EAGLE User Support (English) Problem with import-bmp.ulp
  • Subscribers 184 subscribers
  • Views 2498 views
Former Member over 15 years ago
I'm running Eagle 5.11.0 on a 64 bit Windows 7 machine, and am having
problems importing a bitmap.  I've reduced the colors in the bitmap to 2
(monochrome / black and white), and reduced the size of the bitmap to
575x240 pixels.  When running the import-bmp.ulp, I get the message "Bitmap
file contains more than 256 colors, reduce colors before use".  Have you
seen this problem before, and is it related to Win7 64 bit compatability
issues?
Arley
Arley D. Jackson
Softronics
100 35th Street Suite A
Marion, IA 52302
ISO 9001:2008 Certified
Phone 319 721 6778
Fax 1 319 851 4433
    "Bitmap file contains more than 256 colors, reduce colors before use".
    Have you seen this problem before, and is it related to Win7 64 bit
    compatability issues?
    Arley
    Arley D. Jackson
    Softronics
    Marion, IA 52302
    Phone 319 721 6778
    Fax 1 319 851 4433
    Hi Arley,
    It's not a Windows 7 issue(for once). Try this procedure:
    -Run import-bmp.ulp
    -Say ok to the help popup that shows up.
    -Find your bitmap file and click open.
    -The ULP will now popup a dialog with a pallet of colors and it will
    probably tell you that the bitmap is a 256 color file.
    -At the bottom of this dialog you'll see a button that says Scan used
    colors, click it.
    -If your file is truly monochrome then in the next screen with
    checkboxes and colors you'll see that black in the upper left and white
    in the lower right are checked. Depending on the situation you may want
    to uncheck the white. If you find that more colors are selected try
    having black checked by itself and uncheck everything else. Click ok.
    -This will pullup another dialog where you can select the scaling and
    format of the imported bmp. For this test you can leave them alone.
    -Click ok.
    -It should generate the script, click Run script to get the bmp in.
    hth,
    Jorge Garcia
    Am 04.02.2011 17:20, schrieb Arley Jackson:
    Then the bitmap has more than 256 colors.
    Please send me your bitmap.
    I can not see a problem on my Win7 Pro (64bit).
    I have save a bitmap by paint with 16 color (4bit).
    Bitmap and library attached (look symbol).
    Alfred Zaffran
    _____________________________________________________________
                                 Web:   <www.cadsoft.de>
    Geschäftsführer: Dipl.-Ing. Klaus Schmidinger, Bodo Badnowitz
