EAGLE User Support (English) Eagle Cad default silk screen
  • Subscribers 189 subscribers
  • Views 455 views
I can change the width to height ratio of the silk screen manually.  But is there a way so that my silk screen vector font is always a width ratio of 15%.  A defualt setting so that I don't have to manually update all my silk screen.
    e14 Contributor over 10 years ago in reply to omega-5
    Got it!!!
    Thank you very much!!
  • omega-5
    omega-5 over 10 years ago in reply to e14 Contributor
    Am 03.02.2016 um 17:23 schrieb Tony Crocker:
    Thank you.  How do I download the script?
    https://www.element14.com/community/message/173398
    I think there is a problem with the synchronization between the
    newsgroup eagle.support.eng and Element14. The script is
    available as an attachment in the newsgroup.
    If you do not use a newsreader like Thunderbird, then you can
    better take the WEB Interface of http://www.eaglecentral.ca/.
    Freundliche Grüße / Kind regards
    Friedrich
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
  • omega-5
    Am 02.02.2016 um 15:23 schrieb Tony Crocker:
    all my silk screen.
    As a possible solution I have this script for you:
    change_size_ratio.scr
    PS. No attachment on E14.
    Friedrich
    ... use NNTP://news.cadsoft.de and a functional news reader like Thunderbird!
    Web access to CadSoft support forums at www.eaglecentral.ca
