EAGLE User Support (English) How to create library part with thermal pad?
  • Replies 55 replies
  • Subscribers 180 subscribers
  • Views 6134 views
Hi there,
I was hoping someone could give me the recommended flow for creating a
library package with a thermal pad.  I'm using an LME49600TS/NOPBLME49600TS/NOPB which has 5
pins and a thermal pad.  The pad is electrically connected internally
to Vee.
I initially tried just marking a tStop region in the shape of the pad
hoping that if I just drew a polygon over it in the layout editor and
hit ratsnest, all would work out.  All I got was a polygon around the
pad not connected to it.
I then tried to draw a polygon in the package and name it something but
I discovered you can't name polygons.  A square pad would work I guess
but this isn't the shape of the pad which is in the shape of a 'T'.
Any pointers on the correct way of doing this?  The demo board doesn't
have the pad polygon connected to the Vee pin so that shouldn't be an
issue.
Thanks, Shareef.
    Former Member over 14 years ago in reply to Former Member +1
    Am 04.04.2011 21:58, schrieb Gary Gofstein: On 4/4/2011 7:00 AM, Olin Lathrop wrote: >> Klaus Schmidinger wrote on Mon, 04 April 2011 04:35 >>> Well, I'm sorry I got into contact with the GED before I…
    Robert Pearce wrote on Thu, 31 March 2011 17:43
    On Wed, 30 Mar 2011, Owen wrote to us saying :
    >Well Mr Pearce,
    >as much as I thank you for your help, I must admit that I am not as
    >knowledgeable using Eagle as you might have thought I was.
    <snip>
    >So, no need to insinuate something by saying that I need less
    syllables in
    >order to understand
    I apologise for being snarky. However, please do not try to suggest
    that
    your inexperience with Eagle was under attack. I am actually very
    tolerant of "newbies". What set me off was that I was repeating Olin's
    earlier answer. I have less tolerance than I should of people who need
    to be told things twice. Sorry.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    OK, I understand. Although not a newbie, I certainly am no expert, even
    though I use Eagle almost daily in my work. I guess each person's level of
    experience is ... subjective.
    I will try to read answers more carefully in the future as it is true that
    I missed one word which made a difference. I am guilty of this, it's
    happened before.
    cheers,
    Redcutlass
    ps: In any case I was able to properly design my footprints using the
    Restrict layer. Fabulous!
    Olin Lathrop wrote:
    Another annoying "feature" that is due to Eagle's origin is that
    vertical text reads up not down.  That is the german convention.
    However, I am using the english language version, and judging from
    the number of downloads and the activity in this forum, the english
    language version is much more popular.  Is this ever going to get
    fixed?  It's been reported as a problem long ago.  At the very least
    there should be a setting for default vertical text direction.
    Currently this is a outright bug in the english language version, but
    Cadsoft doesn't seem to take is seriously because it looks right in
    the version they use.
    Off subject apologies.
    I had not previously known of this  'text reads down' preferrence and agree
    that if a significant portion of the market desires it then it should be
    catered for.
    I don't see the default as a German convention. 'text reads up' is my
    preferrence as rotating the document clockwise (right) is my preference.
    Are you saying the North American convention is to read a document from the
    bottom or the left.
    Cheers
    Warren
    warrenbrayshaw wrote on Fri, 01 April 2011 15:46
    the bottom or the left.
    I don't think of it as reading a document from a particular side.  However,
    pretty universally when you see vertical text here it is written going
    down, not up.  This applies to signs, the spines of books, and just about
    everything else.  Vertical text going up looks stupid, at least here.
    For example, if you look at a german bookcase the titles will read up, but
    here they will read down.
    All this has been pointed out to Cadsoft before.  They don't seem to care.
    They really should enhance text placement in general.  Eagle is workable
    but very primitive in that regard.  Most software that lets you graphically
    place text allows you to chose the anchor from one of the 9 corners, center
    of edges, and center.  After that should be choice of direction, with
    something better than the rather awkward "spin" flag to fix things.
    I actually wrote a ULP that looks for vertical text strings.  It sets the
    spin flag, orientation, and moves the origin around so that the text reads
    down instead of up in the same place.  It mostly works, but it does move
    the text around a little bit.
  • kcadsoft
    kcadsoft over 14 years ago in reply to Former Member
    On 04/01/11 14:58, Olin Lathrop wrote:
    It is pretty universally understood that CUT does a copy and delete.  This
    was well established before Eagle was written.  It is totally beyond me
    what Klaus and company were thinking when they named the copy command
    "cut".
    The user interface of EAGLE was inspired by the "Valid GED", a graphical
    editor I was working with during my time at Siemens. In that editor the
    COPY command worked in such a way that you select the command and then
    click on the object you want to copy. Then you move the copy to the
    desired target location and click again to place it.
    The CUT command in the GED did only copy the selected group into
    the "cutting" buffer for later use with PASTE. It did not delete
    the group from the original drawing.
    Well, I'm sorry I got into contact with the GED before I was "contaminated"
    with Windows, but that's the reason why COPY and CUT behave as they do
    in EAGLE.
    To get this recurring discussion over with once and for all I suggest
    the following changes for version 6:
    - The COPY command, when activated, just copies the group into
       the buffer and terminates immediately. It will no longer be able to
       select individual objects for copying. To copy individual objects
       you will have to draw a group around each object, do a COPY and then
       a PASTE. Unlike the former CUT command, which allowed the user to
       define a reference point to "cut" the group at a particular location,
       at which it will be attached to the mouse cursor when doing a later
       PASTE, there will be no such reference point in the COPY command
       (as usual under Windows, the group will be selected at its center).
    - The CUT command becomes a combination of COPY, followed by a DELETE
       of the group. Since board and schematic
       are connected via forward&backannotation, some limitations apply
       to the DELETE command (as is already the case now). Therefore it
       may not be possible to actually delete the entire group. In such a case,
       the group that has been copied into the buffer may contain objects
       that have not been deleted from the drawing. Also, when doing a CUT
       in the schematic, the group that gets copied into the buffer will
       contain only the objects from the schematic, while the DELETE will
       also delete the related objects from the board.
       Alternatively (and since it most likely would cause quite some
       confusion in boards and schematics) the CUT command could be
       removed entirely.
    - The PASTE command remains unchanged.
    These changes should make EAGLE's COPY/CUT mechanism as "Windows like"
    as possible. Whether this behavior is actually useful, is another
    question...
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    Former Member over 14 years ago in reply to kcadsoft
    That would be a great disadvantage. I often use COPY on single objects.
    It wouldn't be any problem to keep that (with use of the LMB), IMHO -
    even if the function for dealing with groups was changed as described above.
       a PASTE.
    Horrible.
    ...so you'll run into many grid problems. Selecting the reference point
    is a very essential feature of the (current) CUT command.
    question...
    Exactly. I hereby request YAES (yet another eaglerc.usr switch) to
    restore the current behaviour.
    (Additionally, what about scripts that use the old command syntax?)
    Tilmann
    P.S. Yes, you have to learn the different command behaviour compared to
    windows standard. Yes, you also need to get used to it. But after all,
    EAGLE is a complex and powerful design tool - and in the current
    implementation, you get the maximum /working efficiency/, and that's
    what counts. The need to learn the tools is common for all complex ones.
    Perhaps you just need to /rename/ the existing commands to avoid (or
    reduce) the windows users confusion? (Script handling should still be
    considered, however.)
    Am 04.04.2011 10:35, schrieb Klaus Schmidinger:
    >> "cut".
    in EAGLE.
    removed entirely.
    question...
    Klaus Schmidinger
    Well, I think this is going to be a very bad idea. Apart from the fact
    that some people think that they are the nabel of the world does not
    mean that they are allways right.
    You can bet that your suggested change will not close the subject "once
    an for all".(Unfortunately)
    Eagle is also not written for windows alone but also for linux etc.
    But mostly window users go up the wall if something is not windows like.
    (I shall not start a discussion about all the windows problems now, but
    I am a windows user too).
    So some people stumble over "cut" and they have not, and did not want,
    learn that in over twenty years.
    I bet that if the word "salary" wold be exchanged to "deptor" they would
    accept that in 10 seconds image
    I use the "copy" very often in creating schematics und it would be worse
    now allways first painting a group around a device just to copy it.
    Why not just simply rename the "cut" into "groupcopy" or whatever you
    like and leave the funktions as they are.
    A far better idea is to have the complainers come up with a suitable name.
    Joern Paschedag
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:inbvt9$fuu$1@cheetah.cadsoft.de...
    The CUT word is a real world reference to cutting something from a
    sheet of paper, or an old newspaper editing desk. If you cut something
    , it is either deleted or moved+pasted somewhere else. The problem with
    this reference to Eagle is that brd and sch works "in parallel", so if you
    cut in either the traditional way, you have not defined what is going to
    happen to the other part of the project.
    Maybe the function CUT should be renamed. (how about "CLONE" or
    "DUPLICATE"?). To make both this and the copy functions more usable I would
    also add more to it, like different options to what happens to the
    copied/cloned netnames when you paste it. This could have been done after
    copying as a separate function (edit paste buffer nets), or when pasting. It
    is very intuitive to say how this is going to happen GUI wise, but in
    command space it may be more difficult to visualize. Maybe the paste buffer
    should get its own project.pastebuffer(index).sch and/or
    project.pastebuffer(index).brd reference and work much like the main
    structure, while commands could get a netname prefix to work in the
    pastebuffer, so that a net named "net" would be referred to as
    "$paste(1).net" after a copy or clone to buffer 1. (I've assumed there will
    be multiple paste buffers here).
    The Eagle window could even have a "edit pastebuffer" mode, where the stuff
    in the pastebuffer can be opened and edited.
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:inch25$8ic$1@cheetah.cadsoft.de...
    Sorry for the left overs..
    I could add that there should be a syncronized area clone/copy mode, where
    you select a group window on both the sch and brd, and where clone/copy
    checks if they contain the same parts and nets, and works on the selected
    data in a wysiwyg way.
    It should give error if nothing is common, or warning if one selection
    contains other nets/parts than the other.
    "contaminated" with Windows,
    It's not a Windows thing.  The copy and cut convention was around well
    before that.
    The current problem is one of naming, not of how the commands actually
    work.  I think that changing anything now will cause too much pain to
    people that have managed to get used to how it works, and more importantly
    that have scripts and ULPs that rely on the existing names.
    The fix is therefore documentation, not changing code.  There should be a
    "Introduction to Eagle" section or something new users will find that
    explains the various unobvious things about Eagle.  CUT doing just a COPY
    should be prominently mentioned, and what COPY really does and when you'd
    use that over CUT also needs to be made clear.  That would have saved me a
    bunch of time back when I started.  (actually I'm still a little hazy about
    when to use COPY versus CUT, although I haven't spent the time to
    deliberately try and educate myself either)
    Olin wrote on Mon, 04 April 2011 10:00
    a "Introduction to Eagle" section or something new users will find that
    a bunch of time back when I started.  (actually I'm still a little hazy
    about when to use COPY versus CUT, although I haven't spent the time to
    I don't really agree with that conclusion Olin.  Here is what I would
    suggest:
    1)  We keep some way of keeping the current methodology for all the old
    farts who can't rewire their brains and for the current library of scripts
    that rely on the copy and cut commands to do what they normally do.
    2)  Provide some method to use a new framework of cut, copy, paste that is
    more inline with everything else in the world now.
    So I would suggest an option on the SET command that flips back and forth
    between these two modes.  For the GUI I would default to use the new modes
    (old timers can change their eagle.scr file to easily get back to the old
    way of doing things, newbies couldn't do the opposite easily).
    I would further suggest that the script command behaves the opposite--it
    assumes the older mode and would take a command line option to force it to
    use the new functionality of cut, copy, paste.  That way the old scripts
    will all work as expected and new ones can tell the command to use the new
    mode.  The scripts could also just use the SET command to get the correct
    mode to start and restore it when complete.
    Then I think we get the best of everything--backwards compatibility and a
    way for current users to get back to the way it was.  But new users get the
    more modern functionality of these commands and have a better experience
    with EAGLE out of the box.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
