EAGLE User Support (English) Mousebites?
  • Subscribers 179 subscribers
  • Views 1710 views
Mousebites?
Hello Forum.
I am making a 6 layer PCB and one part of the circuit is supposed to be
able to physically break off so it can be de-attached. I though it could be
made with 'mousebites' (don't know if it got another name, but it is just
like the areas between the individual PCB's when panelizing - Example:
http://blogs.oracle.com/spotee/resource/eDAQ_Panel.jpg).
My questions is:
1. How is this done in Eagle?
2. I have supply-/ground-layers on some inside layers and groundfill on
both top and bottom layers. should I minimize theese aound the
'break-off-area'?
Best regards
Stg.
  • KennyMillar
    KennyMillar over 14 years ago
    I do this often on 2 layer boards, and all I do is draw the 'mousebites' on Layer 20 - eagle takes care of adjusting the POLYs
    I have never tried it on 4 or 6 layer boards though.
    Ok, so you draw a line in the dimensionlayer?
    Steen wrote:
    Hello Forum.
    be able to physically break off so it can be de-attached. I though it
    could be made with 'mousebites' (don't know if it got another name,
    but it is just like the areas between the individual PCB's when
    My questions is:
    on both top and bottom layers. should I minimize theese aound the
    'break-off-area'?
    Best regards
    Stg.
    I  recommend googling "pcb mouse bites" . Many good board house requirements
    documents are returned. The variety of their approaches to breakoff and
    routing is valuable education.
    How you address the requirement in Eagle depends on whether you go with
    mouse bites or v-scoring. Board tickness comes into it.
    Talk to your board house as their requirements will govern how you do it in
    Eagle.
    Keep copper well away from the break-line. It makes it harder to break and
    ideally you should not expose copper after the break.
    You application is internal to your board design so you should be able to
    specify your break without being tied to the style of break-offs the board
    house panalization utilizes.
    HTH
    Warren
    Former Member over 14 years ago in reply to Former Member
    Thanks Warren. I think I will contact the boardhouse to be sure how it's
    done then.
    "Steen" <stg@logos.dk> wrote in message
    news:iqteeg$7p5$1@cheetah.cadsoft.de...
    Hello Forum.
    be
    My questions is:
    'break-off-area'?
    1- This is just done by "milling and drilling". Normally this is done by the
    manufacturer and is part of the panelizing process, but if you want to make
    panels yourself, you just define the shape by drawing in mill layer, and put
    small holes in the perforated tabs. The pick&place manufacturer knows best
    what sizes you should use.
    2- If you do this with mill and drill, the spacing will be taken care of by
    DRC parameters (edge clearance), and tracks will be checked by a DRC.
    done then.
    This is a good approach.
    If you are looking for more suggestions there have been at least a
    couple of other threads on this topic in these newsgroups where it is
    described as a "break away", e.g. :
    "Break away rails" 6-Aug-10
    I use the (old) IPC-SM-762 fig 3-31 suggestion.  It has always been OK
    for me but YMMV.
    Neil
