EAGLE User Support (English) XREF flag options
  • Replies 7 replies
  • Subscribers 179 subscribers
  • Views 1065 views
XREF flag options
rtzaudio
rtzaudio over 14 years ago
I would like to see an option within the XREF object itself that
indicates whether the flag outline & cross ref data are drawn or not. I
understand this is controlled by the global XREF settings now, but it
sure would be nice to use this feature to label the ends of nets also
that don't necessarily go off to another sheet.
Also, the xref sheet/row/col data should print AFTER the net label name
for rotation values >= 180 degrees (eg when on the left hand or bottom
side of net end).
I still want to see other options for the flag style so that allows
drawing like Orcad with the double arrow head styles (eg ->> NETNAME and
-<< NETNAME) rather than the framed arrow around the text. Another
option would be to draw a small port flag and put the text outside to
the left or right.
In general, I just don't like the arrow border drawn around the text -
it's just plain ugly on complicated drawings with all the flags sizes
different lengths and makes reading the names difficult. PLEASE give us
more options for the XREF feature!!
Bob
    Am 27.07.2011 22:23, schrieb Bob Starr:
    side of net end).
    the left or right.
    Bob
    Hi Bob, speaking of orcad I have done plenty of modifications with that
    system. As long as the labels are correct, no problem. But if they are
    not correct through the whole drawings they cause more problems than help.
    So I prefer the one type only label. I would not want the border off,
    because then the label text might be mixed up with other text in tight
    drawings.
    I don't see what can be done about the label length. Should cadsoft set
    a limit of caracters or an option that one can set the limit oneself?
    In every drawing I know the labl length depends on text.
    The only wish I have on xref is its own size parameter.
    It really brings up my bloodpressure if I change the size of text and
    after placing a label that comes up with that same size, so I have to
    change that again.
    Joern Paschedag
    Bob Starr wrote on Wed, 27 July 2011 16:23
    I'd agree with that.  While you're at it, add some difference between a
    XREF label on a signal with no other connections vs. one with another
    connection on the current sheet.  Right now, you can't tell the difference
    between those two instances which is annoying.
    Yes, the ERC will catch that but once you print it out you can't tell.  My
    rule of thumb is that the schematic should be completely discernible from a
    printed copy.  (That means no hidden pins either, in today's multi-voltage
    world hidden pins are a REALLY BAD IDEA).
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    (first, I dont know why my iphone nntp client doesnt quoue some of the
    followups.. sorry for that)
    When it comes to xref or page connectors, it should be a schematic
    primitive. I used to draw in DesignWorks (capilano computing) and I think
    Eagle has a lot to learn from that sw, both on page connectors and bus
    handling.
    Former Member over 14 years ago in reply to Former Member
    handling.
  • rtzaudio
    drawings.
    change that again.
    Hi Joern, I'm not saying it shouldn't support the framed type also, but
    I'd like another type of port. The simple orcad double arrow heads would
    be a blessing for me as I deal with some large drawings regularly.
    Currently, I have make the text size smaller (like 50 mil) in order to
    line up the XREF borders when placing XREF's next to each other on a
    0.1" grid. Typically I keep text size at the default 70 mils at everything.
    My eyes are shot as is, so trying to read 50 mil bordered text in scaled
    down printout requires a magnifier glasses for me. I'd like to have a
    printer capable of printing architectural sized drawings, but that's not
    likely to happen in this lifetime.
    Bob
    SNIP
    Bob
    Hi Bob, I see you point of view now. In case labels are at 100 mil
    distance one (must) use size 50 for text since the other 50 mils are for
    the frame. Without frame, size could be 80 mils (better for your eyes)  image
    Perhaps cadsoft cold generate kind of bracket for a frameless label
    [[something like this]] but with an option to switch the frame on.
    I still wouldn't want pointers for any direction as I have mentioned before.
    BTW did you try increase the text ratio for a better readability?
    Joern Paschedag
    SNIP
    Bob
    Joern Paschedag
