EAGLE User Support (English) Newbie struggling with making edge connector
  • Replies 27 replies
  • Subscribers 182 subscribers
  • Views 5511 views
oldtech1000
oldtech1000 over 10 years ago
I am having trouble trying to make an edge connector in eagle.
I wish to make a PCB that plugs into a 20 pin edge connector, to make an extender board.
The board consists of only 20 tracks with a spacing of 0.1 inches. No components, just the tracks.
Have not been able to find anything in libraries,tried to modify other connectors but all appear to want me
to connect to other components (other than the tracks).
I am sure this is very easy for experience Eagle users but not obvious to a very New Newbie like me.
Thanks for your help
Regards
George
    autodeskguest over 10 years ago in reply to oldtech1000 +1
    On 22/01/2016 2:50 p.m., George LIVANES wrote: Hi Warren, Thanks for the help. Yes, the extender i am trying to make looks exactly like this picture (Double sided). The edge connector is called a "PCB…
  • gpsmikey
    gpsmikey over 10 years ago in reply to autodeskguest
    Rob Pearce wrote on Sat, 23 January 2016 01:31
    On 23/01/16 02:26, Mike Fields wrote:
    (why you don't use a wire to wire something is beyond me, but that
    is the
    way it is).
    Because in the schematic you are not "wiring up", you are defining the
    nets that you will later "wire up" on the board. The lines on the
    schematic don't represent wires but connections - which could be
    realised in a variety of ways that don't necessarily look like the
    schematic.
    While that is true, it is not intuitively obvious from the number of
    beginners that try to create schematics using the "wire" function
    (especially for those of us old enough to have put in lots of time wire
    wrapping boards etc.)  What they really need is one of those warnings that
    pops up (that you can turn off) when someone starts to draw a schematic
    with the "wire" command.  Just a simple popup that says "use the net
    command when connecting components in a schematic" with the option to check
    "don't show this again".
    mikey
  • gpsmikey
    is the
    way it is).
    schematic.
    mikey
  • gpsmikey
    is the
    way it is).
    schematic.
    mikey
  • oldtech1000
    oldtech1000 over 10 years ago in reply to gpsmikey
    Hi Warren,
    Thank You Very Much for your help....greatly appreciated.
    Only problem is I cannot see your attachment  on my side.
    Could you please attach again or perhaps email me ?? as I
    would very much like to see your version.
    I thought of just using the board editor but although I managed
    to get some rectangular pads into the board editor I could not route
    The pads together (without first connecting them together in the schematics editor
    to create airwires).Without airwires in the board editor I could not route the pads together.
    I would think this is normal as Eagle expects you to use the schematics editor first, check for errors and
    then go to the board editor.
    I hope I am making sense as I am obviously very new to eagle.
    You also answered my problem regarding how to make the tracks longer...Thank You.
    Regards
    George
  • oldtech1000
    Hi Mike,
    Thank you for pointing out I should be using NET instead of WIRE in Eagle
    Read this in several places but, after watching a u tube tutorial which used WIRE,
    forgot that NET was preferred...very confusing for Newbie.
    Regards
    George
    Hi George
    You are yet another victim of Element14's badly implemented web portal
    into the Cadsoft Forums....and you thought it was a E14 forum image
    Try Eagle Central, its a much better web interface that works properly.
    You will find the attachment is there on your thread.
    http://www.eaglecentral.ca/index.php/t/52170/1a48f5bf2f7bdad27de93cd6681c1c93/
    Warren
    Hi George
    Warren
    Hi George
    Warren
    Hi George
    Warren
  • COMPACT
    COMPACT over 10 years ago
    Hi George!
    Would you like to view a helpful walkthrough?
    Very Compact
