    • Avnet Boards Community
EAGLE User Support (English) Show and zoom??
  • Replies 12 replies
  • Subscribers 177 subscribers
  • Views 1800 views
Show and zoom??
It's really hard to find a component the way my system is setup. If I do
a "show R44" it will highlight it but the display isn't focused on the
part. I then have to zoom out to show the whole schematic and then I
can't see the highlighted part. I have to zoom in and then slowly pan
across using the two scroll bars until I happen upon the part.
Someone told me he thought there was a ulp or some other function that
would allow you to actually find a part quickly. I have spent 30 minutes
or so looking thru the postings here but didn't see this topic.
Any help appreciated. Rob
    Former Member over 14 years ago +1
    "Rob" wrote ......somone told me he thought there was a ulp or some other function that would allow you to actually find a part quickly. I have spent 30 minutes or so looking thru the postings here but…
    Former Member over 14 years ago in reply to Former Member
    On 10/28/2010 2:15 PM, Warren Brayshaw wrote:
    "Rob"<rob@unpublished.com>  wrote in message
    news:iac0qe$asu$1@cheetah.cadsoft.de...
    >> Warren, thank you for the info. When I run a ulp the program looks only
    >> at my own ulp directory (not in the eagle directories). So I put a copy
    >> in my directory and when I did "run find r1" I first get a message that
    >> it can't find ulpmessage.ulp. So I found that file in eagle, copied it
    >> in my ulp directory and then did "run find r1" again. This time it
    >> popped up a message that says it found the part but I have OK the
    >> message before it actually zooms in on the part. This is not very
    >> convenient. Do you have to go thru okaying this message or am I just not
    >> set up correctly? Thanks again, Rob
    Rob
    I'm still on V4.16 so this may be a V5 issue as some of the relevant
    commands like SHOW behave slightly differently.
    Could a V5 user verify find.ulp does centre and zoom to the part and then
    present the dialog (which needs to be acknowledged)
    Warren
    I don't know, but I'm on 4.16r2 and I have a confirm dialog as well.
    I figured out how to get rid of the acknowledgment requirement. Just
    edit ulpmessage.ulp and dump the one line that pops up the window.
    Didn't have to do anything to exp-project-lbr.ulp.
    Again, thanks to all that have helped me out here.
    Regards, Rob
