EAGLE User Support (English) Re: import image into GND plane?
  • Views 584 views
However when I run the CAM job and view the resulting files in gerbv ...the
bmp image is missing and only the outline remains
    Morten Leikvoll schrieb:
    I think I may get it. The bmp is probaby built of small rectangles and I'm
    not sure how CAM export that. It wont be as round aperture wires for sure.
    It could be that gerbv has issues with that data.
    Does the export script do wires?
    Importing a bitmap results in small rectangles (pixel sized) which are
    later output as flash apertures in the gerber code.
    As Jorge mentioned, it should work with GCprevue (which I'm also using
    for decades now, and never had any problems), and gerbv seems to have
    problems with that.
    Tilmann
    Jorge Garcia wrote on Tue, 20 September 2011 14:03
    Gerbv has a bug which doesn't allow it to show features imported with
    the import-bmp.ulp. Try using Viewmate or GC-Prevue, even the online
    gerber viewer at www.circuitpeople.com will show you the correct
    features.
    Hi Jorge, aha...that explains why the bmp can be seen at certain low
    altitudes in gerbv..for 3 clicks of the mouse-wheel it can be seen...one
    more click and poof it's gone...I will investigate those suggestions and
    return
    @Tilaman thanks for explaining the forum/newsgroup thing..I will look into
    these when I get a mo
    Hi Tuk,
    gerber viewer at www.circuitpeople.com will show you the correct features.
    hth,
    Jorge Garcia
    Would you please stop to create new threads for every new idea or comment?
    Tilmann
