EAGLE User Support (English) Bug in 7.3, can't export to TIF file
  • Replies 27 replies
  • Views 2977 views
In version 7.3 on Windows 7 64 bit, there seems to be a bug in exporting a
board to a TIF image file.  In the board editor, if I run "EXPORT IMAGE
\temp\a.tif" I always get a popup that says "Out of memory while writing
'/temp/a.tif'".  This happens regardless of resolution.  For example,
"EXPORT IMAGE \temp\a.tif 50" fails the same way, even though that would
have only required 320 x 552 pixels in my case.
This is a important feature to me since that's how I make assembly
drawings.  The same procedure to make the same assembly drawing worked fine
in version 5.
    in version 5.
    Hi Olin,
    Here's a sample of what is produced by the fix. Let me know if this
    works. Also let me know if the attachment doesn't make it.
    Best Regards,
    Jorge Garcia
    Fixed-lin-mono2.tif
    autodeskguest over 10 years ago in reply to autodeskguest
    By the way, The FILE > EXPORT menu still won't accept "I" to go to the
    "image" entry, as it did in version 5.  A number of similar things that
    broke from version 5 to 7 (I never used 6) are still broken in 7.6.
    I wasn't aware of this issue. I have reported it as well and will follow
    up once I hear something.
    Best Regards,
    Jorge Garcia
    in version 5.
    Hi Olin,
    Good news! Qt got back to us on this issue and they have provided a fix.
    With the release of beta 7.6.1 (I don't know when it will be released
    yet) the fix will be included.
    You'll get the TIFF files you are used to. As always though feel free to
    let us know if something doesn't work.
    There's a couple of other points on this thread that I need to report
    and will be doing this in short order.
    Best Regards,
    Jorge Garcia
    Am 20.05.2016 um 20:32 schrieb Olin Lathrop:
    SNIP
    broke from version 5 to 7 (I never used 6) are still broken in 7.6.  It
    seems that every version the user interface gets more tedius, requiring
    either more keys, or much worse, forcing the use of the mouse.  I don't
    know your process, but it feels on this end like nobody checks these
    things.  You need someone using only the keyboard to follow a proper
    regression test that hits all menus, popups, and the like.  One of the
    great things about Eagle is that you can do most things with the keyboard,
    but that advantage is eroding with every new release.  It used to be
    something you paid attention to, but recent releases have been
    disappointing.
    Instead of creating a new version and adding new features, fix all the
    little things that are broken first.  I know you make money by bringing out
    new major versions, but you have to give the existing customers good value
    too.  I'm not sure what I really got out of going from version 5 to 7.  I
    did that because I got a customer to get me Eagle for my use at their site.
    That of course had to be the latest version, which was 7.  I did upgrade
    from 5 to 7 at Embed, mostly so I could move libraries back and forth and
    not have to re-invent new parts.
    What did I get for that?  The binary versus XML file format under the hood
    is irrelevant to me.  The hierarchical schematics is a nice idea, but not
    really ready yet.  The autorouter is now more complicated with that silly
    top router that doesn't solve anything for any real EE I know of, and a
    bunch of the user interactions are now much worse.  Can I get the ver 5
    autorouter interface back, please?  After enough confusion, many more
    keystrokes and very annoying clickety-click interactions I eventually get
    it to do what it did much more easily before, but I don't see any advantage
    at all.  Your existing loyal customers deserve more than the 5-7 delta for
    the price of two upgrades.  It seems lately you're too focused on the
    window dressing and appealing to stupid people so that you're not adding
    real value each release anymore.
    Well this has nothing to do with the bug report but I agree 100% what Olin
    says about the latest eagle "developments".
    IMHO it's a shame to declare  new blurry icons as new features, ah but
    yes, they are scalable.
    Same goes for the loud announcement of the "hierarchical design" which
    is not half ready yet.
    If someone tells me now that hierarchical design will be finished in
    version 8 or9 then that's it with me and eagle after 25 years.
    Joern Paschedag
    SNIP
    disappointing.
    Joern Paschedag
    Jorge Garcia wrote on Thu, 19 May 2016 11:16
    It's been a while since I've heard from you. I've touched the subject
    again.
    Thanks.
    Quote:
    This isn't a case of gratuitous change, it's more of an unintended
    consequence of upgrading our GUI libraries.
    That's one of the drawbacks when you don't own all your code.  You are
    beholden to those that maintain the low level libraries that you rely on.
    When you go that route, you need a really really good suite of regression
    tests.
    If I remember right, you use QT for your GUI library.  I know nothing about
    it, but surely there must be a parameter you pass that indicates the type
    of image file you want them to create.
    Quote:
    Since we are discussing, EAGLE supports other image formats with
    monochrome output. Is there another alternative that might better suite
    your purposes? For example, GIF or PNG?
    The tools I use don't support PNG.  While I could in theory update them to
    yet another file format, this is not something I want to spend time on at
    this point.
    As far as I can tell, Eagle doesn't support GIF files.  My tools do
    understand GIF files, and they could support either monochrome or gray
    scale images efficiently and without loss, but Eagle won't create them.  I
    just tried it again in version 7.6.  With a schematic window open, I do
    FILE > EXPORT > IMAGE.  In that dialog I enter "\temp\a.gif" for the file
    name and check "Monochrome".  Instead of create the file as entered,
    "\temp\a.gif.png" gets created.  I haven't checked, but assuming that's a
    PNG file, not a GIF.  The same thing goes for JPG.  You get a .jpg.png file
    when you try.
    disappointing.
    again.
    Thanks.
    tests.
    this point.
    when you try.
    disappointing.
    Once again, DON'T MAKE GRATUITOUS CHANGES.  You will inevitably break
    something that someone has relied on.
    Hi Olin,
    again. This isn't a case of gratuitous change, it's more of an
    unintended consequence of upgrading our GUI libraries.
    hth,
    Jorge Garcia
    Hi Olin,
    hth,
    Jorge Garcia
    Hi Olin,
    hth,
    Jorge Garcia
