EAGLE User Support (English) Interpreting progress bar / status bar
  • Views 499 views
I added a line in the BRD: section of eagle.scr to run a ULP when a board
loads. The ULP does run.
Referring to the attached image. The ULP 'statistic-brd has run to the
dialog displaying the results but you can see the board below shows an
incomplete progress bar and a 40% figure.
Closing the ULP dialog quickly clears the 40% indication
What I would like to know what the 40% is referring to so that I can be
assurred the ULP is working with all the board data.
If the board is fully loaded/displayed, as it appears to be, then this may
be simply a delay in updating the status and could be fixed.(v5.11.1)
Warren
    autodeskguest over 14 years ago in reply to e14 Contributor
    Richard Hammerl wrote:
    Running the ULP from a scrip file.... That's the difference. The
    percentage belongs to the script file that is executed and starts
    the ULP. So i think that 40% of the script are done when the ULP
    starts. Quit the ULP and the percentage will increase until the
    script is finished.
    That seems to be  the explanation.
    Thanks for your time
    Warren
    news.cadsoft.de
    script is finished.
    Warren
    news.cadsoft.de
    e14 Contributor over 14 years ago in reply to Richard_H
    Am 23.09.2011 10:16, schrieb Warren Brayshaw:
    >> board loads. The ULP does run.
    >> the dialog displaying the results but you can see the board below
    >> shows an incomplete progress bar and a 40% figure.
    >> be assurred the ULP is working with all the board data.
    >> this may be simply a delay in updating the status and could be
    >> fixed.(v5.11.1)
    I just tried this and did not get the progress bar at all. How
    long does it take until the statistics are shown after starting the
    ULP?
    Adding a label to the dialog and using timems()
    it displays between 571 and 710 milliseconds.
    There is no progress bar if the ULP is run from the board editor.
    This is only noticed when running from eagle.scr
    I launch by selecting one of the sch/brd pair in control panel.
    What you observe depends on which of the pair you use to load the pair.
    Starting with the brd I can observe the 40% while the statistics are
    displayed. When I quit that statistics display I can see the flash of a % in
    the sch.
    While testing this just now I manged to have statistics-brd.ulp run without
    any board or schematic getting displayed. That's the first time I have seen
    that but earlier today I got various results when trying to have ulps run
    for both schem and board as a schem /brd pair loaded indicating that race
    conditoins are at play.
    I have also just had the statistics being displayed.before the board was
    displayed. The schem was already open in this case.
    Try running a script that generates an error as follows
    I tried euro.scr placed in the BRD: section of eagle.scr
    From the control panel double click the SCH of a BRD/SCH pair
    The script errors as the SCH is displayed and script wants to draw wires
    into the BRD.about 12 times
    Watch the board details in the task bar as you acknowledge the errors, They
    count up which suggests the figures represent % done of the script.
    I see 30% 38% 44% 49% 58% 70% 75% 80% 89% 100%
    Warren
    news.cadsoft.de
  • Richard_H
    Richard_H over 14 years ago in reply to e14 Contributor
    Am 26.09.2011 14:24, schrieb Warren Brayshaw:
    >>> fixed.(v5.11.1)
    >> ULP?
    the sch.
    Warren
    script is finished.
    Richard Hammerl
  • Richard_H
    Warren
    long does it take until the statistics are shown after starting the ULP?
    Richard Hammerl
