EAGLE User Support (English) Via's get lost when changing layer
  • Subscribers 187 subscribers
  • Views 332 views
I'm trying to flip some already drawn details from top layer to bottom,
and eagle (7.5.0) for some strange reasons seems to find it suitable to
remove all the vias connected to these nets when I group change layer. I
want to keep those vias and cant find a way to prevent Eagle from doing
this. Are there workaround or should this be flagged as a bug?
    autodeskguest over 10 years ago in reply to autodeskguest
    On 09.02.2016 14:59, James Morrison wrote:
    Morten Leikvoll wrote on Tue, 09 February 2016 13:22
    I
    What if you turn off the via layer before you select the group so that vias
    aren't included in the change layer command?  Does that help?  Just an
    idea, not sure if it will help or not.
    James.
    Unfortunately that does not help.
    The only thing I can do with some effort is to copy the vias first, then
    change layer, and then move vias back. But if the copy buffer contains a
    lot of different nets, there will be some work renaming the new via
    names back. Not ideal. Wish there was some way of keeping the netnames
    during a copy easily (maybe there is?). I guess I have a clone script
    that can do it, but even that is not as straight forward as it should be.
    I
    James.
    Order your EAGLE license from Stratford Digital at
    http://www.eaglelicenses.com
