EAGLE User Support (English) How to change all wires?
  • Replies 19 replies
  • Subscribers 180 subscribers
  • Views 5502 views
Former Member over 15 years ago
I 'am using Eagle 5.11
In my layout I have many traces with  WIDTH of 0.2mm.
Now I would like to change all that wires  in WIDTH 0.15mm.
I know I can do that with the command  CHANGE and GROUP but is there an
other way ?
With GROUP some other wires ( for example WIDTH of 0.5mm ) change too.
THANKS
    an other way ?
    The ULP
    cmd-change-brd-width.ulp
    can do it for you
    All the best
    Warren
    other way ?
    You could try cmd-change-brd-width.ulp.
    Tilmann
    Former Member over 15 years ago in reply to Former Member
    >> other way ?
    Tilmann
    Also, you should look into classes, by assigning nets to a certain
    class, you can control width and clearance for that class. that way your
    hi current or power nets don't need to change with your signal nets.
    maybe this is what you are really looking for.
    also, you can group by box and then ungroup certain elements, but I
    don't remember how to do it, it is possible though.
    other way ?
    THANKS
    I don't think so:
    - Modifying classes does not change anything that is already routed;
    - Class widths are used /only/ by the autorouter and have absolutely no
      effect when routing manually.
    Tilmann
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:iitfcc$rqg$1@cheetah.cadsoft.de...
    I don't think so:
    I somewhat agree with Gary. I use classes myself, but it needs to be
    followed up with ULP's. I have ULP's for grouping classes (on specific
    layers), and with that I can easily change width of a class,, no matter what
    it used to be. It is very useful when doing impedance match and when you
    play with stackup materials and distances.
    >> I don't think so:
    You are right - but without additional ULPs, using classes wouldn't
    solve the OPs problem.
    (And even for what you described, the previously mentioned width change
    ULP can be restricted to a particular signal - so for most cases it
    should be sufficient.)
    Tilmann
    Thanks all for the information.
    But I was thinking there maybe  a ULP so you can change all wires with width
    0.2mm into 0.15mm without selecting all the wires seperate.
    Karst
    "Tilmann Reh" <usenet2007nospam@autometer.de> schreef in bericht
    news:iitkd7$lk7$1@cheetah.cadsoft.de...
    >>>> your
    >>> I don't think so:
    >> what
    Tilmann
    with width
    Karst
    The mentioned ULP does it both ways. I'm referring to the ULP bundled with
    Eagle v5.11 The ULP dialog has 1.5.1 as a version on it. The version that
    came with v4.16R1 looks similar.
    So you either:
    - select the signals of interest
    - or select none but check the box below ("Change without Signal name") and
    you then enter the range in the bottom two fields. The fields are
    'inclusive' so for your example above put 0.15  in the first box and 0.2.
    Note the Units are whatever your board is in currently i.e.. mm  inch  mil
    or mic
    All the best
    Warren
    I don't think so:
    Tilmann
    Yes, I was wondering if maybe the OP was really after a way to control
    the widths as he was doing the board, since he mentioned "other ways".
    That's why I said "look into" classes, because it is not clear if it
    solves his problem or not, but may be useful to him.
    As an aside, wouldn't it be better if the manual router used the net
    class information to preload the width of the traces? I never actually
    noticed that it doesn't. Maybe that's why I stopped using net classes image
