EAGLE User Support (English) how to copy a symbol
  • Views 406 views
Is it possible to copy an existing library-symbol to another name so I
can use it as a starting point afterwards for editing and making a
different package with it?
regards,
hugo
p.s. my apologies to Michael Cooper for "stealing his thread", it
happened by accident
    Lorenz schrieb:
    symbols can not be copied separately.
    Unfortunately... Hoping that V6 will finally fix that.
    You will need to copy a device that uses the symbol you want.
    That will copy all packages and symbols used by that device too, so
    you will have to clean up afterwards.
    If you need only the symbol, GROUP/CUT/PASTE will probably be easier and
    faster.
    Tilmann
    >Open the library editor and open/create a library
    >Go to the Control Panel (..the eagle control panel not the windows one)
    >Expand the libraries tab and browse to the symbol/part that you want
    >Right click and select the "Copy to Library" option ...this copies the
    >part/symbol/package to your new library
    Lorenz
    regards,
    hugo
