EAGLE User Support (English) Lost Consistency
  • Replies 8 replies
  • Subscribers 178 subscribers
  • Views 2027 views
Lost Consistency
I wonder if any one provide assistance.  I have lost consistency on my
board.  I have tried various methods to fix but without success.  I have run
ERC and identified say this error below:
"Different connections in IC2B pin OE and pad 4 (GND/ none)"
I interpret this to mean there is a net connection on GND but NOT on pin OE.
However there is deffinately a net connection in my schematic as I can move
the GND symbol or my device (74HCT125D) symbol and see that the net is
connected to both device and ground.
I have also tried deleting devices and nets and added new devices from
library, with no success.  I have also deleted nets and renamed there
another name and still no success.
How can I fix this ?
Many thanks,
Jim
    On 3/7/2011 11:36 AM, Jim D wrote:
    Many thanks,
    Jim
    Hi Jim,
    This a common issue, especially for new users. What the error is telling
    you is that on your schematic you have the OE pin connected to ground,
    however in the board design no such connection exists.
    Here's a procedure for regaining consistency:
    To regain consistency run the ERC in the schematic, it will point out
    all of the consistency errors. Do whatever you have to do to correct
    them. If the errors are missing parts in schematic and board, then erase
    the parts from either the schematic or the board that way both are the same.
    If there are net issues, again delete or add any traces that may be
    necessary. If you find that the number of net errors is very large then
    you can correct them all by using a netscript.
    1. In your schematic go File->Export-> Netscript. Save the Netscript and
    make sure you know where it is.
    2. In your board file turn off all of the layers except 19 Unrouted. You
    should only see your airwires. If you've routed the board you're going
    to have to ripup everything for this method to work. Once you see all of
    your airwires, select them as a group and delete them.
    3. Turn all of your layers back on
    4. Now there's an icon at the top of the screen that looks like a sheet
    of paper with the letters SCR, click it. As an alternative, type Script
    -> Enter in the command line.
    5. Find the netscript we created earlier and run it. You'll see that all
    of the airwires are back. If you run the ERC again, you'll see that all
    of the net errors should be gone.
    hth,
    Jorge Garcia
    Former Member over 14 years ago in reply to Former Member
    Am 07.03.2011 19:38, schrieb Jorge Garcia:
    >> Hi,
    >> run
    >> pin OE.
    >> move
    >> Many thanks,
    >> Jim
    Hi Jim,
    same.
    hth,
    Jorge Garcia
    In addition to Jorge I may add the following: It is perhaps easier for
    you to remove the mentioned IC from the .sch and .brd. Important is that
    you have consistence again before adding more parts.
    Joern Paschedag
    "Jim D" <j.doyle@optosci.com> wrote in message
    news:il31ir$4g5$1@cheetah.cadsoft.de...
    run ERC and identified say this error below:
    OE. However there is deffinately a net connection in my schematic as I can
    move the GND symbol or my device (74HCT125D) symbol and see that the net
    is connected to both device and ground.
    Fixing inconsistancy is easy IF you understand it, but its more complex than
    you may think. There is a lot of confusion around on how this works.
    First, to resolve a problem, you need to fix the problem AND run ERC again
    to get the design into a resolved state. If you "fix" too much, you end up
    with different inconsistancies.
    To fix your problem you need to go to the board and use the "signal"
    command/button and click the pad (hold cltrl while clicking to catch it if
    its outside the grid). The second end of the signal can be either:
    -a loose end (the pin gets a new netname wich you can rename to GND). Click
    on an empty space and left click again to confirm, and esc to end it. You
    will now get an airwire cross on the pad (meaning it has a net, but it
    doesnt go anywere). You can now do the "name" command on it and you will get
    an airwire.
    -a second pad or via from the same signal (unfortunately connecting to a
    wire doesn't work)
    Click ERC again to check if it helped.
    Hi Jorge,
    Thanks for getting back to me.
    Regarding your feedback, I understand your guidance. However, can I provide
    another example of my Lost Consistency problem, to aid more understanding.
    I have a 4 pin single inline connector directly connected to a 64 pin
    backplane connector, (I only tell you this so that you understand it is a
    simple direct connection).
    Again no matter if I delete all 4 nets and then add new nets, no matter if I
    delete 4 pin connector, from schematic and PCB and then add new connector, I
    get the Consistancy error "Different connections on SV10 pin 1 and pad 1
    (10RX1+ / none"
    SV10 = 4 pin connector
    10RX1+ = net name on pin 1
    For this connector and with the remaining 3 pins of the connector, I get the
    same error. This error type is the same or similar for a further 79 error
    instances in my design.
    My PCB has been tracked a great deal so deleting all tracks as you
    previously suggested is not a good option for me.
    I have checked that there are no such things as missing parts etc between
    schematic and PCB. Also to point out, there are some devices which have air
    wires attached to some pins while not being attached to other pins on the
    same device.
    Is there another way to achieve consistancy?
    The option you previuosly stated seems a bit of sledge hammer to crack a
    nut.  I'm also perplexed as to how this consitancy issue has arose since I
    always close both PCB and Schematic by closing Control Panel, and I never
    work with either the schematic or board open individually - they are always
    open as a pair and closed as a pair.
    Anyway I hope this provides a greater picture as to my problem, hope you can
    help.
    Many thanks.
    Jim
    Many thanks,
    Jim
    news:il4vih$fdo$1@cheetah.cadsoft.de...
    The simplest way is to delete all nets to the conflicting pins both in sch
    and brd. In sch its easy.
    In brd you need to get an airwire to the pin only before you delete it.
    -If there is a wire going to the pad, start by deleting that.
    -Do ratsnest
    -Llook for an airwire. Make sure there is just ONE airwire going to the pad.
    If you get two, you will have more problems after deleting them because you
    will split a net into two different net names. To fix that, do a temporary
    route around the pin (doesnt matter if you overlap) and do ratsnest again.
    Note, if the pin is surrounded by filled polygons, you should temporary
    rename the polygon to something else and redo ratsnest.
    -When you got one airwire to the pad, delete THE AIRWIRE.
    -Redo temporary changes
    -Now try ERC again.
    -Do ratsnest
    -Now try ERC again.
    After removing erroneous nets, you must run ERC again for the brd and
    sch to become consistent again BEFORE you reconnect what once was
    removed. As long as there is an inconsistency noting you do in sch will
    end up in brd.
    1) Remove
    2) ERC
    3) Repeat 1) and 2) until consistency has been achieved
    4) Add what was once removed.
    5) Celebrate
    Breg
    Vidar(Z)
    I now have Consistency in my design, thank you Morten and all for your great
    input.
    In the interests of more people having a similar problem, (experienced or
    inexperienced) here is what I did.  I had tried to fix as directed by Morten
    below but for some reason I could not get the Airwire Cross to appear on the
    pad of interest. I could place a signal airwire on the first pad of
    interest, but when I double click mouse on empty space + press "esc", no
    Airwire Cross would appear.  I tried this dozens of times with no success.
    To get round this I tried typing the command directly at the top of the
    board window using following structure:
    signal (signal name) (device reference) (pin No) (second device reference)
    (pin No of second device)
    eg1 - signal 7RX1+ X5 C9 SV7 3
    eg2 - signal GND IC1 7 IC2 7
    Rather than type this for every instance of Consistancy error I used the
    arrow keys and the previous entered cammand line appeared then I just simply
    edited this line to suit the next error signal.
    In the instances where there were tracks already on the PCB but these were
    also inconsistant, I pressed the "signal" button and clicked on thefirst pad
    with track still in place.  I then dragged mouse, with Airwire still
    attached, to second pad and single clicked mouse to attach Airwire.  I then
    pressed "esc" to release Airwire from mouse.  Next I pressed "ERC" button.
    Hence, particular error was deleted from error list.
    Working my way through all errors in this manner resulted in bottom of
    schematic or board window displaying message
    "board and schematic are consistent"
    Many thanks - hope this adds to knowledge base, at least for newbies.
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:il4o1j$4au$1@cheetah.cadsoft.de...
    >> Hi,
    >> can move the GND symbol or my device (74HCT125D) symbol and see that the
    >> net is connected to both device and ground.
    than you may think. There is a lot of confusion around on how this works.
    Click on an empty space and left click again to confirm, and esc to end
    it. You will now get an airwire cross on the pad (meaning it has a net,
    but it doesnt go anywere). You can now do the "name" command on it and you
    will get an airwire.
    wire doesn't work)
    I have a problem similar to Jim Doyle's, but with a twist. I've begun a
    board revision which includes replacing a few parts with different types
    and correcting a couple library parts. These were 2 connectors, same type,
    4- and 5-pin versions. In the first edition of the board, we got the order
    of the pins reversed from what the customer wanted, so I edited the library
    parts to reverse the pin order (1=>5, 2=>4, ...). when I did the update
    library on the board, the 4-pin switched correctly, making the connections
    correctly, but the 5-pin kept the connections in the same physical
    location, i.e., now connecting to the wrong pins (except pin 3, of course).
    It looks like I need to do something like Doyle did to remove those
    inconsistencies. What do you think happened here?
