EAGLE User Support (English) Pan in the layout
  • Subscribers 189 subscribers
  • Views 1026 views
Pan in the layout
Gustav_M
Gustav_M over 14 years ago
In version 4 it was possible to pan (or "scroll") around in the layout by holding the Ctrl button down and moving the mouse.
Is it possible to do the same in version 5? How do you enable that?
    Element 14 User wrote on Thu, 22 September 2011 17:15
    That's what the center mouse button does.
  • Gustav_M
    Gustav_M over 14 years ago in reply to e14 Contributor
    Nice to hear that I am not the only one who likes the Ctrl for panning in V4.
    Thanks for the help, Tilmann.image
    In V5, the ctl key has some new functions... You need to re-enable the
    old functionality with a switch in eaglerc.usr or via the SET command.
    See the built-in HELP, last section, for "Interface.UseCtrlForPanning".
    Take care that there are some side effects with the new functions of the
    ctl key. However, that was one of the first settings I applied after
    moving to V5. image
    Tilmann
