EAGLE User Support (English) Better Eagle zooming with trackballs, how?
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 1032 views
Just switched to a Logitech T-BC21 trackball because it's much easier on
the wrist. And dog hair from our Labradors does not get in so easily image
How can one zoom better with trackballs which do not have mouse wheels?
I assigned the two back buttons to F3 and F4 so zoom essentially works.
But not nearly as well as the mouse where the wheel will zoom into
wherever the pointer was. Unfortunately in Eagle F3/F4 are
"pointer-insensitive" and thus do not zoom centered at the pointer or
cursor.
Does anyone know a trick how to emulate a mouse wheel with a trackball?
Like CTRL + roll the ball? Despite being very bloated the Logitech
configuration download does not offer this.
Regards, Joerg
    autodeskguest over 10 years ago in reply to autodeskguest
    On 2016-01-14 13:45, Rob Pearce wrote:
    On 14/01/16 18:39, Joerg wrote:
    Turning the ball with the thumb is much more comfortable - and that one
    also has a wheel...
    I really prefer index and middle-finger instead. Maybe because I ride to
    much mountain bike where those fingers are always on the brake handles image
    I don't ride my mountain bike often (or at all, these days) but I too
    find the fingers much more dexterous with the ball than the thumb. I
    detest the thumb track-balls with a vengeance.
    I believe they are also less healthy because you'd then mostly bend the
    thumb back and forth. That can foster carpal tunnel disease. With the
    fingers my whole hand moves.
    But not having a working scroll function is a major setback. I'll have
    to mount a mouse on the other side or something, just so I have a scroll
    wheel. Eagle is tough to use without that. I wish there were Eagle hot
    keys that, unlike F3/F4 would zoom into where the cursor is and not
    always assume one wants to zoom centered.
    I am also wondering how long those little plastic knuckles of the
    Logitech rackball will last that the red "marble" ball glides on.
    Probably because of mountain biking I often use a lot of force with my
    hands and have worn out several keyboards.
    Regards, Joerg
    also has a wheel...
    You just got the wrong trackball.
    Unless you're left-handed, the M570 is the one to go for.
    With that one people reported the same kind of problem on the web.
    also has a wheel...
    The other reason is that I sometimes use the trackball (and mouse) on
    the right, sometimes on the left.
    Regards, Joerg
    also has a wheel...
    Regards, Joerg
    On 2016-01-14 00:04, Joern Paschedag wrote:
    Am 13.01.2016 um 21:15 schrieb Joerg:
    cursor.
    Hi Joerg,
    with the "Logitech SetPoint software" it should be possible to adjust
    the trackball.
    I downloaded that rather bloated SetPoint software. Over 80MB
    (megabytes!) but not much to write home about. I does not let you fully
    emulate the scroll wheel of a simpe mouse which was quite disappointing.
    Zoom neither works in Eagle nor in Foxit.
    Another thing is: Could it be possible that the trackball has a lower
    dpi than  your mouse?
    No idea but otherwise it works just as well as the mouse.
    Regards, Joerg
    also has a wheel...
    Tilmann
    cursor.
    Hi Joerg,
    the trackball.
    Joern Paschedag
