EAGLE User Support (English) show landscape/portrait  on screen
  • Replies 9 replies
  • Views 491 views
Is is possible to TEMPORARILY switch to a landscape view of my board
layout---it would fit my widescreen better when I zoom in to do some work.
I certainly don't want to start all over!
The normal orientation is portrait to show what I'd consider the top of the
board at the top of the screen.
    Am 23.01.2012 03:59, schrieb Hoyt:
    Did version six V6 fix this limitation?  I'm looking forward to it.
    Unfortunately, NO.
    Andreas Weidner
    Am 09.09.2011 11:21, schrieb Andreas Weidner:
    As a matter of fact, that IS already possible: Every text comes with a
    SPIN flag that tells EAGLE whether this text should be automatically
    rotated to ease reading or not: Enable this SPIN and the text DOESN'T
    automatically rotate.
    Ah. Never noticed that. Personally, I would prefer to have this enabled
    by default...
    Dietmar
    Am 08.09.2011 23:33, schrieb Dietmar Schwertberger:
    IMHO this is one of the worst features of Eagle. It should be possible
    to rotate text
    The problem is that this feature depends on the individual OBJECT's
    settings, which one doesn't know and cannot see while rotating the whole
    board.
    Also options for center and right alignment would be nice sometimes.
    Yes - agreed.
    Andreas Weidner
    Am 08.09.2011 13:46, schrieb Andreas Weidner:
    Additionally, depending on your text settings, the layout may be
    MINUTELY different after rotating: By default, EAGLE shows texts so that
    they are readable from below or the right side. Rotating the board of
    course also rotates the text and, in order to make it readable, EAGLE
    might rotate the text some additional 180 degrees. If you're using
    ground polygons, these will flow a little bit different then and, on
    dense boards, might create problems (we once had the problem of
    unconnected 'islands' after rotation).
    to rotate text (e.g. when I want to assemble several board into one
    panel and have to rotate one board to fit).
    Dietmar
    Yeah, I just want to rotate the VIEW on the screen, not the board in the
    physical panel...my screen is  much wider than taller, so zooming in would
    be much better if I looked at my board sideways ( landscape ).
    this should be a NEW FEATURE!!!
    Am 08.09.2011 09:13, schrieb Lorenz:
    ... you can "display all; group all; rotate R-90 (>0 0), display last"
    that won't work if you have locked parts though!!!
    Therefore, if you want to have a really RELIABLE display, don't rotate
    the board. And since EAGLE cannot rotate the view, you're stuck. Too bad...
    Andreas Weidner
    there is no such display option in eagle, but ...
    Lorenz
    If you don't want to make any changes do the following:
    command line: "set used_layers all", enter
    "group all", enter
    click the move-button (or F7 or simpy "mo", enter in the command line)
    hold CTRL-key & with rmb rotate your layout in steps of 90 degrees
    r
