EAGLE User Support (English) Re: import image into GND plane?
  • Views 289 views
The problem comes after CAMP; when viewing in Gerbv only the outline is
present
    Quote:
    You could just convert the GND plane to a normal layer, add a polygon
    over the whole board and name it "gnd". That would keep your image.
    That sounds pretty much what I have already...
    GND plane is:
    Layer Top 1
    Polygon Pour: Solid
    Signal Name: GND
    I have just noticed the image can be seen in gerbv viewer But!!! only at a
    set altitude...and importantly it's not present in the board pic exported
    from gerbv...I think it's something to do with how CAMP is processing the
    imported image; as no other layers seem effected
    .just tried importing the image to its own separate layer(Layer 2) and
    giving it dominance over the top layer in gerbv ..but the result is still
    the same
    "tuk" <acceleratedrain@gmail.com> wrote in message
    news:j4toq4$v7n$1@cheetah.cadsoft.de...
    present
    This is because supply layers are negative, and the text drawn is removed
    from the copper.
    You could just convert the GND plane to a normal layer, add a polygon over
