I asked before but I will ask again. Could you guys please make it so that
two taps of the ESCAPE betton will totally deactivate the MOVE command (or
any other command).
Apparently, your Options >SET >Misc Select factor ( % ) has no bearing on a
group, so that means that an accidental R-click of the mouse will move a
group, even with 2% "Select Factor", and even if the R-click was from planet
Pluto.
Being able to tap the escape key is sometimes much easier than having to use
the mouse to click the STOP button, except that it doesn't always work. The
Move command will stay active, even after 10 taps on the escape key. Is
there reason behind that?
I sorry, that was a rhetorical question.
