EAGLE User Support (English) Empty project, no board file
  • Views 645 views
I created a new project and then created a schematic within it.  The .sch
file appears beneath it in the control panel.  There's no board file,
however (usually created automatically), and the Description column says
it's an empty project.  How do I solve these issues?  This is in Eagle
4.16r2.  Thanks.
    But I assume in your case it's a DRC issue.
    That was it again.  Thanks.
    Karl Lautman schrieb:
    Thanks, Tilmann.  That did it.  But I've discovered another problem.  One
    of the parts on the board has a 3-hole footprint.  The holes have a larger
    diameter on the board than in the package editor (this is a part I made
    myself).  The holes on the board are the size they were in the editor when
    I laid them down, but I later reduced them before actually using the part
    in the schematic.  I've tried Library/Update and Library/Update All in the
    board editor, but to no avail.  Any ideas, or should I repost?
    Well, this is another issue - but since it's a VFAQ, it wouldn't make
    sense to start yet another thread about it.
    Regarding pad diameters, please understand the influence of the DRC
    settings in your project/board. Have a look at older posts about pad
    diameter, and read in HELP and manual - and here:
    <http://www.cadsoft.de/training/faq/#11>
    Regarding the UPDATE process, take care that the libraries in question
    are "in use". But I assume in your case it's a DRC issue.
    Tilmann
    Karl
    The board file is created as soon as you enter/click the BOARD command
    in the schematic editor. It's not created instantly with a new schematic.
    4.16r2.  Thanks.
    Right click on the project, then edit the description.
    Tilmann
