EAGLE User Support (English) Schematic and Board Consistence
  • Views 276 views
  • board
  • eagle
  • consistent
  • schematic
how it can be possible, in the schematic a net has the name "+12V" and in the board i have two nets names (+12V and n$7).
I had already try run the ERC, and the report was, Board and Schematic are consistent.
I´m using the Eagle version 5.10.0
Regards.
NG
    Thanks for the tip,
    you were right, the wire wasn´t connected.
    Basic error...
    Thank´s again.
    Most likely, you have a unconnected net in your schematics. It may look
    connected, but isnt. Using show for the netnames in brd or sch editor will
    show you the nets (show n$7 will show what's not connected). If you move a
    wire to a device pin, it will not connect. You need to move a device to the
    pin or draw the net to the pin. Could also be grid issues... A good way to
    check for net-device connection is to try tomove the device and see if the
    nets follow.
    "Nelson Goncalves" <communitymanager@premierfarnell.com> wrote in message
    news:1667427299.2461314259247044.JavaMail.jive@flmspu-csapp-02.premierfarnell.com...
    consistent.
    Regards.
    NG
