EAGLE User Support (English) Finding disconnected nets
  • Replies 16 replies
  • Subscribers 179 subscribers
  • Views 2484 views
I have some disconnected nets that are so small I can't find them.
Being new to this tool, I assumed I could highlight them with SHOW,
but I can't see anything highlighted. So I tried to use the LABEL
command from the text entry window, but I can't find a syntax that
does not give an error. I tried changing the width of the net, nothing
changed. I am really stumped. How do you find small disconnected nets
and delete them? I know their names from the rules check, so there
must be some simple command to just delete them.
    Am 27.03.2011 04:52, schrieb Mike Jones:
    You din't mention sch/brd nor which version.
    Try command "show @ netname" that should draw a box around the net
    (assuming ver. 5.11.x)
    Joern Paschedag
    Former Member over 14 years ago in reply to Former Member
    Joern,
    It is 5.11.0 Mac. Schematic.
    I tried show @ netname, and it draws a box around the whole page, not a
    single net. Also, when I run error checks, the dialog box lists these and
    other errors. Other errors I can double clock and it does a show, and
    properly puts a box around the error. The disconnected net errors do not
    behave this way.
    Mike
    Try to move (F7) your nets. If there is an unconnected stub, it will show,
    so you can delete it.
    r
    Ok, I typed:
    MOVE N$101
    Got message:
    Unknown part N$101
    What is the syntax that tells the command line N$101 is a net?
    I tried MOVE 'N$101' and MOVE NET N$101, etc
    There must be some syntax that tells it you are acting on a net rather
    than a part.
    The doc on move does not seem to imply you can move a net.
    show,
    r
    It is better to click with the mouse into a net & move it. so you can see
    any stubs.
    r
    I have moved every node and every part and there are no stubs, but the
    error check still says I have disconnected nets. My assumption is there
    is a small island of wire somewhere I can't see. When I do a SHOW @ N
    $XYZ, where XYZ is the node, I get a box around the whole page, but 4X
    bigger than the schematic. It is so big that I can't unzoom to see the
    whole box, rather than a stub. I am wondering if I have some island of
    trace outside the schematic area that is causing the box to misbehave.
    So I am stuck and not sure how to find it. Seems there needs to be a
    simple command that says DELETE N@XYZ to deal with this.
    Also, I have about 8 of these. It is hard to imagine getting 8 islands
    of wire I can't see. So I am wonder if there is a bug and I have some
    habit of wiring parts that trips it up.
    see
    any stubs.
    r
    On 3/27/2011 8:02 AM, Mike Jones wrote:
    Joern,
    behave this way.
    Mike
    You are in SCHEMATIC using ERC not DRC? Then I don't think you have
    airwires. These are a similar problem that comes from incomplete routing
    of a net.
    so let's see, if you are really in schematic only, you need to know that
    EAGLE doesn't actually require a net to connect to anything. If you have
    a dangling net, that's not an error, in fact you can use the NAME
    command on such dangling nets to make connections. There is no special
    symbol in EAGLE to connect a net to another, just give them the same
    name. But, I don't think this is what you have, I think...
    Maybe you have run into EAGLE's "implicit nets". Say you have a device
    and it has a pin for power, the name in the library (yes library) for
    that power pin is the net it will connect to! If you don't have that net
    anywhere in your schematic ( usually tied to "supply" symbol) then the
    net is not connected anywhere and should warn or error on ERC.
    I think v5 has a way to turn this behavior off. ( how would you know
    what net it connects to when you make the library anyways?). but I would
    look at your device's pins for those with direction==power or supply and
    make sure you know what your doing.
    HELP PIN for some more info about implicit nets or look it up in the
    Manual. I personally hate this behavior and I do not use the Sup or
    Power pin directions. I feel the chance of it connecting something I may
    not want connected is too high.
    hope this helps
    I know of "no pins on net ..." and "Segment of net ... has no visible
    connections ...".
    I never encountered an ERC warning with "disconnected" though.
    Could you please post the exact error message ERC gives you?
    Lorenz
  • Richard_H
    Richard_H over 14 years ago in reply to Former Member
    Am 29.03.2011 00:20, schrieb Mike Jones:
    Mike,
    please send me the schematic file by private email. So I couild take
    a look into it and try to get out what the problem is.
    Richard Hammerl
    Am 29.03.2011 07:48, schrieb Lorenz:
    connections ...".
    RUN find (enter)
    press Help button ...
    Alfred Zaffran
    _____________________________________________________________
                                 Web:   <www.cadsoft.de>
    Geschäftsführer: Dipl.-Ing. Klaus Schmidinger, Bodo Badnowitz
    Former Member over 14 years ago in reply to Richard_H
    Mike,
    Mike,
    Is your grid setting in the schematic 0.1"?
    Enjoy,
        - Chuck
    The problem went away. I had rebooted my Mac yesterday, and now the problem
    is gone. I created an error just to be sure the ERC actually ran, and all
    the disconnected nets are gone, so I can't give the precise error until the
    problem occurs again.
    >> Mike,
    Mike,
    Enjoy,
        - Chuck
    >> Mike,
    Mike,
    Enjoy,
        - Chuck
