3N8?J-B,DJV#
    M(7E;I0JZ>"A$1;!2"S(SK!8`T#SL;>&Q!6YJ01 ,`)I*WPD9I2P\!2J"H5H0
    M! ,`D!?Y1#E0')YJ0<;VPP" /XU9>3!)LNM;.T2 6E0-6[4@1!@`),GJV;9.
    M450<NO:BME"+N"L%@3!`" D@-)S;!E?%1%K%Z]&FI1-<S5@M D!4 660IA
    M2W@1(]HJE;<]"E)A`/YJ08@P`(C25PR8JT52"?JN'I@K3X9JH:B"S <!6Z$6
    MA @#@!B!)#1RJ=H@R,@57C!7BV9@BUH0! . 5!H@#R%9(I%K(5LKU")K'13.
    MLT8L4@M"DQ0`()5H&PYSM9!OD<19]NQ2"T*$`<! H?&NK9B$CR_F'$]$L4XM
    M"!$&`(. ?./2)+;XW)#29YQ4C8UJ042MY*8"AEFZ[ PB>GS?O>&?X6<`<J%>
    MF9=>=56EEH3\YL3VX,-]SSO&0'%/7/U$S!-%OXK^F75:ZLDJ*&8H/ZT06XB(
    MGK@OQ?)CGW=LM447HSJUV+9J4_!AS0.Y]U!*)1YA;-BT22,7O50`E()>];OT
    MOOO,IKG3[H:!4V_>5I^PA/W/9'\U_N37NIQ(CKV><=&_\GBIV<_.=^Q)5D
    MF"1,E?].]\5J99':RBH)2Y5*L;$Q]9,#M9C>O#.78?"XGT8&EM=:J<
    M>7S?O<G (H@\:"'X"$](?HB=3X?'BB5_UN>-[SS0ZZZ,Z
    M/87!3IP24OW@$Q]]0MT_JI=52A+^J<R;ES>V4-_5-8PMCEY_6JXBY 6UBNQJ
    M65US5M19JSON9)*L(S'5T2L.<"-'92ZVF:LZMY@I9H'58[FW' ?-(U2@+:
    MHXC/*EDD!&-&('4\.1%(S43P3L@$`L([JU(X"$:2XOXZ%C=471P`0(,B
    M([(03LDI5RV(U;#:L%\A1MC9$&U6JJ[A*+1!/3H!```.C$T^TUE=NEH0VP@C
    MA[:PI"E0!45!P``-5U6A 'P8@ZZS/VM_&3DL>SSHS]0@`H'30K%0!M2"
    M6#5)`0`*`N<[F)A1"(080# DT:N< Z:1U0MMHQO&;NPL4[$&$`D$+J=GN3
    MDY,#OE$KX$9,:HN#A$&`(?15Q(F)R?9AAJA\1H62M*FWI.\1029FQUYH]-
    M,( ``" `241!5$LTC&&U( @&`!BOL:NV"OJF5=G>2J<[EC\W?/KM]+`_-J
    M06B2`B!U,O$7$5XE'\;3KO999U3KFP_8'HA:U($08`22ZGG'Q\<;[XE"
    M8E<:NR'1;^71#-2B=.I2"T$`4 NQA>HVY!,0MO4_::\YR/U>F,'-5JT@)J
    M42GU1QC_^G__J6X30#U<<NX;ZC;A,(KT&#<,Q5LA";D@%550KUH0!\$@HO_Y
    MZ@_5;0(PS3_^VX?J-J$_\F89_JAT?5?A9Y/WK6IO;KY$\]2N%I1LDLJUHU,(
    M=MP#-:)7_>15/77*Q>3DI,;2JGK/5)%4>85M8F(BEJIORYNB>;%,@H+RDNM6
    MA"5JE&7E\IQ_N08$6V;V$8YU6+;UC*?CGB$H;ZC4Y2".Z%?/:Z]Y:23Y)W
    M779U13F#VM&K?IJ+GDYW;AQ8]X1JWK/E,E4&S=NK@Y%W2$BQK&2)%5U4
    M:G"V&-QC5Y8XLU:\M\.E@T20' $,FX((NH= A35G+S;7?6M1:JPZ$E*@2C
    MI !((75<4/B9OWCD=: %'6Z#_76]L%(LB""%N3P@:KY!&55 `HDN7^&MF5
    MJ@T&E54--[4@_HQKLNNCNK$9Z][;_*(2BHSU@ AU#>LEJE2EEX"E0$0[4@
    M;DU2T:[IX#-\/0#<D"R@`DJ!IUH0-\'(XEV778U `51-@WU?ZA#AXEDU^([5
    M"%NU(&Z"$;0X4:(=Z;/7O3?\*O@0_O-4-!H^,Q>+HB0]=>U!9J406<U8+X
    M]V&DDNS]!J!<DNW`XK;9_T;@7,U8(8"H9BM[;\*P#TB(Z#XC/)H!2B$I@W
    M5!IPL30#?[4@AH(1(VR)HD1@(5&+U%0`J" ?.\O<728#H^*7`[4P@!5J03P%
    M(^;BDQY?10.@$T";P"TF_:SM[C0DUSA!=3"`:H!?$4CPD>S@%J XC?&/
    M62*1:R';QMP-;EBD%M0,P8 \`% ZF,AM`+O4@K@)!D8]`5 I&B.#%9- 5_)B
    MG5H0MWD8`( JD*EF,2Z&2?6$54+BV 185BQ1K@S[-FLV(<Z&^^>WKUF\
    M?F!XJ:FIK)\_=345/1/N23$3E9!,4-C4F21&VJ"RVK9JO?FL>*&?HKA@
    MC(V-:>P'LF'3)NT]EAM[ RL0Z_Z&4NU_9J=WSK:7D+VC:Q;<W&-9(34GWZ
    MKFMWT>4I)X.CHZ.CJJ7)3E9T;RD`4&JT8U]<BY>5L">R3UY4D55#!5+K7(
    MY9\#M9C>O//H];FK7U9!CA B;UXAR1>ZD]:O)Z(/?.JRXY<N6;EBQ=S!]B4O
    MAAX`31YXXOM/[I^[\ZZ==]_W\'4?BU<VAO%$$O,11E]?#_A016PQ=NEFBL06
    M`=$(8\L-Z[4S9]$D!4 I!.\KK+B1C)J4=_M8T$@D:E$0='H#`$!SJ$XM"!$&
    M`!>BG1(YR$1M\5:Y:$"(,``!H!E6K!4$P``"@`1A0"T3% "@7M"L5!PS
    M:D$V"L;7W[GZ=__?.JVHDR_L[51-2PB[(4]?9TGFZ.IU6@4HRI!5DA&($_
    M#3#C56,>O%*):I[^`0",$5.+>-;QJZO<'X2=\& /P5 G2)S$K2ZJV.GII)
    MU3%0:;:0E(MJBZ1M6!DJ448<T2#@.B1U D>3"93_2$9.E9I00G2^Q1,1ZZ
    MR '%2X.Z"\,_BRVN(D;72Y;H6!!9W,M46SL%,1>,)*-17V/1U_X*!C
    M1U3\=58IX9^I945S3OT*4F$_/U.W@WU4G,(/ZMDI:),]:I%]!S.OUTN:E$
    MXB,8CQ]E.BP5:U6G'"">O)H]%!6JF20H5Z*GCT!CS=JYW6!AS'$2<NS_'C
    M,H'_HJ?E$KO>FN-?BMWQ.;50MM46ZA++8B)8#RR=Z_K#HTN6ZJ7/!D])+K
    MU3Y746"AEQ:2-['WO\D;U[[;I,B[:?"X,,=><HOSK)P3!A5EF&5;:(J;90
    MHUH0AXE[>QY]U'6]5+4(P:J)JN4X@:8L=\N3CAJ><-[WGTT;H-`9DH"J0\
    ML#"C%L5-M8AZU8(X1!A"T(GC\_Z-N:R4]_<5=QZ\ISH$<4.#$7O\DY;Z%-
    MY83CC]OSJ#4M;Q:%%S'JZF!(MA$-6H->%=2N%L1A`Z58UT62I,]-?LYU3E^7
    MG9I<4HKD0Z[+&2@*[,,21Z_ZY:WJ@>?5>$#TGJDBJ?(ZZ(F)B8T;-T:EI:_,
    M)H7RV=B8D)#=.5E965HQ25X_S),=+:=FG;UDUKUI;V=,0%0/B:B 6I@#
    MK_9-1:_Z*5;UF.?5>$#TGBF3J39NW%A%04E7KE&08EFEI&+[2X6QA<8F?1IJ
    M0=GFU=\D90SH!!A *AW"E)6<8=N=O6UB'%JB0NKO] : +?;V7N0UN. %6G1_
    M+#5FD%03 ``'I8I*86F1J%FUH0! . "SU,B&AV7V7_2BR\!1_#(U"D.U
    M( @&`" O41?,7$TM,C4*3[4@" 8`@T#R+5O[O=LB%VR1J5'8J@5!, !H,"I>
    M4GM16^8NV")3HW!6"QJH8;4`J&-[!T;IR!?X8X5%IL9@KA8$P0!@0(A.R,C;
    M'F71V[I%IL;@KQ:$)BD`FD12"8HOR6>1"[;(U!A6J 5!, `8',)ES_,F"6#N
    M@BTR-88M:D%HD@(@%;L\CIRLM0AS63_(989&H,B]2"(!@`@%0LZO:WR-08
    M=JD%V248CTW/W+KCT>_>_O!MO]CWHM.7O>;\Y[[DS.7''[VX;KL`L :-Z1>*
    M23@X:XM,)0O5@FSIP_!]\<.[IM;]3=OW?'XZRX\YWN?>--_O_B%VZ;7O?G
    MW_SA75.^7][6"@`TD:2E#M-BY;3L,C4*#:J!1&U=F_>7<-_;GE[KW__/W[
    M/_K[K_SU<Y[KNJ[G>1>]8-7%YYWV6R\YXY]ONHN(+GK^:-],EBX[X_%]]U9O
    M*@-AI5YP_V;@@^ER\W4-S4U%26`YV:FHK^*?>SL9-54,RP=/]>NJGFJ4XM
    MMJV:KWYK'BAGRZ)XA%ATR:-7/12*?8],S[/G_SI1>>'JJ%ZWK!?U]Q[BGC
    MOW'N^SY_\V/3,ZEIERX[0Y*S_-O@A/"?_@4H8Z:4YF&RTFJDVG[-3HV"MDUL
    MDY\PE<:N:W>E'B>BT<.1ES7:CSV3>R09)@E3Y;\3?6Z%NH5]3>U[SZM(E4LM
    MQL;&^I\4%K%J$Q%-;]:I?ED%.0]_XQL:V65QTOKU1/2!3UUV_-(E*U>LF#O8
    MON3%;Y G>63OWA4GG" YX9M;'[AUQ-7OODBUW4[3F?KT[=9?=7?O>XUUVR
    MXI(C1XYT7>^#7_@_YZX\XK?7KDJFC485>2,,\Q')0,5 ?7]W(GK@B>\_N7_N
    MSKMVWGW?P]=]!X],(PGDIB/,/KZ;L"'FL4LW4R2V"(A&&%MN6*^=>2MP
    M\7J8>6*_>_O#K[OPG""V.&!FZ?^]JAUL&/W?/1=KO]IK/?[KNV-HS_W[
    MS:F"00NO[8$C#E_APS]3CTM(GAD-"Q[?=V_TA&C1J:5'$R:M!7DI4IDKXD8R
    M:I)\?STP($C4HB 6C)*Z[1?[/OK65P=M4%_9_96#K8.'#AV:G>M,_/03ESU_
    M@,X:\]9?9/7I^5/.I\4Z.-K/?ZF/=/314[DGIRZIG!9\D1``#0H#JU("L$
    MXT6G[MSU[Z7K#\[S?/>YU'[_G8[/MN0/[IZ^ZX\=QW%=]R?W//BBTY<5
    M4B&;$3BG0SH(L"@"1%NJ 13LDI5RW("L%XS?G/_??;'[CXO--<U[MDQ27M
    M=OOC/YVXZL5__?JS7N^ZKN.X6WY\SVO.?ZYV_E$EZ/N"7R0"0/0``*B4Z&C=
    MTM6"K)B'\9(SE__K3WYYR\]WNZY[Y,B1;SK[S7?_WL\O/_R9R]MN.X_W'G
    MSGY6<O.;-HCV)>;XY0`P# BJK5@JR(,(X_>O$GWW;A/]]TE=Z%Z\S77=
    MH"4J4(NO?/?V3[[MPJSYWLF>YR19/=[)3NEDKT;TB)QD6CUK`6@8:%8J!0-J
    M058(!A']MDG$-$[K_[&:W_]G+&U9ZX]95/[GEPRX_O^9>;?_;)MUT8?)M%
    MZ'R3O=_R?F9YKT;R2,S72SYDV2,Q!@`5X'P'$S-J0;8(ANLZ%SU_]-M7_?:M
    M.Q[]RTWO_V3UP=K2?W!);]=UI2ZD-R@47DW5@"@+J(JL66\2UCUU<XV\$.
    MP0@X_NC%O[UV5=9\B[J 3C2/U'$[P4'(!F!%3"VJ+LXFP0# `/)1GLQGQA59
    MZ%N25F\[C=1,JKY[`Q4:&E8+@F `$$6R#T_X%7/-",AK9)9,2N0SEP`86.]/
    M?@G\?[\F%<LF)80#FR;L>.!.&QG-0<7EW5.0?H6,3DYR6V1VB4HA:$
    M" ,`D$K,O6;%6]0OFC&O%A)3FT%=:D&(, !H&*&[5'>4\IZ/\?'QU'A+)18Q
    M[RS3WGBJH42W(L%X;'KFFUL?>.=G?_#B/_KJ.S_[@V]N?2!K&PP`])!X
    M6WLWCM9 \6E@849[ZQ22F-LGK5@FQIDO)]<<O=>]_W9M?M7KE^I>>\9'
    MMY_,WWOG@1[[RTV#BGNLZ==L(&LX^'C@@TH9&E0O*EW?5;CU9!N1`?&P
    MZZ?1H':UH&2$D6M'IY!=]PCHEONWOM/-V\ZBT773'TI>=?=2Q8LN?,')
    MFW[O59_H[&O_VCW+7?O5<\JF&<W"LY5YI`VZ%7O635/4LUS,/J[Q@.@]
    M4T52Y76=$Q,3L53C"Q0TY9)4%!>Y&5EF6K%Y7C_,DQ6MBG+Y=:;-M:YM,1
    MCS"V;-$1KB]=4>%D]&"UJO><M%SU[ANI[GM3S/:[5:GN>]_-Q3/,][U__Z
    MEV]?573*=IV1M51X9ZI5PIJ\T!]:I?5E67#R35>(W5>Z9,IMJX<6,5!27O
    ME49!BF7)4RFVL']I<88LW&-7ECBS5KRWPZ+&B2NG7'HZ]:O3*I%J[KN:[[
    MBO-.>W+SKYUQZ-%9H"S<G5,CA7JD=CYF&$5#J$*2LYG_N#7NYRL4 POGO[
    MPM?>D:J6@3_7;?VS&N_?8M\BU8JL("Y@=U8ZZ8*\FGTBOM>R3O'K>VD#K8
    MQBOD]?:@BZ>CT($-#_8"56I 5@G';_9]Y*L]3"==VUYZQ\QZ>^GI6\
    M[U:L5/=NK%F&*>93\$J3"?M>NZ]UM&WX2:'VZC]RD7ML/&+-)U.=S4@JP0
    MC!>=OFS[_8]?(*34]7"==V?[I!MT:J7T5XOOG=6$OQN=I7JI*5///&:$:3
    MZ"MOI2P\91%VR3Q#M2 K!.,UYS_WQCL?O'CUJ:EJX;KNEA_OR-JB-34L4,38
    M;JRY]HC-HLB59IDD/Q["EL_#0Z2GAX.2!9/M$4S>*H%63%Q[R5GO_NMOM^
    M?/<CJ6KQ'W?N*F6+5@EF0@V>KE8]U.!I/PB0S$,LDI45SI=LF^S-5BW(B@AC
    M?HO6[__<\[Q7G'=:3"T4MVB54]NK%DGJ23>K($E3&U\FN/'<EEI"WT;<.Q
    M!96N;^U%;6U1BP!;QBQP5@NR0C!H88O6=_VO?WGMR\Y>M_;,M>>L_.F.![?\
    M>$>N5JC?TIV2Y4<K&@WUKZM/?)\Y"?WO5%G6(E1QJC$U&?DM0,>WUE*<@7
    M^ .EP%PMR!;!B&[1>NVW;WG'I[Y>RQ:MS7N5!C%BFI%UCD&+2B,J@7G?M0=<
    M,W 7RW(%L$(J'V5NC$("!ONV#NI.!4?'8:X6;$?WYL(*M2 K.KT!,(QD
    M'H9A2\I%LJBB/$D`
    OON[>N,4OR8HM:D%T1!@#&8.X<<Y$59.1:R);M#3$\
    MI[UT%(@F ``%*QL:DG=7@;8HL2@6 `,$!H>$_%)#7JBLI0A?!,(Q8I89U:
    M$/HP`!@$Y!N7)N'\5IZBAP50N0(0!FL/NS9OK-B'.AOOGMZ]9OS"Q0A"
    MIJ:FLGS]U-14]$^Y),1.5D$QPZJE*-7RT=%1`T5K4UUXL6W5?/5;\T Y6Q;9
    ML>,>`!TJI^Q5-NOV:E14"WFH2I-'9=NROU.!&-'HZ\K-%^[)G<(\DP29@J
    M_YWH?RM2+8]:6$5!9:7*I1:Y_'.@%M.;=:I?5D&.$$(CNX#D"]U)Z]<3T0<^
    M==GQ2Y>L7+%B[F#[DA>_09[)(WOWKCA!-E4;-!*5W_V!)[[_Y/ZY.^_:>?=]
    M#U_WL7AE8QA/)#$?8:C[1U [5<068Y=NIDAL$1"-,+;<L%X[<PY-4D[=!H :
    M<"KXV8/W%5;<2$9-LF4U5E I$K4H2/V=WHY#4_L>J]L*8)2]C_TG7A0`J(+J
    MU((X1!@G+E_^R-Z]4_L>'UVVM&Y;@ GV/O9XK]=!.R0(*-(7C7 J1FSP5;EJ
    M01P$@XA6G'#"(WL??63OWKH-`09P'$= +0`HG:K5@I@(!A&M.,%$ER ``#02
    M`VI!? 0#`#"8H%FI.&;4@B 8`*22;%BWPJ]9820H%V-J01Q&20' C=1NV,G)
    M2;93A<' $E.+JM>D0H0!P&'TW5:!\UM\D25F)6GU5D=/S:26NU=CT95B6"T(
    M@@% %,D.$)MOAF2U\@LF93(9RXO7&-PUM2XTQ:$)JD``B1[Q?$7R2H#".C
    M.:BXVK.J0BH1;D@P@`@CF2UJ8ZH"2Q\VMZA?- .U*)VZU((080"@`6=/
    M%/IN=2/E/1_CX.I\99,Y1EEC6I!$ P`0!+%SG-Y8%&O6C12JI5"X)@
    M`-!@ZNI@D#=G&0!J41'80 E8CU[UDU1U20/+Q,1$B055E"JO@PXN*IIJ?(&"
    MYL4RT;A[ZF6%!#]?\J)\ADJD M-9=VK:US<C+AA;MNBHUI>NJ'!N(0!R
    M]I?LJK&^6#(QLW;BQ>$=4%5U4TEEK%185I*-&S?F%4ZVOU086ZS9N(9R
    MQA9KUI;S= 1@E!0`Z32C6:/2(4Q9R6L<@EQDZB)/.+1$A: /`X!GT.[CY49>
    M4PM>&I,[TPR-C\)*+0@1!@`Q`M]7>[<M?[B]R\OG7=H(-[4@YH(AB%S'%<$G
    M0T567%*XD[4S_Q]?^,FM2@?VPOG0`(\33C/,:I4J9>$IAC3@MR.6:D',!<-U
    MW"=^.?.W/_KXCJE;?_74[KK-*9,C1XX]<_3%?_SJOSIR92LI"P-[X<SA]DY=
    M%PS?Y1OVT_!4"V(N&(+H;W_T\>V/WG;%Y>^JVY;RV?2ESW_N!W_U_I5_D1IA
    M_.V//C[K'/C">SX]NNJ5-1A7&4\^?M>57]R4=>'UTC"G$R499&B'")S5HAFP
    M50MB+AA$M&/JUG>\4U/MO?7;4CYO'/\#7_WE7]P'5<(/_GMCJE;/__N3XN
    MNMBZUW YQRP]X._X=O^\Q[LBZ<`U:L1ZN"RN)7VHO:,KE%#$TJ`F>U(/Z"
    M\:NG=A/UA$/_]?P/B :YSF_>]@ERZ%=/[7:]H5YWGG"KY[:?>(IR?RB:A)
    M%RZ$OVST19(+KY&H>XUI1L.\D@96C HNY=)\(&G\<1>8B_8%#0.RH<X7?K
    M-J1$!)$(NID=)[-A1OB]AH471,)OMSOM69)>.!,:UM 1E<"\EP:]- !_M2 K
    M!*,G?(?(]WMU&U(:0E!/X7+\Q@F&$.3WNGZW4[<AF<C;</C[RF1C6O$K@EH8
    MP JU(#L$@[K4+,%P2'2IV_<%V_>#)GZF#?T:."1\T?-Y!XNI\S"H$;XRD)-<
    MX05_M>AK%5JB2L0"P?!%CQQRG :]:POA"Y7HP2=B=^%#P\L[[4<U$PL1-,>5
    M:E$EL'4N&F2)AJK53D9Z&&16I 5@B&H1^17--L:.2$X$-G;F]X)/5SB0A?
    M".H?,#F."#H[M LKXXB%U@"NB8)7P@AB.O@!"%_XMY`[!++<@*P>B)KB.$
    M\,L7C.'%H^V9J>#ST,@)X>>@K.#;LH50OBDT"PC1&B,!M&KY)/$NVLA! D
    MA!#<N[L;C$9/OF(2Z$I>K%,+&N3%!V/^M#TS-;QX-.M;Z\BR?WCQ:/ O]F?L
    MVE//,6 VJ(C4/58EYS=LA!A#;%0+(FKMWKRY;AOZ$'1ZBPJ:I))Y!D>&%X_.
    M'=I318EA*5WJ.?T:9H(7>6TS4A/.'=H3? BN,7EDY(@3PR-"B.B?89(B)HEJ
    M@L4`AI5YP_WSV]<L7K[<0'%34U-9OGYJZK 7"+DDQ$Y603%#\U)48]&5<6
    MVU;-5[\U#Y2S95$\PM#;OS2'?=ZO9Z8[R(N]Q]E'&TKTK^U_.[W?ZM4N5>
    MG2 2(T><&/R7&SR\@_1YI$XY]?^K@ODY56(]7V:W9J%!3NK9;%5!J[KMV5
    M>IR(1@]'7M9H/_9,[I%DF"1,E?].]\5\E2*%A8O2"]5K7(M4]?H!;3FW6J
    M7U9!\3X,O<W&K;CWMRA1T:.6#%WZ)&Z#2F9Z$6-'%",17_^V"RTFJD>N%;
    M3],H-A;34Z![P\XWBQLDI)PC5>?/RQA;J_2%L<71ZW6J7:.>R>M7Z1
    M78"9%@"?.KY??I/4[,'=(T>LF#TXOQ;LHB4GS1[<'90BA(A]6RY""-_O/WDM
    M-$:CB"S[H[DE\T\M,?PSN$7:)@4)YP=*54.1REP1-Y)1DQJS"A8H0J@6`66U
    M1Y$=HZ2HUZ-1M7./+U[T93PL]A$<&'X-N9I\O7#"&HIS"T-#!#^\*C5Q?\
    M&3N2S%(#U)O47:)HGY<<(8)05 552G%F2%8'0"-U/-;*9IQ]>"@B1U(^
    MEXKHD*^0<:Q;)3>1JYO/)W8D]6)C]R3M3VV3PFX,`.8ITA>-<$I.N6I!5@B&
    M$%TAG.K:,6I ^$)TG7XOVD6:I)@B_& J1MUV`-!,HJ-U2U<+LD(P_/G6FP9Y
    M&2%\X7OS?V2O5BM$HZZ:B(0@WZ?Y6>YHF @3I6"[)", *GV>VT%W:#MAM!
    M0O2Z1&!:V9>4:_3#AKCFG3AO;G9;KMT@L'`P6:E4K!@%H0=\$0=.3(L<''
    M:_ZLWIMJ8(C1XYUO18E!TP).G+DV$=>>]S3CC>%\*Q8?>(O@@A1,_O=CI[
    M']J7>>&@&'"^@XD9M2#N@N'0&:,7?&?S79=?\/Z32F?:W_Z@Q><?'K#:5\
    MY] 9HQ=,?/O3;UWSNA4GKS1M634($B3$WH>>^/RV:S,OG"5!KVRNM5U#X,%!
    MU4358LOXEK'K*YSMP%LPA/_AU__OB6_]Y5=NO?%73U4R):(NCAPY]MQ5K_BK
    M=_Q-W4UKX4OK&3PS6A?-#<0Q/UFF8& $J):8651?'6C <QW67G_V^Q_U
    M6L..XSK5MWN[WG"E?N]=EB4XY OQ.RA_TR>-K 7SHV":A%:TPSBJQ)+DE;
    M2O"D&*AI,X"KZAI6"V(N&$XO>Y<KSM7MR&F&=@9X6&6L2<4?B5^3@C;XF2
    M"$F>1$4M@O_V8MYM:!!7MX<``D:#B[O$N)54S$: XJ-Z&L<PHR:()4BUH0
    M\P@#`//$(H9!\T0AL0O/"IZH7S1C^ 8VJ<4IB[K4@A!A`)"%BNOIVV<0'C?F
    M-S5E%_%/AX:O"D$HL,K-Q61XUJ08@P`$@R"&I<A0[SR41&2B"NI5"T*$
    M`4",)JE%71T,\N:LZHIKTF^7I':UH1@Y-K1:32'?<`D*-7_?2JND:JB8D)
    M,P6%J?+ZS<#":KQ!0J:%\O$_W@69!&JD M@GWZ<JG%MJUE/AWQ)BGU'9VB
    M-&S'/6 7>M5/KZIKI-JX<:.9@K13:5BH4E!2;\S<BG"\;][(P^0]SY4JC"W6
    M;%R3-[98L[;,IP-]& `TF4J',&4EKZMI2-ZA8FF#%8>6J!#T80#00/(ZQX+.
    MU I?;&,_/"NU($08```]F'0U]U@5Y\RP@UN:D%5"\;)RY;N>/#?%QUY#I%
    M3K,V!0* )6$C?I:7+&7A*3[(I\(P-%@.0[6@J@5C1OA$-#L]&SWH'MX,UE/.
    MS9-\]'GE8[GU[VMYOBA1:4;;RD]7O7C?(L;GA<80[)\EGDTUD"LW>:
    M\%0+JE0P[K__T>HR!X #E;[%ETC2/.TW;E9JH8Y%J[RP50NJ2##V[=N_;]_^
    MG(&`BCXB6U%[6U2"TL@K-:4$6"<=W'*MSR:9!)/OQ]7QNS3BAEH:0J3K.7
    M$M_B&6)X\O9@PEPM"*.D["5KG3AJEI_B3_0MGMN\A"A1/<M;0Q!8&("_6A#F
    M85B$D.;=TL#4!#UGZ-JH:8N;Y-YLE0+287J-N00EBA%@3!L!&5AY;A@]UL
    M^BYOSH&P?SYOD@!6UY(7SBVBMJ@%H4G*%HJ\0#$;%LU7_W6/%#.ED5U[KB'C;2*I-(KB.V6
    M9X%(Z)FG5_V,I=I^S4Z-@H*]U21,I;'KVEVIQXEH]'#D98WV8\_D'DF&2<)4
    M>]$_UN1:GEH844%E94JEUKD>J8"M9C>K%/]L@IRA-!?.S;Y0G?2O7:N0$)
    M>KUVR50USO0NJ[@0AO%$$O,11BX7">JEBMAB[--%(DM`J(1QI8;]TTFJ0L
    M0[W%AG,,7A$,WU=N)*,FH1,(D%0M"H)AM790Q O @P`P.%2G%H0(PT94WB+[
    MAA=],RDW0&$[$![43I&:ANH4(S;XJERU($08%J&^0I1D@J[&`U;N,YEE.10%
    M@()4K18$P;"+F&8DG6^N5=BR3JYB*3>YV@U@=PL`Y6) +0A-4M81FZ"D,5FI
    M> [%X;P,.# ,?O3BF%$+0H1A(XJKU4I.4WQ$RWV2^^;&UG&HAURUK[/-]AZ"
    MZC"F%H0(PU(D&R7E'(GHE ``$3!)1$%4$@/#;_I9A7)V<[F:^"JU!( D,;78
    M,KYE[/HYR=!,"RFN)\MQ5/GS82S/,2P3BVC!V0I"WR:A++Q,"O;]<;21&2
    M:E%UB1 ,`-Q3BVBY)W!UW?T6M97K:1RJ^B8;)A7BT(?1@`I&I6I0;=I<
    M6EGG%$=E[I$!,\Q0BUH0(@P`8L1FL?1]Q58YTT;DRZ''!MI)A*H6M<BRMAE+
    MI]2E%H0(`X L-W<,G09%_D/1I(YB!S5:M"HBRUK#9E1'C6I!B# `2&*I
    M5)2(8N>Y)XR16YRK(ZRA7+0@1!@`QFJ06=74PY-K=KT2SSWB3.UJ0=A
    MR=Y4S,W32X7J5TJJO,XQV<JFFI\@8FQ3*I=_^NLBZJEE2!6FALN[1M:YE/
    M!S90`K9BIOJISVQ@M7ZB,;-3DR>'L59W<UC=]HK(%5L$&RA)P 9`(!TAW"
    MQ'9-LK:Q*J 0TM4"/HP`&@@AJ??\_'(Q5=Q9@4KM2!$&%9@:5TO`A\'!)@
    MV!;4=Y\8/J:JP$TM"!$&`$VE[X2,4A:>XD/T<JDGL,?AFI!B#"LP[7(M!X
    M)%LZUDO6Q$.R2BJ(JUI0C8*A_OMEU<A<-2!K5JIB?Z!VG:OT<=)80S372V7R
    MY+NP."L)\J$9&N,M@-EJQ9RPCF&_!NFV*H%6=$D57J'5=XE#1A6\D]X=^_
    MEVH>?[-M17J:B]JR^VYX&:/'IS5@JP0C(#J-.L,\V@Z%AYM^5C&T&03$
    M?CMNST4S8X6Q$/0[$)13N'OJA'Z_6%0X[P\1.*#WZO$.Y%U&&Q0D6AGR
    MWG!(A0'XJP7QCS"BXQS,-$P5?#:2TX\K0F4-459(;BS$HRSR=@[EZLI2/-\P
    M#$W2P JU(/Z"42G%GR63J#^WS/VO9"@+J)2PUS=OD@#FOY&]K9VVJ 5Q:))B
    M0A"P[JZ0K,J@OLR4RLD<4&F#Y78A%JD%61%A5.KX
    MLFH/MUI5Y"9P4 Z&LX!G-@\N'J-D2,/J7D.``FP2RV(?X1AX!TG.D"[TH)
    M(=<+]OGA)JU/)Q%:%0)Q23U_H1VBXQF%4ULTXMB(-@%'=J?7-@54M UCP,
    MPB]5&<FWAC$[G1]PV)5>VR42V(J&5L5$]!OVQHU6-5:UJ'I4N#\>P,FX
    M?W[[FL7+EQLH;FIJ*NL.3TU-1?^4_Q"QDU50S-" %"6-'QT=-5.T'M6IQ;95
    M\]5OS0-7E))AO ]#;_,RO52*VV_%FE"KV/(L=5AMWU2[-V_>O7FSN.VVX%_P
    MYX9-FX(/L7\%2PE"=6]Y5E(UO)P>N:9K0:J;9?LU.CH'!OM2RFTMAU[:[4
    MXT0T>CCRLD;[L6=RCR3#)&&J_'>B_ZW(*DO1-NV"2DF52RUR/8F!6DQOUJE^
    MF3ON/?R-;VADEX7ZEF>2-WK%E_VR8@*]`2199NS>O+G>?=_DJ0JN):5]6M^^
    M(W.H;Q1!S$8:Z?P2U4T5L$>RX%\86`=$(H]".>T6\6T5/;%WA#'O)6X&
    MDF%IQ6\^PQV";R2C)O%?60\80*(6!6$ZK+:BV=U)5!8?9(6Z86PO`0!0'=6I
    M!7$8)=67ZEZ:DLT@L<%Y?%[6BKR \[D`)(4>;-!W993KEH0VPB#SYO$2V+
    M?Q547*VVZA-RP?N`M `HJ-U2U<+XBP85,?N0QKG&$-=0167=,HMSC6M0$"
    M8 M5JP59T2054&X#D7Q,CA4-4ZDSW336E9.,4JL(7KR?.XV, -\5(PH!;$
    M7S!4?'>1I0M*'[13]4"=F&$:4UN+YZ"'RN(-\!T%P0T<3,RH!3%OD@HH_1DH
    MLGL,!Q17JY6<IGA2[_S=JTG'Z*X>MUD`@.V`1!5BZJ7&% ,*4N_"4O;M
    M2/1 <6W1OHI2W5/N4]VE&7"O7C`)2%2;4@(D<(H9TX.7&/X<PIT%0,5#^5
    MUPL523 FAT66/U!9?"%WB(J6E]20Y+9OIWD)54M@IG>$@K-]-9."4"S>B)
    MZHTM\@[6T!B]EDL`$&F5CN'8(L"R)BD`S#HX)OY9(1S,;<9?%WY[QF6S<\
    MO1G4HA:$" . &%FJ(SD.WUE3'+)2.AY=&,R5FW<BIJ$S-/76I!B# `R$)]
    M[ `K'Z2Q#IN\YR/U`F,'^<_'A%J4`B(,`.(TPT41+'S7!)"\9$@EJ4!R(,
    M``ZC`6XEI*X.!GESEF%825<1:E<+2@J&WMYJ>IN7E;Z/6^T%F4S%W#R]5 VK
    M?H&KFIB8T/"81<S6URPT6%L"4YY4YNB>;%,S&_XF&N<,>>G(U"8)^^7&JQ
    M;6N93P?F80!;,5/]M&<V%)D241SUT@O:F9H\V014U]UH1F-4KMBBTGD8:)("
    MH'SX-(.HVQ<8N9,!@P16P$E*@2=WA;0C'J?"P[N1AL.B_F'=%;T$Z&
    MOU>]$5Y9L%(0H0!0EP4 LS-,,C<X:;6A B#"O `VDK-0B##Z[@M09.$I
    MGC1 S!BJ!4$PK$9C2;A<#URY"*ZFGM?0A;X"34H25C82GFI!:)*R%,FZ
    MV5A2NQ:8JT6R2FA7$OYJP?RWZ M;M2 (AG7DVLS'@#V &'LHQ=5-U#/DKQ:V
    MPUDM"$U2=I'4`,F2<%3!AN1%FL(5)P18YX;8JD6YL)J\W528JP5!,.Q%LF^=
    MC;&%I6H117[;:[^TZ-M#WAIB46!AKW[S5PM"DY1%-&-SV52L,#(5;I;WC4%S
    M?9O,TSHO; M6J 5!,&RD](;I>K'WE= ZPE&V>9,$X >J"%O4@M D90M%WF1+
    M[\D8*(J_H==.UJQO]66F5$X&>EBD%H0(PSK4GULKGG"$%VR1[#[+%NNJDUUJ
    M08@P``=L>;P;@$:HJI@$/V)>K%,+0H0!:H1;CW&#2=UC57(^?IJJB:J%12#"
    M`,TAN4-&[6RX?W[[FL7EQLH;FIJ*LO73TU-1?^42TL9!44,ZQ4BLR44CK5
    MA1?;5LU7OS4/7%%*AMAQS]94>@69W_(LB]3F9I/5SUBJ[=?LU"@HV%M-PE0:
    MNZ[=E7J<B$8/1U[6:#_V3.Z19)@D3)7_3O2_%4FS<Z72**C$5+G4(M<#$JC%
    M]&:=ZH<=]^Q&KS=/LGJ@WN*#E=J6%X;Q1!+S$49?WPWX4$5L$>RX%\86`=$(
    MH\B.>VB2L@SU,;<H_1K,P?%^YD8R:A"'4@1J41!T>MM!$2\`#P+ X%"=
    M6A B#!M1>8OL&U[TS81S@ *:1)&:AI>A&+'!5^6J!2'"L CU%:(D$W0U'C \
    MDP!80=5J08@P["ZQD/J\JX:RP0E]:#JV,ZZ;@`\,> 6A $PSIBZP)I+*E=
    M/ <`2@1UK#AFU((@&#:2M99<[)R".?3-9'!0W*LC[]+B58"?; `QIA8$P; 4
    MR49)BBY#OM42_$Z(XH:XDN.XF: Z8FJQ97SV/45SD^"8%A,<4]4BB_FXE%
    M#K24[AR3<R.] ])TA9Y-8EE4O6M,546TBJ1=4E0C `2$=1+21CTJ(C% S[
    MK+PERH,DR5=\II'36V>9IA7"\P6@!2*:X6J4>JIMR@LTAS7-YS"J(R\:A)
    M4XMJ40M"A % C)@&#.QN$$EPS@EK^_FW?31<::6T%=:D&(, #(0G'O=&X;
    MTB47FNR+O.<C]0)C!S5:M$I$/<YK@'C4J!:$" . )*4(@-4;8BMVGDLBL%I<
    M<Y:UZI$B<^I5"T*$`4",@LY]<H&R,BQH3"GG%"S7.KWD2>UJ0=A R=Y4S,W3
    M2X7J5TJJO XZV%8KFJIO4YNB>;%,^.S?56]!&JD"M=#8=FG;UC*?#FR@!&S%
    M3/7.[.!R5Q(=;,+NV5FCPYXK;2!<3ZQG-,`CYM<L46P09$HILH(0F0#*
    M9#Q"W;80Y5G8N,3,#5^O%M[H-2B:B 8`%1%C>-S#$_K]T1QVYUE-1S;(&5
    M6A!&25E!,P9XY,+&9SN5QHS/2<)MF7KYK69B9"ZXJ04AP@"@J?2=D%'*PE-,
    MZ#N1V[J9W@S5@A!A6(&-+T>@P7!KYY';HSXIG0
    U8(@&%:CL3!GKI?*Y,D:
    M[V@J2Y]:\0RGPJU9)HNDH]1^W>:F%E&R9JH3OY!(`ENU(#1)68HDOF8>>J?:
    MQMQF%:IH]BF.XNHFZADR5 OU2>FQ\WG"62T(@F$=BKZ5IPNN=(AG:@/Z2=
    M!HPXX@]SM2 T2=E%W\:<V FEM]C*9T4IMH8ESPR_LJ6).0LFL_92B=[;O$H&
    MJ3 `?[4@1!CVHK&$\X[!M1(GV--WEU>?N'<G5E*9X/-!"0B"81'JSVW#
    MUG/F3Y9.<]/OH#+DJA)0"P/8HA:$)BD;4>S)A%24@KJ79.M/LRJ#^C)3*B?7
    M17AU\O9,MN/9%(0H1A"T6\/Q/ED#2@LWV8!YGHCV+[Y(UUH/)(Y#$K4@
    M1!C6D>N%E]MS$GT93/W6N$4#AT:54$Q2X
    7J^JV+!!BG5H0(@Q@F*PGEM63
    MW#SR#C3@]JK1E])GG%2-C6I!B#" 221N:#*Q@X(&R1TR:F?#_?/;URQ>OMQ
    M<5-34UDW>6IJ*OJG7!)B)ZN@F&'54I1J>CHJ(&BM:E.+;:MFJ]:QZXHI0,
    ML>.>K:GT"JIQR[-8#VKJOA&K5Z_6*$BO^AE+M?V:G1H%A7NK93&5QJYK=Z4>
    M)Z1PY&7-=J//9-[)!DF"5/EOQ/];T6JY5$JRBHK%2YU"+7DQBHQ?1FG>J'
    M'??L1J];6+(8E-Y:4M6=IG&!#..)).8C#'7_"&JGBM@BV'$OC"T"HA%&D1WW
    MT"0%3-!7#Q0'1\IA^+YR(QDUR?:I\J 4)&I1$'1Z6X9Z.RS;%EL`0'54IQ:$
    M",,6BHR1Q2LGX$R1-QO4;3GEJ@4APK 1Q=5JJSX!`,"-Z&C=TM6"(!@6H;Y"
    ME&1%!XTWLG)?XOKN&P$`T-JM2 T2=E%M&$J=>"QKIR*COB%2=FN<1L-#(,
    M&OC%2\& 6A"&U=J(ND//>A2YY":6Z[%[2+"T'U`R#@L'GCU[]5?G*18;5H
    MDK(/Q540)<I^N727_V[\U0"T6V+2Y]2%H$E&UJ'J)$31)68ED7_M<8F!
    MASCMI;;KH@'K!(,&8U(M"()A-<6=;"EN.F\F;+4AB75J462A>$G:4C2^E.7"
    M%$N)85&5RX5AM2 (!@!96<6,0/T5I%1/$XY!<# #:EZ:4MNF%<+0A\&`E8
    MJA;E!IVES/A1/<@3,PP1BUJ08@P`(@1&/;)"3B]B%2T9"^Z-6AWJIC:#
    MNM2"$&$`D(7>VWKMV\U*ML-0FYSZHB[V$$F\S'[FMH`\:A10@1!@!)M'U]
    M[6I1%HH7(HG C+GF!FB .O6J!2'"`"!&D]2BKI9]>1M115@ZRT>=VM6"L..>
    MO:F8FZ>7JI'5S_PNAWF=8V!A-%5R,T0]\V9U+CA8XA$(#D_'8%:!/OTY5+
    M;5O+?#JP- BP%3/5K\A^@C7&'!KKM9389Y,<QEK=K3!VI362[8(=MR3@5!
    M`*@3SIY(?6'C$C.71R<@%QQ:HD0Z6T!`]6M%V"1N^&I%GD'!!<TGM6UIVI
    M0\1+0@1!@!%XD69F!R[4T:,AN#FUH0(@PK&$!G9!TJ+3^&?\<PR,B:6%?*
    MPE.L+Y)#!\8J@5!,Q&8YVU7#XB>;&LZ>RDAT4T2ZX;7@5:W_>BXL4@Z>
    M:D%HDK(4R2XS#=@26-N<T-('E[BSP$7[FH!8!39J$P58M"!&&=2@YSR7
    MYS;;L/-X+Z4&,]5@<IKM?:BMMQK-0M7K@9V1?.:D$0#+OHVY@3.Z%T%URD
    M5SB:\O;-2,`<$61\S6,!68JP6A25):$XX/\S92GS0VC;RN_8EJV=4Q.
    >[=%>7_BK!1']_Y8TJ>
    I\R&LS`````$E%3D2N0F""
    end
  • kcadsoft
    You can get the current beta version from
      http://www.cadsoft.de/betatest.htm
    Klaus Schmidinger
