EAGLE User Support (English) How to create library part with thermal pad?
  • Replies 55 replies
  • Subscribers 180 subscribers
  • Views 6101 views
Hi there,
I was hoping someone could give me the recommended flow for creating a
library package with a thermal pad.  I'm using an LME49600TS/NOPBLME49600TS/NOPB which has 5
pins and a thermal pad.  The pad is electrically connected internally
to Vee.
I initially tried just marking a tStop region in the shape of the pad
hoping that if I just drew a polygon over it in the layout editor and
hit ratsnest, all would work out.  All I got was a polygon around the
pad not connected to it.
I then tried to draw a polygon in the package and name it something but
I discovered you can't name polygons.  A square pad would work I guess
but this isn't the shape of the pad which is in the shape of a 'T'.
Any pointers on the correct way of doing this?  The demo board doesn't
have the pad polygon connected to the Vee pin so that shouldn't be an
issue.
Thanks, Shareef.
    Former Member over 14 years ago in reply to Former Member +1
    Am 04.04.2011 21:58, schrieb Gary Gofstein: On 4/4/2011 7:00 AM, Olin Lathrop wrote: >> Klaus Schmidinger wrote on Mon, 04 April 2011 04:35 >>> Well, I'm sorry I got into contact with the GED before I…
    On Tue, 29 Mar 2011, Owen wrote to us saying :
    >Actually I don't understand why you say it generates holes...
    >I might need to read the help section on tStop, but I know that there were
    >no holes generated in our boards on the tStop layer...
    Try reading what he said:
    >Things drawn in the tStop and bStop layers make
    >holes in the top and bottom solder mask, respectively.
    So there's no mention of holes in the board, nor of holes "generated in
    the tStop layer". It's quite simple, so let's try fewer syllables:
    The tStop and bStop layers define where the SOLDER MASK is NOT present.
    That is, they define the HOLES in the SOLDER MASK. Please note that this
    is the SOLDER MASK. It has ABSOLUTELY NOTHING to do with board holes or
    copper traces.
    If you want to keep a polygon (or the autorouter) away from somewhere,
    you need the tRestrict layer. This is all explained in the help, so
    perhaps you should read it.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    Well Mr Pearce,
    as much as I thank you for your help, I must admit that I am not as
    knowledgeable using Eagle as you might have thought I was. That is why I
    didn't understand (and still don't) why there are supposed to be holes in
    the tStop layer, what they do, nor how come it is one of the only two
    layers that are generated automaticall for a SMD pad. there might be
    something (or more than one thing) that I don't understand, that's obvious,
    but if I did know, then I obviously wouldn't be posting on this forum, eh?
    So, no need to insinuate something by saying that I need less syllables in
    order to understand, or telling me to read the help file when I don't even
    know specifically what to look for... It is hard to know what to look for
    when you think you've looked at everything you could think of, and then
    there's the things one doesn't think of...
    In any case your explanation did help me out. I shall try this polygon
    perimeter-delimitation method with the tRestrict layer.
    sincerely,
    Redcutlass
    On 3/30/2011 12:29 PM, Owen wrote:
    Well Mr Pearce,
    sincerely,
    Redcutlass
    Hi Redcutlass,
    I'm sure Mr. Pearce didn't mean anything by it. To understand what the
    tStop and bStop layers do you need to look at a PCB. Whenever you have
    smd components, the pads of the components need to remain exposed once
    the board is manufactured, otherwise they'll get covered with
    soldermask(this is gives PCBs their classic green color) and you won't
    be able to solder parts to the board.
    The function of the tStop and bStop is to indicate what areas need to be
    void of soldermask so that the copper pad can show through. This is why
    features are automatically drawn on the tStop layer whenver you create
    an smd pad for your package. These voids are what Olin referred to as
    "holes", though I could see how that term could be confusing to a new user.
    If you want the autorouter to avoid a certain area then as already
    mentioned you would draw features in the appropriate restrict layer.
    hth,
    Jorge Garcia
    Redcutlass wrote on Wed, 30 March 2011 12:29
    That is why I didn't understand (and still don't) why there are
    supposed to be holes in the tStop layer, what they do, nor how come it is
    one of the only two layers that are generated automaticall for a SMD pad.
    It seems now the real problem is not as much your understanding of Eagle,
    but that you don't understand how PC boards work and how they are made.  If
    you did, it would be intuitive how some of the Eagle layers map to layers
    of a PCB.
    Briefly, a PCB can the thought of as a sandwich of layers.  For simple
    double sided boards from top to bottom these are the top silkscreen, top
    soldermask, top copper, the PCB material itself (usually FR4 fiberglass),
    bottom copper, and bottom soldermask.  You might also have a bottom
    silkscreen for a more complicated board.
    Go read up on PCB construction, then how the Eagle layers map to that will
    make sense.
    Olin wrote on Thu, 31 March 2011 07:27
    Eagle, but that you don't understand how PC boards work and how they are
    made.  If you did, it would be intuitive how some of the Eagle layers map
    to layers of a PCB.
    will make sense.
    euh, no. I am quite aware of how a PC board is made, be it single
    double-sided, or multi-layered. I know what the solder mask does and what
    delimitation it is supposed to have around the components. This is not my
    first succesfully-manufactured board I've designed...
    Funny enough,I asked a co-worker if he would refer to the Stop layer (he
    doesn't use Eagle) as having "holes" in it, and he looked at me with
    question marks in his eyes..
    He then suggested that maybe the person who said that meant "openings"...
    Then suddenly it all made sense.
    You see, it isn't a question of my lack of knowledge, it is a question
    using the correct word to describe the Stop layer. when I read holes I
    thought to myself: round small openings. That's a hole. Not, "a perimetric
    delimitation around an area", which opening would have suggested.
    I was hoping not to have to defend myself in such a manner but it seems as
    though people would rather assume that I lack knowledge.
    anyway, another reader on another related topic has found a solution. I
    shall go try that out now.
    anyways, thanks for your replies, I hope I don't come off as too defensive.
    >> to layers of a PCB.
    >> will make sense.
    The people who write the EAGLE software do not have american english as
    a first language, some of the terms in EAGLE's english are not clear.
    solder-stop is another name for solder-mask and the stop in tStop refers
    to this.
    There are a lot of cases where you have to be flexible in your
    interpretation of EAGLE's terms.  image For backward compatibility with
    scripts and ULP's, the historic, perhaps misleading, terms are here to stay.
    On Wed, 30 Mar 2011, Owen wrote to us saying :
    >Well Mr Pearce,
    >order to understand
    I apologise for being snarky. However, please do not try to suggest that
    your inexperience with Eagle was under attack. I am actually very
    tolerant of "newbies". What set me off was that I was repeating Olin's
    earlier answer. I have less tolerance than I should of people who need
    to be told things twice. Sorry.
    this message are    |
    Don't believe a     |
    word.               |
    Gary Gofstein wrote on Thu, 31 March 2011 16:19
    stay.
    When I first started learning Eagle the poor choice of command names caused
    considerable confusion.  For example, CUT does a COPY, and COPY never seems
    to do what you want.  WIRE draws lines except when they represent wires,
    then you use NET.
    It is pretty universally understood that CUT does a copy and delete.  This
    was well established before Eagle was written.  It is totally beyond me
    what Klaus and company were thinking when they named the copy command
    "cut".
    Another annoying "feature" that is due to Eagle's origin is that vertical
    text reads up not down.  That is the german convention.  However, I am
    using the english language version, and judging from the number of
    downloads and the activity in this forum, the english language version is
    much more popular.  Is this ever going to get fixed?  It's been reported
    as a problem long ago.  At the very least there should be a setting for
    default vertical text direction.  Currently this is a outright bug in the
    english language version, but Cadsoft doesn't seem to take is seriously
    because it looks right in the version they use.
    I did not think about that... the famous language barrier. However the
    level of english spoken on the forum, I find, is of higher quality than
    other forums I visit.
    ain't that true. I'm not surprised to see that other (non-german) members
    find this weird. But once you know it... lol
