EAGLE User Support (English) Several ground nets
  • Replies 11 replies
  • Subscribers 178 subscribers
  • Views 1079 views
Several ground nets
in my current design I need a lot of ground nets, each one isolated from
the others.
For example: I use 8 ADM3251. The isolated side should be not connected
to the isolated side of another AMD3251.
I also use 8 digital isolator and so on...
Ok, I could draw a net without any ground symbol but it's not very clear
to read.
So, how to draw the same supply pin (e.g. AGND) but with a different
name so they won't be connected together?
Thanks!
Marco
    On 04/07/2011 07:51 AM, Marco Trapanese wrote:
    the others.
    to read.
    Look in supply2.lbr.  There are several ground symbols labeled 0V, AGND,
    DGND, GND, GND1, GND2, etc.
    Enjoy,
        - Chuck
    Marco Trapanese wrote on Thu, 07 April 2011 07:51
    There are a bunch of examples in my POWER library included in the Eagle
    Tools release at http://www.embedinc.com/pic/dload.htm.
    the others.
    to read.
    In that case naming them might be best. Maybe SYSGND, and then ISOGND1,
    ISOGND2 and so on. Always think about that archaeologist finding the
    time capsule with your schematic in 500 years, he needs to understand image
    Regards, Joerg
    Former Member over 14 years ago in reply to Former Member
    Yes, but I don't want to use 20+ different symbols. May I just rename
    the nets?
    Marco
    Thank you!
    Marco
    the nets?
    Ideally yes but I have tried that with power symbols and just renaming
    in the schematic messed up the PADS netlist. So I made library parts for
    all the voltages I usually need, all with the same symbol.
    It's not that big a deal. For example, you could make a library
    "trapanesesupply.lib", then add a dozen grounds. A normal one, then
    ISO1, ISO2 and so on. In my experience it makes schematics easier to
    read for others if the isolated grounds have a more unusual ground
    symbol (but all of those have the same type of symbol).
    Regards, Joerg
    Yes. It's exactly what I want and what I was going to do.
    Because all of them shares the same symbol I was wondering if I may
    avoid to create n symbols, but only changing their names.
    Anyway the straight way seems the better one!
    Marco
    >the nets?
    supply symbols use a special kind of pins that rename the net they get
    connected to.
    You can rename the net again though, but then you will get into deep
    s... really fast 8-)
    So the only clean way for using supply symbols is to create one for
    every separate supply net you need.
    Lorenz
    Thank you!
    Marco
    Hi Marco,
    I hope you are doing well. Try the new make-supply-symdev.zip that's up
    on our website. It's a simple ULP which creates a variety of supply
    symbols, it should speed up your work considerably.
    hth,
    Jorge Garcia
    Ok, thank you for the clarification!
    Marco
