EAGLE User Support (English) How to create library part with thermal pad?
  • Replies 55 replies
  • Subscribers 189 subscribers
  • Views 7579 views
Hi there,
I was hoping someone could give me the recommended flow for creating a
library package with a thermal pad.  I'm using an LME49600TS/NOPBLME49600TS/NOPB which has 5
pins and a thermal pad.  The pad is electrically connected internally
to Vee.
I initially tried just marking a tStop region in the shape of the pad
hoping that if I just drew a polygon over it in the layout editor and
hit ratsnest, all would work out.  All I got was a polygon around the
pad not connected to it.
I then tried to draw a polygon in the package and name it something but
I discovered you can't name polygons.  A square pad would work I guess
but this isn't the shape of the pad which is in the shape of a 'T'.
Any pointers on the correct way of doing this?  The demo board doesn't
have the pad polygon connected to the Vee pin so that shouldn't be an
issue.
Thanks, Shareef.
  • justinhotban
    justinhotban over 9 years ago
    I think you should use SinoGuide TCP110U thermal pad for test, one side with fiberglass reinforcement;  TCP110U has a 1.1 W/mK thermal conductivity for exceptionally low thermal resistance. Naturally tacky on one side for easy assembly,  A special resin material that is easy to pull from the liner and place in the application enhances handling.
    e14 Contributor over 14 years ago in reply to kcadsoft
    On 9/27/2011 12:16 AM, Klaus Schmidinger wrote:
    On 09/27/11 01:42, Olin Lathrop wrote:
    >> warrenbrayshaw wrote on Mon, 26 September 2011 18:20
    >>> I too would have guessed there were a large number US resident Eagle
    >>> users
    >>> but alas not one has responded to confirm your assertions.
    >> I don't think many people watch these forums, particularly in the US
    >> where
    >> they are not well known. Haven't you noticed that particularly the NNTP
    >> users are disproportionately European? Also note that nobody from the US
    >> has disagreed with me either. Most people don't want to use NNTP,
    >> Element14 is widely disliked, and few people know about Eagle Central.
    >> I can tell you that I've mentioned this to others and have pointed people
    >> to my TEXTFLIP ULP that tries to fix vertical text after the fact.
    And I am still waiting for you to provide a
    concrete example of a diagram, data sheet
    or whatever (preferably, of course, a schematic diagram)
    that has vertical text reading downwards (or "from the left
    side"). Since this is, according to you, what everybody
    does in the US, it shouldn't be hard to come up with something.
    Klaus Schmidinger
    I (in the US)  Like NNTP. Clear Concise, no frills and searchable.
  • kcadsoft
    kcadsoft over 14 years ago in reply to e14 Contributor
    >> users
    I don't think many people watch these forums, particularly in the US where
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    users
    Olin Lathrop wrote:
    warrenbrayshaw wrote on Mon, 26 September 2011 16:48
    >> The request is for documentation and CAD drawings practices  and not
    >> the spines of books,
    As I said before, down-reading vertical text is a strong convention
    here. The book spines are merely a way to illustrate this and point
    out that there really is a difference.
    You're not going to find a standard document, but the fact that's how
    it's done here should be good enough.  I don't know what fraction of
    Eagle users are in the US, but that's got to be a significant number.
    I too would have guessed there were a large number US resident Eagle users
    I was only curious. I went looking for an example and found none. I was not
    asking for a standard document, just a link to a document or attachment that
    provides anecdotal evidence that the convention exists beyond individuals
    choosing to use that practice. You are requesting the feature and have not
    in the interrum provided examples.
    To me it seems that Cadsoft would be justified in not catering for it as the
    business case has not been made.
    Warren
    news.cadsoft.de
    As I said before, down-reading vertical text is a strong convention here.
    The book spines are merely a way to illustrate this and point out that
    You're not going to find a standard document, but the fact that's how it's
    done here should be good enough.  I don't know what fraction of Eagle users
    Andreas Weidner wrote:
    Am 23.09.2011 23:13, schrieb Warren Brayshaw:
    >> Can soemone, a US resident I suspect, post some document links that
    >> show down reading text is a common convention somewhere.
    In my office and our institute's library, we have several hundreds of
    English books, mainly from American publishers. Of this awful number
    of books, not more than about a handful have their titles printed
    upwards. Therefore, downward printing seems to be QUITE common in the
    US.
    Even quite OLD German books have their title pointing downwards, and
    only the 'younger' ones (from the 70s and later) seem to have adopted
    upwards printing. I myself prefer upwards, of course, because I only
    learned reading in the 70s (yes, of the LAST century, and NOT the one
    before that)...
    Andreas Weidner
    The request is for documentation and CAD drawings practices  and not the
    spines of books, which has derailed the discussion. Interesting though.
    Warren
    news.cadsoft.de
    Can soemone, a US resident I suspect, post some document links that show
    English books, mainly from American publishers. Of this awful number of
    books, not more than about a handful have their titles printed upwards.
    Therefore, downward printing seems to be QUITE common in the US.
    before that)...
    Andreas Weidner
    On 24.09.2011 00:51, Olin Lathrop wrote:
    >> Robert Pearce wrote on Fri, 23 September 2011 12:55
    >>> A bookshelf is a very poor model to use as referent.
    >> It was merely a example.  How is the text on the spine of german
    >> books oriented?
    German books usually have the text reading upwards.
    Book titling is irrelevant but the following from Wikipedia  completes our
    education.
    QUOTE
    Spine titling.......
    ......Early books did not have titles on their spines; rather they were
    shelved flat with their spines inward, and titles written with ink along
    their fore edges. Modern books display their titles on their spines.
    In languages with Chinese-influenced writing systems, the title is written
    top-to-bottom, as is the language in general. In languages written
    horizontally, conventions differ about the direction in which the title on
    the spine is rotated:
    • In the United States, the Commonwealth and in Scandinavia, titles are
    usually written top-to-bottom on the spine. This means that when the book is
    placed on a table with the front cover upwards, the title is correctly
    oriented left-to-right on the spine. This practice is reflected in the
    industry standards ANSI/NISO Z39.41[22] and ISO 6357.[23]
    • In most of continental Europe, titles are conventionally printed
    bottom-to-top on the spine so, when the books are placed vertically on
    shelves, the title can be read by tilting the head to the left.[24]
    END QUOTE
    Latin America publications are not mentioned  but a quick search reveals
    they mainly follow Europe.
    Warren
    news.cadsoft.de
    Klaus Schmidinger wrote on Sat, 24 September 2011 04:59
    That's what I thought but wasn't sure.  Here in the US the spine of books
    when in a bookcase read down.  This means there definitely are different
    regional conventions.
    Again, the books are only one indication of the general preference.  The Y
    axis label is a special case because the Y axis "flows" upwards and the
    text is just going along with that.  Other than in such cases, upwards
    vertical text just looks strange or wrong.
    Quote:
    Imagine a symbol with two pins, one extending to the right
    and one to the left (i.e. rotated by 180 degrees). Would you
    really want the pin and pad names of the left pin be written
    upside down?
    No I wouldn't, but this particular case is a lot easier because there are
    only 4 possible pin orientations so it's easy to say up front what the text
    orientation for each case should be.  In the two vertical cases I want the
    text reading down, not up as now.  This should probably be based on a
    global vertical text orientation switch.
    What I was thinking about more was arbitrary graphical text created with
    the TEXT command, like in the silkscreen layer coming from package
    definitions.  Those end up in arbitrary locations and orientations anyway,
    so I don't care how Eagle originally writes them as long as it's easy for
    me to move around and reorient.  Note that easy doesn't include having to
    set the spin flag.
