    • Avnet Boards Community
EAGLE User Support (English) Show and zoom??
  • Replies 12 replies
  • Subscribers 177 subscribers
  • Views 1800 views
Show and zoom??
It's really hard to find a component the way my system is setup. If I do
a "show R44" it will highlight it but the display isn't focused on the
part. I then have to zoom out to show the whole schematic and then I
can't see the highlighted part. I have to zoom in and then slowly pan
across using the two scroll bars until I happen upon the part.
Someone told me he thought there was a ulp or some other function that
would allow you to actually find a part quickly. I have spent 30 minutes
or so looking thru the postings here but didn't see this topic.
Any help appreciated. Rob
    Former Member over 14 years ago +1
    "Rob" wrote ......somone told me he thought there was a ulp or some other function that would allow you to actually find a part quickly. I have spent 30 minutes or so looking thru the postings here but…
    find.ulp is what you are looking for
    RUN find R44
    will zoom and centre on R44(highlighted)
    enjoy
    Warren
  • Richard_H
    Richard_H over 14 years ago
    Am 24.10.2010 20:42, schrieb Rob:
    Use SHOW @ R44 and EAGLE will draw a pointer to and a frame
    around the object. Since EAGLE 5.7.0.
    Richard Hammerl
    Former Member over 14 years ago in reply to Richard_H
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:ia3b9r$6kj$1@cheetah.cadsoft.de...
    That function somewhat annoys me.. What was the reason for not zooming to
    the object instead of showing that annoying pointer?
  • Richard_H
    Richard_H over 14 years ago in reply to Former Member
    Am 25.10.2010 10:34, schrieb Morten Leikvoll:
    Sure there can be several methods of showing something.
    I like the way it is. I can see where the component is. In most cases
    I know what component it is, but I don't know where it is placed.
    So the pointer is a good solution for me. If I want to see the details
    I can quickly zoom in.
    Of course, zooming onto the object directly can be usefull as well.
    In this case you could use RUN find.ulp. I think it zooms onto the
    object. But IMHO in most cases you have to zoom out again to get
    out where you are.
    Richard Hammerl
    Thanks to all for the tips. I'll look for this run.ulp and see how it
    works. Sounds like lots of keystrokes to find a part but it may be worth
    it. Regards, Rob
    >> "Richard Hammerl"<ric@cadsoft.de>  wrote in message
    out where you are.
    Former Member over 14 years ago in reply to Former Member
    it. Regards, Rob
    >>> zooming to
    >> out where you are.
    you can assign a single key to run the ulp I believe. also if you have a
    3button mouse, then there is no need to mess around with scroll bars.
    you use the wheel to zoom and hold down the wheel (middle button) to
    pan, as in most CAD software these days. If you have a laptop, it would
    be worth getting a small mouse if you do a lot of CAD.
    Gee, I just pushed down on my mouse wheel and discovered I had a 3
    button mouse and it pans -- amazing. I've had this mouse for at least 3
    years and I've had to use both vert and horiz scroll bars like crazy to
    simply look at my schematics. I've still got to find that run.ulp.
    Thanks for the help. Rob
    >>> out where you are.
    "Rob" <rob@unpublished.com> wrote in message
    news:ia9vrj$s6r$1@cheetah.cadsoft.de...
    Rob
    the ULP is called FIND.ulp
    It's in the ULP folder so you just use it.
    Type 'run find' (without the quotes) into the command line and it should
    reveal a dialog to confirm it's there.
    If you type 'run find R1' the dialog mentioned above will not appear. If you
    have an R1 on the page it will be zoomed to and highlighted
    enjoy
    Warren
    Warren, thank you for the info. When I run a ulp the program looks only
    at my own ulp directory (not in the eagle directories). So I put a copy
    in my directory and when I did "run find r1" I first get a message that
    it can't find ulpmessage.ulp. So I found that file in eagle, copied it
    in my ulp directory and then did "run find r1" again. This time it
    popped up a message that says it found the part but I have OK the
    message before it actually zooms in on the part. This is not very
    convenient. Do you have to go thru okaying this message or am I just not
    set up correctly? Thanks again, Rob
    On 10/10/27 16:54 PM, Warren Brayshaw wrote:
    "Rob"<rob@unpublished.com>  wrote in message
    Rob
    enjoy
    Warren
    news:iac0qe$asu$1@cheetah.cadsoft.de...
    Rob
    I'm still on V4.16 so this may be a V5 issue as some of the relevant
    commands like SHOW behave slightly differently.
    Could a V5 user verify find.ulp does centre and zoom to the part and then
    present the dialog (which needs to be acknowledged)
    Warren
