EAGLE User Support (English) adding extra copper (parallel) routes
  • Views 501 views
Say I have 10 parts & all the airwires have been routed, so ideally
everything is done.
However, I want to add some additional copper paths, say from the input lug
terminal to the output lug terminal  (to give it TWO beefy parallel
paths--assume there is not room for 1 massive path)...or perhaps from R2 to
R3 to provide an extra current path for high current.  These do NOT violate
the schematic.  However, when clicking on the component pin, Eagle just
beeps--apparently to tell me that pin is already finished.
How can I override a "finished" pin to add an alternative rotue?
I don't want pours or polygons, just extra parallel traces (that might take
various geometrical paths).
    Maciej Kucia schrieb:
    You can use line tool to draw a new route without any airwires.
    Caution: if the existing object/track is offgrid, the new one will not
    be connected (getting a new signal name), and DRC errors will result.
    Tilmann
    everything is done.
    No - it beeps since it doesn't find an airwire to route.
    For adding tracks to existing ones, hold the Ctl key pressed when clicking.
    See the built-in HELP for details on the ROUTE command.
    Tilmann
