EAGLE User Support (English) HELP PLS, updating board from modified sche matic
  • Views 356 views
Hi All,
I'm having a problem. I have made some changes in my schematic and now get
consistency errors between my schematic and the board. I thought it would
update the board.
Mostly, I have removed some gnd wires and placed GND symbols to the pins of
each chip (as required) and updated the values of some resistors. Now eagle
give me consistency errors to each of my changed.
Its a really complex design and don't want to have to delete the board and
replace the bucket-loads of components again. Is there a way to update the
board from the schematic??
Thx Darren
    Thanks guys for the help. I'm slowly getting more and more familiar with
    the software.
    Hey jeorge,
    will Cadsoft be updating eagle to include scrolling up/down left/right with
    the use of the arrow keys rather than panning out and in with the mouse?
    darren
    Am 02.09.2011 19:28, schrieb Jorge Garcia:
    In the next version we will have an indicator in the GUI to let you know
    when consistency is broken.
    Won-der-ful. That should mean much less crippled projects from our
    students who just start layouting and don't know EAGLE too much.
    Andreas Weidner
    On 9/1/2011 10:50 AM, Andreas Weidner wrote:
    Am 01.09.2011 13:05, schrieb Darren:
    >> get
    >> update the board.
    It does that quite well, but ONLY if you have BOTH editor windows
    (schematic AND board) open at the same time. Working with only ONE
    window destroys consistency and creates the mother of all headaches.
    >> and
    >> the
    No. Once consistency is destroyed, you are on your own and need to
    correct everything manually. But one CAN do it manually - even if it's a
    pain somewhere:
    1. The ERC displays lots of inconsistencies telling you what is
    missing on the board, what is connected to different signals,
    etc.
    2. Look at EVERY SINGLE inconsistency and either retrace your steps
    in the schematic, or add signals in the board, or do whatever is
    necessary.
    3. Sometimes one problem may be displayed as several inconsistencies,
    so the number of actual problems might be smaller than shown by
    the ERC.
    4. After EACH change, run an ERC again and look whether that
    problem has been solved. If not, try again.
    Unfortunately, EAGLE does NOT show any warning in case one continues
    working with only ONE window, so one can only prevent inconsistencies
    (and ruined projects) by REALLY paying attention.
    Andreas Weidner
    Hi Andreas,
    Best Regards,
    Jorge Garcia
    Cadsoft Support
    update the board.
    pain somewhere:
         etc.
         necessary.
         the ERC.
    Andreas Weidner
