EAGLE User Support (English) drill files, viewmate
  • Subscribers 184 subscribers
  • Views 1851 views
Former Member over 15 years ago
I'm trying to generate a CAM output and preview it before submitting to PCB
manufacturer. I read the recommended Al Williams book.
I'm using ViewMate to preview the files.
All the layers are OK, except the drills.
I found this topic that seems to solve the issue (haven't tried):
http://www.eaglecentral.ca/forums/index.php?t=msg&goto=17274&S=a61937e116c7338a6f333b00d2f75ac6
It seems that the problem are the leading zeros that ViewMate needs.
But I'm confused, the point of previewing the files is to ensure that the
manufacturer will understand them. Maybe if I change the .def file the
manufacturer will have problems ?
So my questions are:
What format should I use to generate/preview the drills to avoid problems ?
Could you please point me to a tutorial about excellon files ?
    Hi Frikosal,
    Unlike the Gerber format which has a single standardized format, the
    Excellon drill format is flexible. All you have to do is let the viewer
    know what format your drill file has.
    EAGLE exports the excellon file in 2.4 Leading Zeros Suppressed Absolute
    inches format. If you let Viewmate know what format you're using you'll
    see that everything looks as it should.
    Boardhouses usually have more sophisticated tools and can determine the
    format without you telling them. With that said, don't take chances
    always let your manufacturer know what format your drill file is in.
    hth,
    Jorge Garcia
  • Richard_H
    Richard_H over 15 years ago
    Am 03.05.2011 10:06, schrieb frikosal:
    Usually the EXCELLON device is readable by all manufacturers.
    You could add a further EXCELLON device as mentioned in the
    message you linked to so that it fits to Viewmate.
    I'ld recommend to use the following definition for EXCELLON. It has
    a better init sequence that should work with all viewers and
    manufacturers. Simply try it with Viewmate as well.......
    Type     = DrillStation
    Long     = "Excellon drill station"
    Init     = "M48\nINCH,LZ,00.0000\n"
    Reset    = "M30\n"
    ResX     = 10000
    ResY     = 10000
    ;Rack     = ""
    DrillSize  = "%sC%0.4f\n"        ; (Tool code, tool size)
    AutoDrill  = "T%02d"             ; (Tool number)
    FirstDrill = 1
    BeginData  = "%%\nM72\nG90\n"
    Units    = Inch
    Select   = "%s\n"                ; (Drill code)
    Drill    = "X%1.0fY%1.0f\n"      ; (x, y)
    Info     = "Drill File Info:\n"\
                "\n"\
                " Data Mode         : Absolute\n"\
                " Units             : 1/10000 Inch\n"\
                "\n"
    Richard Hammerl
    Instead of ViewMate, I use gerbv which allows you to view Gerber and
    Excellon files.  It's an excellent program, it's free and you can
    download it at http://gerbv.gpleda.org
