EAGLE User Support (English) isolation wire
  • Subscribers 178 subscribers
  • Views 235 views
isolation wire
jgowen
jgowen over 14 years ago
to:Eagle Forum
re:"isolation wire"
Thu 6/23/2011 12:51 pm
In the Eagle Version 5 "8th Edition" manual, in section "7.8 Routing
Multi-Layer Boards", "Supply Layers", it says "After routing, you should
draw an isolation wire around the layout. This prevents short-circuits at
the edges of the board."
1. Since the "supply layer" "is represented with an inverse display", I
assume this "isolation wire" is actually a no-go area around the board,
which would prevent conductive signals from showing up in metal on the edge
of the board?
2. Surely one should do this before routing? At least, that's what I'm
doing, and stuff seems to work. At least the suggestions on page 197 "SMD
Boards With Supply Layers" seems to do OK.
j.g. owen * email:
web: http://owenlabs.org
  • Richard_H
    Richard_H over 14 years ago
    Am 23.06.2011 19:04, schrieb owen_bda4:
    of the board?
    This is correct.
    No problem to draw this wire before routing.
    Richard Hammerl
