EAGLE User Support (English) Re: import image into GND plane?
  • Replies 8 replies
  • Views 654 views
Quote:
Your posts lack the references to the previous posts, that's why they
appear to start a new thread here in the newsgroups. Maybe you used
"new
message" instead of "reply", maybe the web forum gateway is broken
again... :-\
Im 90% sure I used reply ..on my screen All my posts in this forum appear
in the only thread I have made since joining ..I always return to my posts
several times to check spelling/clarity so I would probably notice if I
created a new thread
Quote:
On the topic:
At least for me it's still unclear as to what your problem is. Perhaps
you can also provide an image about how it appears in gerbv. You might
also upload a board file containing a test case with your imported
bitmap and then post a link so we can have a look at your data.
based on this comment I think the forum has a problem of some kind ..I was
surprised when Morten Leikvoll asked me for screenshots because I had
already posted 'self-explanatory screenshots' in my first post and then
posted them again in reply to Morten ...I though you were warning me
because I had posted the same screenshots twice ..and now your asking for
screenshots..I'm guessing you cant see Any of the pics I've posted?
offtopic:
I can post screenshots of this thread to help troubleshoot the issue ..but
will you be able to see them? image
    Warren Brayshaw schrieb:
    >> I can strongly recommend the Faststone Image Viewer as the perfect
    >> all-purpose tool for everything related to images.
    I had a look at  Faststone Image Viewer
    It does not appear to be able to compress images. I see it can
    resize/resample but not optimise for a smaller file size. Have I missed it?.
    You already found it by yourself...
    Besides, it's essential to choose the right file format. JPEG is only
    fine for photos, for screenshots of menus or technical content PNG is
    much more effective (with reduced number of colors to further shrink the
    files) - and also better to read (lacks the compression artefacts).
    >> (And while we're at it, you could consider installing Quotefix...)
    It is installed already from your previous advice, thanks  Although I
    replied to a post, I did erase everything and not quote any of  it. Are you
    seeing something amiss?
    Your second post on the "boycott" issue (18.09.) contains some broken
    quotes (lines wrapped after quoting).
    Tilmann
    tuk wrote:
    warrenbrayshaw wrote on Tue, 20 September 2011
    >> TUK- It is web ediquit to compress/optimise your images before
    >> attaching.
    >> Get a app like 'Image Optimiser'  and your screen shots can be
    >>  squashed to
    >> a more manageble size. Had you done this, all your images would have
    >> got
    >> through.
    I used IrfanView to reduce the images to the forum upload limit of
    49kb or less..the source files being several hundred kb each I
    thought this was reasonable ..had I known the trouble it would cause
    ^^ image
    Kudos for the attempt.
    FYI
    I had a go with the very first image you posted.(48kB)
    Leaving it as a JPG it is still OK at 16kB
    Changing it to a PNG (with 4 colours) it is great at 7kB
    Regards
    Warren
    news.cadsoft.de
    missed it?.
    I found it. A side function of "Save as..."
    news.cadsoft.de
    >> I did not see apparent new threads as Tilmann saw.
    See the attached image. The screenshot shows the first post of tuk
    appearing in the newsgroup, and all the subsequent new threads fully
    expanded.
    I see.
    ................ Maybe this is a result of the first post
    missing, so the gateway couldn't detect the message to reference in
    first place?
    That makes sense.
    Tilmann
    Regards
    Warren
    news.cadsoft.de
    attaching.
    Get a app like 'Image Optimiser'  and your screen shots can be squashed
    to
    got
    through.
    I used IrfanView to reduce the images to the forum upload limit of 49kb or
    less..the source files being several hundred kb each I thought this was
    reasonable ..had I known the trouble it would cause ^^ image
    A trap with NNTP is that the 50kB appears to be the whole message and not
    the attachment limit so a 49.6kB attachment at EagleCentral won't  get
    through due to the text ,message and wrapper text exceeding 50k in total.
    That's logical since in newsgroups, all attachments are transported in
    the message body - and due to encoding the size increases about 20%.
    TUK- It is web ediquit to compress/optimise your images before attaching.
    Get a app like 'Image Optimiser'  and your screen shots can be squashed  to
    a more manageble size. Had you done this, all your images would have got
    through.
    expanded.
    Maybe your OE is configured so that it automatically combines threads
    that have the same subject line? In fact, those posts by tuk don't have
    the usual "references" header, so they are not correctly related to the
    existing thread. Maybe this is a result of the first post missing, so
    the gateway couldn't detect the message to reference in first place?
    My newsclient also provides that option, but it's better to leave it
    unchecked. Otherwise, posts with more common subjects (i.e. "I have a
    question") are sorted as reply to some old post that randomly had the
    same subject.
    Tilmann
    This has been a messy thread. A few observations looking at it with
    newsreader and browser.
    The initial post was not accepted by Newsgroup as it was over 50kB.
    Interestingly (the first time I have seen this) although James reconfigured
    EagleCentral to not accept files over 50k and limited to three attachments,
    you can add many 49kB files so that's why it was rejected by Newsgroup as
    there was 116kB of attachments.
    A later  post did not get to the Newsgroup. It had a sigle 45.88kB
    attachment.
    The first message the newsgroup saw, the second post when viewed at
    EagleCentral has an imbeded image. Strangely this image appears to have been
    attached to the first message. James needs to look into this.
    Subsequent posts have images imbedded. These don't pass through to the
    newsgroup. Something more for James.
    Stop Press: An now tuk- has posted all the images again, which did not reach
    the newsgroup  because the total is 180kB
    through.
    Regards
    Warren
    news.cadsoft.de
    >> "new
    >> again... :-\
    Well, this message starts yet another thread - while your previous reply
    to my message referenced that correctly. image
    Quote:
    >> On the topic:
    Yes, that web gateway still has "some problems of some kind"... :-\
    What about using a decent news client (Thunderbird, SeaMonkey, Forte
    Agent, etc.) and access the newsgroups directly? Note that even when
    accessing the "forums" at eaglecentral.ca, you are not really using a
    forum - instead, it's just a (somewhat buggy) web based frontend to the
    newsgroups.
    ..I was
    There simply was no "first post" here. Your first post visible in the
    newsgroup seemingly is a reply already (starting with Re: in the
    subject). Eventually, your attachment was larger than the size limit
    (50k?) for the newsgroups so it didn't get through.
    The (probably) second screenshot is visible - but from that, at least I
    can't see what your problem is. There is an imported logo, obviously
    importing it has worked. Fine - but what's the problem with the gerber data?
    offtopic:
    You'd better upload your images and post a link.
    Tilmann
